Local Time 06:07 24 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : (MM-DM-UBW32) The 3D Mite !
darthmite
Posted: 07:02pm 25 Nov 2011
Heya
I just discover the MM some day's ago and have build 3 different sort.
Now for see what it can do i just have made some 3D graphics tests.
The 3D Algorithm are pretty simple (no back face computing). only the
3D meshes is showed and rotate in your screen
OK i stop babbling ... here are the sources.
3D Cube test:
10 'Number of Faces and Number of Points
11 DATA 35,19
12 'Points from the 3D Object
13 DATA -10.0,-10.0,-10.0
14 DATA 0.0,-10.0,-10.0
15 DATA -10.0,-10.0,0.0
16 DATA 10.0,-10.0,-10.0
17 DATA 10.0,-10.0,0.0
18 DATA 10.0,-10.0,10.0
19 DATA 0.0,-10.0,10.0
20 DATA -10.0,-10.0,10.0
21 DATA 10.0,0.0,-10.0
22 DATA 10.0,10.0,-10.0
23 DATA 10.0,10.0,0.0
24 DATA 10.0,10.0,10.0
25 DATA 10.0,0.0,10.0
26 DATA 0.0,10.0,-10.0
27 DATA -10.0,10.0,-10.0
28 DATA -10.0,10.0,0.0
29 DATA -10.0,10.0,10.0
30 DATA 0.0,10.0,10.0
31 DATA -10.0,0.0,-10.0
32 DATA -10.0,0.0,10.0
33 'Faces from the 3D Object
34 DATA 0,1,2
35 DATA 1,3,4
36 DATA 5,6,4
37 DATA 6,7,2
38 DATA 2,1,6
39 DATA 1,4,6
40 DATA 3,8,4
41 DATA 8,9,10
42 DATA 11,12,10
43 DATA 12,5,4
44 DATA 4,8,12
45 DATA 8,10,12
46 DATA 9,13,10
47 DATA 13,14,15
48 DATA 16,17,15
49 DATA 17,11,10
50 DATA 10,13,17
51 DATA 13,15,17
52 DATA 14,18,15
53 DATA 18,0,2
54 DATA 7,19,2
55 DATA 19,16,15
56 DATA 15,18,19
57 DATA 18,2,19
58 DATA 3,1,8
59 DATA 1,0,18
60 DATA 9,8,13
61 DATA 14,13,18
62 DATA 8,1,13
63 DATA 1,18,13
64 DATA 7,6,19
65 DATA 6,5,12
66 DATA 12,11,17
67 DATA 17,16,19
68 DATA 19,6,17
69 DATA 6,12,17
10000 OPTION base 0
10010 CLEAR
10020 CLS
10030 DIM sinx(360)
10040 DIM cosx(360)
10050 'We get the number of points and faces
10060 RESTORE
10070 READ nbface
10080 READ nbpoint
10090 DIM px(NbPoint)
10100 DIM py(NbPoint)
10110 DIM pz(NbPoint)
10120 DIM face(NbFace,3)
10130 DIM nx(NbPoint)
10140 DIM ny(NbPoint)
10150 deg = 3.14159 / 180
10160 'Record the sinus and cosinus table
10170 FOR a = 0 TO 359
10180 sinx(a) = SIN(a*deg)
10190 cosx(a) = COS(a*deg)
10200 NEXT a
10210 'Read the points from the 3D Meshe
10220 FOR a = 0 TO NbPoint
10230 READ px(a),py(a),pz(a)
10240 NEXT a
10250 'Record the Faces from the 3D Cube
10260 FOR a = 0 TO NbFace
10270 FOR b = 0 TO 2
10280 READ face(a,b)
10290 NEXT b
10300 NEXT a
10310 'Starting Angles
10320 ax = 45
10330 ay = 20
10340 az = 0
10350 'Zoom on the 3D Cube
10360 zoom = 5
10370 'Cube Center
10380 dx = 152
10390 dy = 108
10400 'Rotate the 3D Cube
10410 DO WHILE 1
10420 sx = sinx(ax)
10430 sy = sinx(ay)
10440 sz = sinx(az)
10450 cx = cosx(ax)
10460 cy = cosx(ay)
10470 cz = cosx(az)
10480 FOR i = 0 TO NbPoint
10490 tx = px(i)
10500 ty = py(i)
10510 tz = pz(i)
10520 'Save the old coordinates
10530 'Rotate on X axis
10540 y = ty * cx - tz * sx
10550 z = ty * sx + tz * cx
10560 ty = y
10570 tz = z
10580 'Rotate on Z axis
10590 x = tx * cz - ty * sz
10600 y = tx * sz + ty * cz
10610 tx = x
10620 ty = y
10630 'Rotate on Y axis
10640 x = tx * cy - tz * sy
10650 z = tx * sy + tz * cy
10660 'Save the screen points coordinates
10670 nx(i) = INT(x * zoom + dx)
10680 ny(i) = INT(y * zoom + dy)
10690 NEXT i
10700 'Erase the old 3D Cube and trace the new one
10710 CLS
10720 FOR i = 0 TO NbFace
10730 LINE(nx(face(i,0)),ny(face(i,0)))-(nx(face(i,1)),ny(face(i,1 ))),1
10740 LINE(nx(face(i,1)),ny(face(i,1)))-(nx(face(i,2)),ny(face(i,2 ))),1
10750 NEXT i
10760 'Increment all angles
10770 ax = ax + 3
10780 ay = ay + 3
10790 az = az + 3
10800 IF ax>359 THEN
10810 ax = ax - 360
10820 ENDIF
10830 IF ay>359 THEN
10840 ay = ay - 360
10850 ENDIF
10860 IF az > 359 THEN
10870 az = az - 360
10880 ENDIF
10890 LOOP
As you can see i record the sinus and cosines in a array to not recompute them
every cycle.
