Local Time 07:31 22 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Colour Maximite 2 V3 G3: First look
Posted: 02:48pm 14 Nov 2026
The boards have arrived for the Colour Maximite 2 V3 G3. This is a version with on-board HDMI and below is the very first image after the MS7210 chip was correctly programmed over I2C. The image quality is stunning up to and including 1080p. This was driven with an app so the next step is to embed the driver code into the firmware. Once everything is tested I'll put the design files on github. Bottom pic is of the all-new wifi dongle. If I can get this working the CMM2 will have all the web functionality currently available on the PC3/Webmite
Posted: 03:58pm 14 Nov 2026
OOH! Those are rather nice boards. :)  I may need surgical modification for the power switch (if that's what it is) though, it looks a bit tight in the pic, especially with a WiFi adapter plugged in as well.
Wölfi
Posted: 05:28pm 14 Nov 2026
I’m looking forward to seeing more and learning more about it.
Posted: 05:33pm 14 Nov 2026
UPDATE
Video fully working. Now implementing HDMI audio
homa
Posted: 05:34pm 14 Nov 2026
I had a feeling!
Will the Wi-Fi also work on the older CMM2?
Matthias
Edited 2026-11-15 03:35 by homa
Posted: 05:41pm 14 Nov 2026
  Quote  Will the Wi-Fi also work on the older CMM2?
If it works at all, then yes
Posted: 03:39am 15 Nov 2026
STOP!
STOP, PETER!!!
YOU'RE GONNA EXPLODE IF YOU KEEP RELEASING THINGS AT THIS SPEED!
The MS7210 chip looks like a very interesting little beast, and I can't believe it is less then two bucks per chip($1.80) for a full 1080p HDMI interface with audio!
Does the new beast of a PCB actually NEED the power-switch?
Do people actually USE it now?
Any CMM2G2's I have been shipping, I leave the little power switch in the "ON" position anyway.
Kinda like the Raspberry PI idea - the power switch is the USB power connector and plug.  Plug it in, it's "ON".  Pull the plug out, it's "OFF".
I doubt the switch costs much, so I guess if it can be fitted in at all....
What do others here think?
Posted: 08:10am 15 Nov 2026
Personally, and being ancient, I still love the toggle switch on the front. You can see exactly what it's doing, you can have it actuating either way up and it has a nice, satisfying clonk. However, it's not great for preassembled boards. It has to be hand-soldered, it's much more expensive and it makes the board more fragile, leading to higher shipping costs. It also isn't ideal for switching 5V at low current (toggle switches rarely are as the self-cleaning action can be poor).
I moved onto push-push mechanical buttons, which are good but take up a little more width on the panel than I like, but they aren't as deep on the board as toggle switches. Self-cleaning is better than a toggle switch. They still need hand soldering though.
My latest experiment is to use mosfet power switching. Although it takes up board area and demands the use of a SMD mosfet as the power device (I can't find low enough RDSon for P-channel in any other package), the actuating button can be tiny and tucked away just about anywhere.
IMHO if the power switch isn't on the front then it's not going to be used by many people. They *will* put stuff on top of the enclosure and unplugging the PC end of the lead might be easier. :)
PhenixRising
Posted: 09:38am 15 Nov 2026
  Grogster said  What do others here think?
Me no-like and I also regard the tinned edge-connectors, on the PCB, an eye-sore.
Posted: 09:53am 15 Nov 2026
The edge connectors aren't great, but availability of WII controller PCB connectors is poor now that the WII has been out of production for many years. You can get them from one or two Chinese sellers, but they are not easy to find.
Posted: 10:01am 15 Nov 2026
If you don't like the switch don't specify it and link the pads - easy.
The nunchuck connectors stay, they are part of the cmm2 concept
Posted: 10:42am 15 Nov 2026
I've been trying to find that sort of switch. Usually such things can be found on AE, but not in this case. I can find plenty of latching switches but not horizontal operating, only vertical.
Posted: 10:44am 15 Nov 2026
I will add a 2-pin header that you can either bridge or use to connect a remote switch.
