Local Time 07:31 22 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Pico Computer 3 is not fully operational until it runs DOOM
javavi
Posted: 08:37pm 30 Oct 2026
PC3_DOOM.zip
Flash the firmware onto the Pico Computer 3,
and copy the `doom1.wad` file onto an SD card.
Now you're ready to play!
https://github.com/rh1tech/frank-doom
Why do we need AI when we still test hardware by running DOOM?
hhtg1968
Posted: 08:53pm 30 Oct 2026
cool!
we must do that in mmbasic.
I changed peters demo for ray to create a little fps shooter and I am working on it. the ray command does not have all the features of the doom1 engine but that does not matter...
hhtg1968
Posted: 08:57pm 30 Oct 2026
by the way:
ray is on my cmm2 much faster than on picomite. at the resolution 640x480 it is nearlay smooth.
Frank N. Furter
Posted: 12:59pm 05 Nov 2026
Can you also make a version for HERETIC? It runs on Chocolate DOOM, for example. HERETIC runs on the same engine as DOOM...
That would be great!
Frank
Posted: 01:52pm 05 Nov 2026
heretic is much nicer than doom
Posted: 03:15pm 05 Nov 2026
Heretic will be on the CMM2 launchable from Basic later today or tomorrow
Posted: 07:24am 06 Nov 2026
Hi javavi,
If you port this:
https://github.com/rh1tech/frank-idtech1
Then you have all the IDtech games.
Also look at :
duke nukem
Prince of....
Edited 2026-11-06 17:27 by Volhout
javavi
Posted: 08:06am 06 Nov 2026
  Volhout said  Hi javavi,
If you port this:
Hi Volhout,
Yes, I know Mikhail from Greece through the Murmulator group on Telegram. I actually got *Doom* from him for porting purposes. I also reached out to him regarding *Heretic* to add support for a USB mouse; he said he’d take a look. Once it’s ready, we’ll post it here.
And since I only have electricity for about 3 hours a day, I’ve been tinkering with PicoMite MMBasic in the meantime.
Posted: 08:36am 06 Nov 2026
I hope this war is over soon. You must be so tired of it.
Are you running of batteries during outages ? Pico can run quite a while from a power bank. But the monitor will draw much more.
I wish you and your people strength to keep living.
P.S. I think it is Eisenhower who said this: War is millions of people, who don't know each other, killing each other. Just because of 2 people that know each other, and who are not killing the other.
javavi
Posted: 09:18am 06 Nov 2026
  Volhout said  I hope this war is over soon. You must be so tired of it.
In this situation, people acquire a great many things that are unnecessary in ordinary, peacetime life.
Posted: 09:53am 06 Nov 2026
That's a meaty animal! :)
A lot of monitors and TVs use a power brick now, which often has a 12V output. That sort can be run directly from a battery (well, a fuse is a good idea...) and it's more energy efficient than using an inverter. It's not as impressive a solution though. :)
javavi
Posted: 09:18pm 06 Nov 2026
  Frank N. Furter said  Can you also make a version for HERETIC? It runs on Chocolate DOOM, for example. HERETIC runs on the same engine as DOOM...
Yes, that’s almost certainly possible; let’s see—maybe something can be done about it later...
In the meantime, go ahead and play Wolfenstein 3D.
Wolf_3D_PC3.zip
https://github.com/rh1tech/frank-wolf3d
Frank N. Furter
Posted: 05:13pm 07 Nov 2026
Thank you very much for your efforts!
Frank
javavi
Posted: 09:28pm 12 Nov 2026
For my experiments with the Pico Computer 3, I built an adapter on a breadboard that connects to the external I/O port, allowing for the attachment of various peripherals: a PS/2 keyboard, a PS/2 mouse, an NES game controller, and a Wii game controller.
Posted: 08:00am 13 Nov 2026
Nice !
You are creating the standard now by being first to suggest. I am not sure you can get a PS2 keyboard to work on GP0/GP1 though. If I recall it uses GP8/GP9 default in PS2 builds of MMBasic.
Posted: 09:10am 13 Nov 2026
OPTION KEYBOARD PINS
clockpin, datapin ✓ NON-USB VERSIONS ONLY Allows the user to select the pins to be
used for connecting a PS2 keyboard. The default is pin 11 (GP8) and
pin 12 (GP9).
The PS2 keyboard must be disabled (OPTION KEYBOARD DISABLE)
OPTION MOUSE CLKpin,
DATApin
Set the pins to be used to connect a PS2 mouse. Using this command the
mouse is automatically configured on boot and you can set up interrupts
and read values with no additional commands. This is different from the
MOUSE OPEN which only connects to a mouse while the program is
running. The PS2 mouse MUST be is disabled.
The PS2 signal lines should ideally be level shifted for a 3V3 system.
Edited 2026-11-13 19:19 by Mixtel90