For get the points and faces from the meshes i just have made a little VB6
converter to get a basic file code from a ASCII STL file.
At end i just merge the points/faces file to the base 3D program.
Enjoy.
Edited by darthmite 2011-11-27
darthmite
Posted: 07:05pm 25 Nov 2011
Here is the 3D Ball test part 1 source code.
11 DATA 223,113
13 DATA 3.6,1.5,-9.2
14 DATA 3.9,0.0,-9.2
15 DATA 0.0,0.0,-10.0
16 DATA 6.5,2.7,-7.1
17 DATA 7.0,0.0,-7.1
18 DATA 8.4,3.5,-4.1
19 DATA 9.1,0.0,-4.1
20 DATA 9.2,3.9,0.0
21 DATA 10.0,0.0,0.0
22 DATA 8.5,3.6,3.9
23 DATA 9.2,0.0,3.9
24 DATA 6.6,2.8,7.0
25 DATA 7.1,0.0,7.0
26 DATA 3.7,1.6,9.1
27 DATA 4.1,0.0,9.1
28 DATA 0.0,0.0,10.0
29 DATA 2.8,2.7,-9.2
30 DATA 5.0,5.0,-7.1
31 DATA 6.5,6.4,-4.1
32 DATA 7.1,7.0,0.0
33 DATA 6.6,6.5,3.9
34 DATA 5.0,5.0,7.0
35 DATA 2.9,2.9,9.1
36 DATA 1.6,3.5,-9.2
37 DATA 2.9,6.4,-7.1
38 DATA 3.7,8.4,-4.1
39 DATA 4.1,9.1,0.0
40 DATA 3.7,8.4,3.9
41 DATA 2.9,6.5,7.0
42 DATA 1.6,3.7,9.1
43 DATA 0.0,3.9,-9.2
44 DATA 0.0,7.0,-7.1
45 DATA 0.0,9.1,-4.1
46 DATA 0.0,10.0,0.0
47 DATA 0.0,9.2,3.9
48 DATA 0.0,7.1,7.0
49 DATA 0.0,4.1,9.1
50 DATA -1.5,3.6,-9.2
51 DATA -2.7,6.5,-7.1
52 DATA -3.5,8.4,-4.1
53 DATA -3.9,9.2,0.0
54 DATA -3.6,8.5,3.9
55 DATA -2.8,6.6,7.0
56 DATA -1.6,3.7,9.1
57 DATA -2.7,2.8,-9.2
58 DATA -5.0,5.0,-7.1
59 DATA -6.4,6.5,-4.1
60 DATA -7.0,7.1,0.0
61 DATA -6.5,6.6,3.9
62 DATA -5.0,5.0,7.0
63 DATA -2.9,2.9,9.1
64 DATA -3.5,1.6,-9.2
65 DATA -6.4,2.9,-7.1
66 DATA -8.4,3.7,-4.1
67 DATA -9.1,4.1,0.0
68 DATA -8.4,3.7,3.9
69 DATA -6.5,2.9,7.0
70 DATA -3.7,1.6,9.1
71 DATA -3.9,0.0,-9.2
72 DATA -7.0,0.0,-7.1
73 DATA -9.1,0.0,-4.1
74 DATA -10.0,0.0,0.0
75 DATA -9.2,0.0,3.9
76 DATA -7.1,0.0,7.0
77 DATA -4.1,0.0,9.1
78 DATA -3.6,-1.5,-9.2
79 DATA -6.5,-2.7,-7.1
80 DATA -8.4,-3.5,-4.1
81 DATA -9.2,-3.9,0.0
82 DATA -8.5,-3.6,3.9
83 DATA -6.6,-2.8,7.0
84 DATA -3.7,-1.6,9.1
85 DATA -2.8,-2.7,-9.2
86 DATA -5.0,-5.0,-7.1
87 DATA -6.5,-6.4,-4.1
88 DATA -7.1,-7.0,0.0
89 DATA -6.6,-6.5,3.9
90 DATA -5.0,-5.0,7.0
91 DATA -2.9,-2.9,9.1
92 DATA -1.6,-3.5,-9.2
93 DATA -2.9,-6.4,-7.1
94 DATA -3.7,-8.4,-4.1
95 DATA -4.1,-9.1,0.0
96 DATA -3.7,-8.4,3.9
97 DATA -2.9,-6.5,7.0
98 DATA -1.6,-3.7,9.1
99 DATA 0.0,-3.9,-9.2
100 DATA 0.0,-7.0,-7.1
101 DATA 0.0,-9.1,-4.1
102 DATA 0.0,-10.0,0.0
103 DATA 0.0,-9.2,3.9
104 DATA 0.0,-7.1,7.0
105 DATA 0.0,-4.1,9.1
106 DATA 1.5,-3.6,-9.2
107 DATA 2.7,-6.5,-7.1
108 DATA 3.5,-8.4,-4.1
109 DATA 3.9,-9.2,0.0
110 DATA 3.6,-8.5,3.9
111 DATA 2.8,-6.6,7.0
112 DATA 1.6,-3.7,9.1
113 DATA 2.7,-2.8,-9.2
114 DATA 5.0,-5.0,-7.1
115 DATA 6.4,-6.5,-4.1
116 DATA 7.0,-7.1,0.0