UPDATE
Wifi dongle now tested and wifi networks identified
javavi
Posted: 10:57am 15 Nov 2026
Will this MS7210 chip work here in both HDMI mode (with audio) and DVI mode (without audio) for older DVI monitors?
Would it have been possible to retain the VGA video output alongside this media converter chip, so as to have two types of video output on the board?
Posted: 11:10am 15 Nov 2026
There seems to be an audio output jack, which would be pointless if audio was only via HDMI. So, yes, the display can probably ignore the audio.
AFAIK the main difference between Gen 2 and Gen 3 is the change in display. You are probably be better sticking with a Gen 2 (or Gen 1) if you want VGA. Fitting both would probably have been a pain (and needed a bigger box!).
Posted: 11:11am 15 Nov 2026
  Quote  Will this MS7210 chip work here in both HDMI mode (with audio) and DVI mode (without audio) for older DVI monitors?
yes, audio is output both on the hdmi and on the existing DAC
  Quote  Would it have been possible to retain the VGA video output alongside this media converter chip, so as to have two types of video output on the board?
No, no space on the edge connector, also the R2R DAC is marginal electrically in terms of the chips pin drive and can cause some clock jitter. In any case the G2 is still a perfectly viable design. This doesn't add anything to the G2 other than the different video output. The wifi dongle will work on both
javavi
Posted: 11:21am 15 Nov 2026
  matherp said  yes, audio is output both on the hdmi and on the existing DAC
What concerns me more is whether a DVI monitor will be able to accept an HDMI signal from this chip.
I have several such DVI monitors (because they are very cheap), and I connect to them using a simple HDMI-to-DVI adapter and an HDMI cable. These monitors absolutely refuse to accept an HDMI signal; even when the audio is disabled, the data packets (data islands) still remain.
Does this chip have the capability to be configured for a true DVI output?
Posted: 11:41am 15 Nov 2026
Ah... DVI is a subset of HDMI. HDMI should accept DVI signals but DVI doesn't usually accept HDMI - they are different. I'll be surprised if that chip can produce what is now an obsolete format.
Posted: 11:42am 15 Nov 2026
I'll look whether I can include a switch (OPTION DVI ON/OFF) to switch the MS7210 into DVI mode.
Edited 2026-11-15 21:42 by matherp
Posted: 11:44am 15 Nov 2026
Short answer from Lumo:
  Quote  Short answer: yes, indirectly — although the MS7210 is marketed purely as an HDMI transmitter, not a DVI part.
What the chip actually is (per MacroSilicon's product page): the MS7210 is an HD transmitter with a high-speed TMDS core (up to 300 MHz clock), accepting parallel digital video input (BT.601/BT.656/BT.1120, RGB or YCbCr) plus I²S/SPDIF audio, and outputting an HDMI-compatible TMDS signal at resolutions up to 4K@30Hz.
Why that matters for DVI: single-link DVI-D uses exactly the same TMDS electrical signaling as HDMI — HDMI was built as a superset of DVI. So the MS7210's TMDS output is electrically compatible with a DVI sink, provided you observe the constraints:
   Pixel clock limit: single-link DVI tops out at a 165 MHz TMDS clock (~1920×1080@60Hz). The MS7210 can clock faster (it supports 4K@30), so you must restrict output formats to those at or below 165 MHz. Above that you'd need dual-link, which the chip doesn't provide.
   Format: output RGB, 8-bit, CEA-861/VESA-style timing — no deep-color or YCbCr-only modes, since DVI sinks generally only understand RGB.
   Physical connection: a passive HDMI-to-DVI-D cable/adapter is all that's needed; no active converter.
   Audio/CEC/infoframes: these simply won't reach the DVI display (DVI has no audio channel over a passive adapter), but they're optional in HDMI transmission, so their absence doesn't break the video.
One caveat worth flagging: MacroSilicon's public materials don't explicitly mention DVI compliance or DVI handshake behavior, so whether it plays nicely with a particular DVI monitor (EDID handling, sync detection) is best confirmed on real hardware or by checking the full datasheet. But in principle, an HDMI/TMDS transmitter like this driving a single-link DVI display is a well-established, commonly used combination.
