Forum Index : Microcontroller and PC projects : Teraterm - presets
| aargee Senior Member Joined: 21/08/2008 Location: AustraliaPosts: 255 |
I'm using Teraterm when playing with the Maximite, but also use it for mucking around with Bus Pirate and a few other serial applications. Now, I'm probably missing the bleedin' obvious, but where/is there a way to save the Maximite setup as a preset (serial port, baud rate, etc), then another for the Bus Pirate, etc. So one click sets up TT for each application? Regards, Rob (probably soon to have sheepish look on face). For crying out loud, all I wanted to do was flash this blasted LED. |
| BobDevries Senior Member Joined: 08/06/2011 Location: AustraliaPosts: 266 |
Rob, you can put that sheepish look in place now..... in the SETUP menu there's a selection "SAVE SETUP". You can change the name from TERATERM.INI to anything you want. Then also in the SETUP menu, there's RESTORE SETUP. Hope that helps.
Regards, Bob Devries Dalby, QLD, Australia |
And then when you have the new INI files, you can start Teraterm with those INI files from separate desktop icons. That saves a few mouse clicks! Check the help file under command line /F option. Jim VK7JH MMedit |
Thanks Gentlemen, I'll have a play. - Rob. For crying out loud, all I wanted to do was flash this blasted LED. |