117 DATA 6.5,-6.6,3.9
118 DATA 5.0,-5.0,7.0
119 DATA 2.9,-2.9,9.1
120 DATA 3.5,-1.6,-9.2
121 DATA 6.4,-2.9,-7.1
122 DATA 8.4,-3.7,-4.1
123 DATA 9.1,-4.1,0.0
124 DATA 8.4,-3.7,3.9
125 DATA 6.5,-2.9,7.0
126 DATA 3.7,-1.6,9.1
127 'Faces from the 3D Object
128 DATA 0,1,2
129 DATA 3,4,1
130 DATA 3,1,0
131 DATA 5,6,4
132 DATA 5,4,3
133 DATA 7,8,6
134 DATA 7,6,5
135 DATA 9,10,8
136 DATA 9,8,7
137 DATA 11,12,10
138 DATA 11,10,9
139 DATA 13,14,12
140 DATA 13,12,11
141 DATA 15,14,13
142 DATA 16,0,2
143 DATA 17,3,0
144 DATA 17,0,16
145 DATA 18,5,3
146 DATA 18,3,17
147 DATA 19,7,5
148 DATA 19,5,18
149 DATA 20,9,7
150 DATA 20,7,19
151 DATA 21,11,9
152 DATA 21,9,20
153 DATA 22,13,11
154 DATA 22,11,21
155 DATA 15,13,22
156 DATA 23,16,2
157 DATA 24,17,16
158 DATA 24,16,23
159 DATA 25,18,17
160 DATA 25,17,24
161 DATA 26,19,18
162 DATA 26,18,25
163 DATA 27,20,19
164 DATA 27,19,26
165 DATA 28,21,20
166 DATA 28,20,27
167 DATA 29,22,21
168 DATA 29,21,28
169 DATA 15,22,29
170 DATA 30,23,2
171 DATA 31,24,23
172 DATA 31,23,30
173 DATA 32,25,24
174 DATA 32,24,31
175 DATA 33,26,25
176 DATA 33,25,32
177 DATA 34,27,26
178 DATA 34,26,33
179 DATA 35,28,27
180 DATA 35,27,34
181 DATA 36,29,28
182 DATA 36,28,35
183 DATA 15,29,36
184 DATA 37,30,2
185 DATA 38,31,30
186 DATA 38,30,37
187 DATA 39,32,31
188 DATA 39,31,38
189 DATA 40,33,32
190 DATA 40,32,39
191 DATA 41,34,33
192 DATA 41,33,40
193 DATA 42,35,34
194 DATA 42,34,41
195 DATA 43,36,35
196 DATA 43,35,42
197 DATA 15,36,43
198 DATA 44,37,2
199 DATA 45,38,37
200 DATA 45,37,44
201 DATA 46,39,38
202 DATA 46,38,45
203 DATA 47,40,39
204 DATA 47,39,46
205 DATA 48,41,40
206 DATA 48,40,47
207 DATA 49,42,41
208 DATA 49,41,48
209 DATA 50,43,42
210 DATA 50,42,49
211 DATA 15,43,50
212 DATA 51,44,2
213 DATA 52,45,44
214 DATA 52,44,51
215 DATA 53,46,45
216 DATA 53,45,52
217 DATA 54,47,46
218 DATA 54,46,53
219 DATA 55,48,47
220 DATA 55,47,54
221 DATA 56,49,48
222 DATA 56,48,55
223 DATA 57,50,49
224 DATA 57,49,56
225 DATA 15,50,57
226 DATA 58,51,2
227 DATA 59,52,51
228 DATA 59,51,58
229 DATA 60,53,52
230 DATA 60,52,59
231 DATA 61,54,53
232 DATA 61,53,60
233 DATA 62,55,54
234 DATA 62,54,61
235 DATA 63,56,55
236 DATA 63,55,62
237 DATA 64,57,56
238 DATA 64,56,63
239 DATA 15,57,64
240 DATA 65,58,2
241 DATA 66,59,58
242 DATA 66,58,65
243 DATA 67,60,59
244 DATA 67,59,66
245 DATA 68,61,60
246 DATA 68,60,67
247 DATA 69,62,61
248 DATA 69,61,68
249 DATA 70,63,62
250 DATA 70,62,69
251 DATA 71,64,63
252 DATA 71,63,70
253 DATA 15,64,71
254 DATA 72,65,2
255 DATA 73,66,65
256 DATA 73,65,72
257 DATA 74,67,66
258 DATA 74,66,73
259 DATA 75,68,67
