Local Time 18:05 21 Jun 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : USB Driver
elchucko
Posted: 04:21am 14 Nov 2011
When I download the driver from Geoff's web site, there's a pdf file a doc file but no driver after extraction. Ideas? Thanks
sparkey
Posted: 04:27am 14 Nov 2011
maybe there is a problem on the site or perhaps you did not get a good down load the down loads are at the bottom of the page in the maximite computer ..also have you looked at what u actully did down load you did not specifiy this...
elchucko
Posted: 04:32am 14 Nov 2011
I tried downloading from Geoff's project page several times. Download shows Install Doc, mchpcdc Security Doc and Setup info, nothing else.
crackerjack
Posted: 04:42am 14 Nov 2011
There should be the following files in the zip archive:
* Installing the USB...PDF
* mchpcdc.cat
* mchpcdc.inf
The inf file is the driver file. Follow the instructions in the PDF and you should be right.
elchucko
Posted: 04:50am 14 Nov 2011
I found the following files. Install Doc, mchpcdc Security Catalog and mchpcdc Setup Info, nothing else.
sparkey
Posted: 05:00am 14 Nov 2011
he`s just seeing icons not files ..needs to actully connect the maxi to the computer to let the computer see it then it should find new hard ware then it should start asking for files then select the directory where the files are it should have created a folder and you need to select that folder ...unless u let it lookfor its self and then at some stage through the driver instalation progres it will ask if the drivers are digitally signed ..."pick continue any way" then it should install and fianally hope fully be loaded ...go to the device manager and open the comports you should see that the driver is there and the maxi must or should be still connected to the pc it will prolly say its on com4 ....then you can start to communicate with it use hyper term and create a user name for the connection when prompted and pic a icon then ok it will now show another screen saying "connect to " only change the connection its the bottom option on this screen ..."change that to match what ever com port is selected by the device manager say com four ...you should se it in the lis select it click ok ..."" propities"" the only thing you should change is the "baud" rate it worked fine for me on 9600 but is capeable of 19200
hit ok and the screen should appear hit the space bar see if the cursor moves or if you actully see the bios startt up splash etc you should be connected....Edited by sparkey 2011-11-15
elchucko
Posted: 05:05am 14 Nov 2011
OK, I don't have my Maximite yet. Thought I'd get one step out of the way! I'll wait.
sparkey
Posted: 05:24am 14 Nov 2011
down load the maxi user manual have a read it should help answer some stuff its on geoffs site i think you know where...
Posted: 06:31am 14 Nov 2011
  elchucko said   I tried downloading from Geoff's project page several times. Download shows Install Doc, mchpcdc Security Doc and Setup info, nothing else.
Those are the three required files.
I recommend that you change your windows options to show file extensions for known file types.
elchucko
Posted: 11:15pm 17 Nov 2011
Sorry for the questions. I'll read up on the subject! Edited by elchucko 2011-11-19
elchucko
Posted: 05:48am 18 Nov 2011
I got the driver loaded and running HT.