260 DATA 75,67,74
261 DATA 76,69,68
262 DATA 76,68,75
263 DATA 77,70,69
264 DATA 77,69,76
265 DATA 78,71,70
266 DATA 78,70,77
267 DATA 15,71,78
268 DATA 79,72,2
269 DATA 80,73,72
270 DATA 80,72,79
271 DATA 81,74,73
272 DATA 81,73,80
273 DATA 82,75,74
274 DATA 82,74,81
275 DATA 83,76,75
276 DATA 83,75,82
277 DATA 84,77,76
278 DATA 84,76,83
279 DATA 85,78,77
280 DATA 85,77,84
281 DATA 15,78,85
282 DATA 86,79,2
283 DATA 87,80,79
284 DATA 87,79,86
285 DATA 88,81,80
286 DATA 88,80,87
287 DATA 89,82,81
288 DATA 89,81,88
289 DATA 90,83,82
290 DATA 90,82,89
291 DATA 91,84,83
292 DATA 91,83,90
293 DATA 92,85,84
294 DATA 92,84,91
295 DATA 15,85,92
296 DATA 93,86,2
297 DATA 94,87,86
298 DATA 94,86,93
299 DATA 95,88,87
300 DATA 95,87,94
301 DATA 96,89,88
302 DATA 96,88,95
303 DATA 97,90,89
304 DATA 97,89,96
305 DATA 98,91,90
306 DATA 98,90,97
307 DATA 99,92,91
308 DATA 99,91,98
309 DATA 15,92,99
310 DATA 100,93,2
311 DATA 101,94,93
312 DATA 101,93,100
313 DATA 102,95,94
314 DATA 102,94,101
315 DATA 103,96,95
316 DATA 103,95,102
317 DATA 104,97,96
318 DATA 104,96,103
319 DATA 105,98,97
320 DATA 105,97,104
321 DATA 106,99,98
322 DATA 106,98,105
323 DATA 15,99,106
324 DATA 107,100,2
325 DATA 108,101,100
326 DATA 108,100,107
327 DATA 109,102,101
328 DATA 109,101,108
329 DATA 110,103,102
330 DATA 110,102,109
331 DATA 111,104,103
332 DATA 111,103,110
333 DATA 112,105,104
334 DATA 112,104,111
335 DATA 113,106,105
336 DATA 113,105,112
337 DATA 15,106,113
338 DATA 1,107,2
339 DATA 4,108,107
340 DATA 4,107,1
341 DATA 6,109,108
342 DATA 6,108,4
343 DATA 8,110,109
344 DATA 8,109,6
345 DATA 10,111,110
346 DATA 10,110,8
347 DATA 12,112,111
348 DATA 12,111,10
349 DATA 14,113,112
350 DATA 14,112,12
351 DATA 15,113,14
10000 OPTION base 0
10010 CLEAR
10020 CLS
10030 DIM sinx(360)
10040 DIM cosx(360)
10060 RESTORE
10070 READ nbface
10080 READ nbpoint
10200 NEXT a
10240 NEXT a
10290 NEXT b
10300 NEXT a
10320 ax = 45
10330 ay = 20
10340 az = 0
10360 zoom = 5
10370 'Cube Center
10380 dx = 152
10390 dy = 108
10410 DO WHILE 1
10420 sx = sinx(ax)
10430 sy = sinx(ay)
10440 sz = sinx(az)
10450 cx = cosx(ax)
10460 cy = cosx(ay)
10470 cz = cosx(az)
10490 tx = px(i)
10500 ty = py(i)
10510 tz = pz(i)
10560 ty = y
10570 tz = z
10610 tx = x
10620 ty = y
10690 NEXT i
10710 CLS
10750 NEXT i
10770 ax = ax + 3
10780 ay = ay + 3
10790 az = az + 3
10810 ax = ax - 360
10820 ENDIF
10840 ay = ay - 360
10850 ENDIF
10870 az = az - 360
10880 ENDIF
10890 LOOP
darthmite
Posted: 07:07pm 25 Nov 2011
3D Ball Test part 2
174 DATA 32,24,31
175 DATA 33,26,25
176 DATA 33,25,32
177 DATA 34,27,26
178 DATA 34,26,33
179 DATA 35,28,27
180 DATA 35,27,34
181 DATA 36,29,28
182 DATA 36,28,35
183 DATA 15,29,36
184 DATA 37,30,2
185 DATA 38,31,30
186 DATA 38,30,37
187 DATA 39,32,31
188 DATA 39,31,38
189 DATA 40,33,32
190 DATA 40,32,39
191 DATA 41,34,33
192 DATA 41,33,40
193 DATA 42,35,34
194 DATA 42,34,41
195 DATA 43,36,35
196 DATA 43,35,42
197 DATA 15,36,43
198 DATA 44,37,2
199 DATA 45,38,37
200 DATA 45,37,44
201 DATA 46,39,38
202 DATA 46,38,45
203 DATA 47,40,39
204 DATA 47,39,46
205 DATA 48,41,40
206 DATA 48,40,47
207 DATA 49,42,41
208 DATA 49,41,48
209 DATA 50,43,42
210 DATA 50,42,49
211 DATA 15,43,50
212 DATA 51,44,2
213 DATA 52,45,44
214 DATA 52,44,51
215 DATA 53,46,45
216 DATA 53,45,52
217 DATA 54,47,46
218 DATA 54,46,53
219 DATA 55,48,47
220 DATA 55,47,54
221 DATA 56,49,48
222 DATA 56,48,55
223 DATA 57,50,49
224 DATA 57,49,56
225 DATA 15,50,57
226 DATA 58,51,2
227 DATA 59,52,51
228 DATA 59,51,58
229 DATA 60,53,52
230 DATA 60,52,59
231 DATA 61,54,53
232 DATA 61,53,60
233 DATA 62,55,54
234 DATA 62,54,61
235 DATA 63,56,55
236 DATA 63,55,62
237 DATA 64,57,56
238 DATA 64,56,63
239 DATA 15,57,64
240 DATA 65,58,2
241 DATA 66,59,58
242 DATA 66,58,65
243 DATA 67,60,59
244 DATA 67,59,66
245 DATA 68,61,60
246 DATA 68,60,67
247 DATA 69,62,61
248 DATA 69,61,68
249 DATA 70,63,62
250 DATA 70,62,69
251 DATA 71,64,63
252 DATA 71,63,70
253 DATA 15,64,71
254 DATA 72,65,2
255 DATA 73,66,65
256 DATA 73,65,72
257 DATA 74,67,66
258 DATA 74,66,73
259 DATA 75,68,67
260 DATA 75,67,74
261 DATA 76,69,68
262 DATA 76,68,75
263 DATA 77,70,69
264 DATA 77,69,76
265 DATA 78,71,70
266 DATA 78,70,77
267 DATA 15,71,78
268 DATA 79,72,2
269 DATA 80,73,72
270 DATA 80,72,79
271 DATA 81,74,73
272 DATA 81,73,80
273 DATA 82,75,74
274 DATA 82,74,81
275 DATA 83,76,75
276 DATA 83,75,82
277 DATA 84,77,76
278 DATA 84,76,83
279 DATA 85,78,77
280 DATA 85,77,84
281 DATA 15,78,85
282 DATA 86,79,2
283 DATA 87,80,79
284 DATA 87,79,86
285 DATA 88,81,80
286 DATA 88,80,87
287 DATA 89,82,81
288 DATA 89,81,88
289 DATA 90,83,82
290 DATA 90,82,89
291 DATA 91,84,83
292 DATA 91,83,90
293 DATA 92,85,84
294 DATA 92,84,91
295 DATA 15,85,92
296 DATA 93,86,2
297 DATA 94,87,86
298 DATA 94,86,93
299 DATA 95,88,87
300 DATA 95,87,94
301 DATA 96,89,88
302 DATA 96,88,95
303 DATA 97,90,89
304 DATA 97,89,96
305 DATA 98,91,90
306 DATA 98,90,97
307 DATA 99,92,91
308 DATA 99,91,98
309 DATA 15,92,99
310 DATA 100,93,2
311 DATA 101,94,93
312 DATA 101,93,100
313 DATA 102,95,94
314 DATA 102,94,101
315 DATA 103,96,95
316 DATA 103,95,102
317 DATA 104,97,96
318 DATA 104,96,103
319 DATA 105,98,97
320 DATA 105,97,104
321 DATA 106,99,98
322 DATA 106,98,105
323 DATA 15,99,106
324 DATA 107,100,2
337 DATA 15,106,113
338 DATA 1,107,2
339 DATA 4,108,107
340 DATA 4,107,1
341 DATA 6,109,108
342 DATA 6,108,4
343 DATA 8,110,109
344 DATA 8,109,6
345 DATA 10,111,110
346 DATA 10,110,8
347 DATA 12,112,111
348 DATA 12,111,10
349 DATA 14,113,112
350 DATA 14,112,12
351 DATA 15,113,14
10000 OPTION base 0
10010 CLEAR
10020 CLS
10030 DIM sinx(360)
10040 DIM cosx(360)
10060 RESTORE
10070 READ nbface
10080 READ nbpoint
10200 NEXT a
10240 NEXT a
10290 NEXT b
10300 NEXT a
10320 ax = 45
10330 ay = 20
10340 az = 0
10360 zoom = 5
10370 'Cube Center
10380 dx = 152
10390 dy = 108
10410 DO WHILE 1
10420 sx = sinx(ax)
10430 sy = sinx(ay)
10440 sz = sinx(az)
10450 cx = cosx(ax)
10460 cy = cosx(ay)
10470 cz = cosx(az)
10490 tx = px(i)
10500 ty = py(i)
10510 tz = pz(i)
10560 ty = y
10570 tz = z
10610 tx = x
10620 ty = y
10690 NEXT i
10710 CLS
10750 NEXT i
10770 ax = ax + 3
10780 ay = ay + 3
10790 az = az + 3
10810 ax = ax - 360
10820 ENDIF
10840 ay = ay - 360
10850 ENDIF
10870 az = az - 360
10880 ENDIF
10890 LOOP
darthmite
Posted: 07:09pm 25 Nov 2011
3D Ball Test part 3
338 DATA 1,107,2
339 DATA 4,108,107
340 DATA 4,107,1
341 DATA 6,109,108
342 DATA 6,108,4
343 DATA 8,110,109
344 DATA 8,109,6
345 DATA 10,111,110
346 DATA 10,110,8
347 DATA 12,112,111
348 DATA 12,111,10
349 DATA 14,113,112
350 DATA 14,112,12
351 DATA 15,113,14
10000 OPTION base 0
10010 CLEAR
10020 CLS
10030 DIM sinx(360)
10040 DIM cosx(360)
10060 RESTORE
10070 READ nbface
10080 READ nbpoint
10200 NEXT a
10240 NEXT a
10250 'Record the Faces from the 3D Meshe
10290 NEXT b
10300 NEXT a
10320 ax = 45
10330 ay = 20
10340 az = 0
10360 zoom = 5
10370 'Cube Center
10380 dx = 152
10390 dy = 108
10410 DO WHILE 1
10420 sx = sinx(ax)
10430 sy = sinx(ay)
10440 sz = sinx(az)
10450 cx = cosx(ax)
10460 cy = cosx(ay)
10470 cz = cosx(az)
10490 tx = px(i)
10500 ty = py(i)
10510 tz = pz(i)
10520 '
10560 ty = y
10570 tz = z
10610 tx = x
10620 ty = y
10690 NEXT i
10700 'Erase the old meshe and trace the new one
10710 CLS
10750 NEXT i
10770 ax = ax + 3
10780 ay = ay + 3
10790 az = az + 3
10810 ax = ax - 360
10820 ENDIF
10840 ay = ay - 360
10850 ENDIF
10870 az = az - 360
10880 ENDIF
10890 LOOP
crackerjack
Posted: 08:39pm 25 Nov 2011
Hey Thanks. This is really cool stuff. I'll be trying it out soon as I'd like to try incorporate it with the Wii Nunchuck controllers I have coming in the mail.
Cheers!
Posted: 10:26pm 25 Nov 2011
Hey Darthmite,
Pretty cool (well sounds it),
I am going to have to find a VGA monitor to give it a go...
Welcome to `the shed' I havent seen your posts before
PS.
Anyone know why the back shed screen is now 3 times wider than my actual screen (PC)?
Mik
Edited by bigmik 2011-11-27
Posted: 11:04pm 25 Nov 2011
Hi Darthmite
The first two work perfectly, most impressed by the first one. Reminds me of the days when I played around with 3D blocks on my Microbee, though the Maximite is a bucket load faster.
The 3rd and 4th listings dont run, 3rd one has a Index out of bounts error on line 10730, and the 4th one has a No more data to read error line 10230
I also noticed where the 1st and 2nd listing start at line 10, the last two start at line 173 and 338. Could the first few lines have gone missing in action when you pasted the code?
Posted: 11:09pm 25 Nov 2011
  Gizmo said   Hi Darthmite
Hi Glenn,
I think all of the 3 parts have to be added together to make 1 file for the 3d ball...
It must have been as the listing is quite long
Mik
darthmite
Posted: 11:43pm 25 Nov 2011
Hi ,
@Gizmo ,like bigmik said , you have to add all 3 parts in one file.
I was not able to paste the complete listing in only one post ... we are probably
limited in post length due to spam.
Cheer.
Posted: 01:20am 26 Nov 2011
  Quote  I was not able to paste the complete listing in only one post ... we are probably
You know I've had a few members say that and I cant work it out. I thought it was a bug in the forum software or something, but as a test I've managed to post entire book chapters into a single post and it accepts it.
Could someone give me some more information on this? How are you told there is a limit on th epost size, does the forum give you a message, or does the keyboard stop responding, or is part of the post missing after you post it? Also, if you do see the post limit condition, what browser are you using. I need a few clues, or a way to replicate the condition. Any help would be appreciated.
Bill.b
Posted: 04:50am 26 Nov 2011
Hi Glen
The forum posted a message saying You have exeeded 20,000 characters, I am not shaw of the exact number indicated as it was some time ago that i possed a long entry.
this message appeared in a seperate window when I selected post reply.
Posted: 06:18am 26 Nov 2011
Thanks Bill, need some more clues though, anyone.
camfab
Posted: 06:25am 26 Nov 2011
ignore this folks, i was just trying a large post to help out, then found i couldnt delete it! can posts be deleted with the edit tool?Edited by camfab 2011-11-27
Fre Sprky
Posted: 08:12am 26 Nov 2011
I think so. I'll clean up the thread once we're done anyway. I know this is all a bit off topic but I really need to sort this bug.
If I can get the exact wording of the message, I can search for it in the software code.
GlennEdited by Gizmo 2011-11-27
darthmite
Posted: 10:00am 26 Nov 2011
Hi ,
Here when i have copy/paste the source code everything was OK.
Then when i push 'Post Reply' , everything was OK too
But ... when i have look the result on forum i have see that the code was
not complete and i just have copy/paste the rest in the 2 other part
of my post.
For the 3rd part of the source i get a message that i have to wait because
of spam.
I was probably a little too fast for my 3rd post , it was OK after 1min
waiting and reposting.
Cheer.
darthmite
Posted: 11:50am 26 Nov 2011
Heya
So , i worked a little on my STL/PLY to Basic converter ...
Now i cut the points/faces Basic line when they are > 100 chars.
Its allot shorter now
By the way i have add the back face algorithm to remove the back-face
from the 3D Meshes when we show it on the screen.
It's not perfect but it work :)
Here are the source for the Cube and the Ball.
I will post the Converter later when i have removed some bugs.
the 3D Cube source :
10'Number of Faces and Number of Points
11 data 35,19
12'Points from the 3D Object
13 data -10.0,-10.0,-10.0,0.0,-10.0,-10.0,-10.0,-10.0,0.0,10.0,-10.0 ,-10.0,10.0,-10.0,0.0,10.0,-10.0,10.0
14 data 0.0,-10.0,10.0,-10.0,-10.0,10.0,10.0,0.0,-10.0,10.0,10.0,-10 .0,10.0,10.0,0.0,10.0,10.0,10.0,10.0,0.0,10.0
15 data 0.0,10.0,-10.0,-10.0,10.0,-10.0,-10.0,10.0,0.0,-10.0,10.0,10 .0,0.0,10.0,10.0,-10.0,0.0,-10.0,-10.0,0.0,10.0
16'Faces from the 3D Object
17 data 0,1,2,1,3,4,5,6,4,6,7,2,2,1,6,1,4,6,3,8,4,8,9,10,11,12,10,12 ,5,4,4,8,12,8,10,12,9,13,10,13,14,15
18 data 16,17,15,17,11,10,10,13,17,13,15,17,14,18,15,18,0,2,7,19,2,1 9,16,15,15,18,19,18,2,19,3,1,8,1,0,18
19 data 9,8,13,14,13,18,8,1,13,1,18,13,7,6,19,6,5,12,12,11,17,17,16, 19,19,6,17,6,12,17
20000 OPTION base 0
20010 CLEAR
20020 CLS
20030 DIM sinx(360)
20040 DIM cosx(360)
20050 'We get the number of points and faces
20060 RESTORE
20070 READ nbface
20080 READ nbpoint
20090 DIM px(NbPoint)
20100 DIM py(NbPoint)
20110 DIM pz(NbPoint)
20120 DIM face(NbFace,3)
20130 DIM bFace(NbFace,3)
20140 DIM nx(NbPoint)
20150 DIM ny(NbPoint)
20160 deg = 3.14159 / 180
20170 'Record the sinus and cosinus table
20180 FOR a = 0 TO 359
20190 sinx(a) = SIN(a*deg)
20200 cosx(a) = COS(a*deg)
20210 NEXT a
20220 'Read the points from the 3D Meshes
20230 FOR a = 0 TO NbPoint
20240 READ px(a),py(a),pz(a)
20250 NEXT a
20260 'Read the Faces from the 3D Meshes
20270 FOR a = 0 TO NbFace
20280 FOR b = 0 TO 2
20290 READ face(a,b)
20300 NEXT b
20310 NEXT a
20320 'Starting Angles
20330 ax = 45
20340 ay = 20
20350 az = 0
20360 'Zoom on the 3D Cube
20370 zoom = 5
20380 'Cube Center
20390 dx = 152
20400 dy = 108
20410 'Rotate the 3D Cube
20420 DO WHILE 1
20430 sx = sinx(ax)
20440 sy = sinx(ay)
20450 sz = sinx(az)
20460 cx = cosx(ax)
20470 cy = cosx(ay)
20480 cz = cosx(az)
20490 FOR i = 0 TO NbPoint
20500 tx = px(i)
20510 ty = py(i)
20520 tz = pz(i)
20530 '
20540 'Rotate on X axis
20550 y = ty * cx - tz * sx
20560 z = ty * sx + tz * cx
20570 ty = y
20580 tz = z
20590 'Rotate on Z axis
20600 x = tx * cz - ty * sz
20610 y = tx * sz + ty * cz
20620 tx = x
20630 ty = y
20640 'Rotate on Y axis
20650 x = tx * cy - tz * sy
20660 z = tx * sy + tz * cy
20670 'Save the screen points coordinates
20680 nx(i) = INT(x * zoom + dx)
20690 ny(i) = INT(y * zoom + dy)
20700 NEXT i
20710 'We go compute the BackFace
20720 NbVisible = -1
20730 FOR i = 0 TO NbFace
20740 pts1x = nx(face(i,0))
20750 pts1y = ny(face(i,0))
20760 pts2x = nx(face(i,1))
20770 pts2y = ny(face(i,1))
20780 pts3x = nx(face(i,2))
20790 pts3y = ny(face(i,2))
20800 Nvector1 = (((pts1x / 100) - (pts2x / 100)) * ((pts3y / 100) - (pts2y / 100)))
20810 Nvector2 = (((pts3x / 100) - (pts2x / 100)) * ((pts1y / 100) - (pts2y / 100)))
20820 IF (nvector1 - nvector2) >= 0 THEN
20830 NbVisible = NbVisible + 1
20840 bFace(NbVisible,0) = face(i,0)
20850 bFace(NbVisible,1) = face(i,1)
20860 bFace(NbVisible,2) = face(i,2)
20870 ENDIF
20880 NEXT i
20890 'Erase the old Meshes and trace the new one
20900 CLS
20910 FOR i = 0 TO NbVisible
20920 LINE(nx(bFace(i,0)),ny(bFace(i,0)))-(nx(bFace(i,1)),ny(bFace (i,1))),1
20930 LINE(nx(bFace(i,1)),ny(bFace(i,1)))-(nx(bFace(i,2)),ny(bFace (i,2))),1
20940 NEXT i
20950 'Increment all angles
20960 ax = ax + 3
20970 ay = ay + 3
20980 az = az + 3
20990 IF ax>359 THEN
21000 ax = ax - 360
21010 ENDIF
21020 IF ay>359 THEN
21030 ay = ay - 360
21040 ENDIF
21050 IF az > 359 THEN
21060 az = az - 360
21070 ENDIF
21080 LOOP
darthmite
Posted: 11:51am 26 Nov 2011
And here the 3D Ball source :
11 data 223,113
13 data 3.6,1.5,-9.2,3.9,0.0,-9.2,0.0,0.0,-10.0,6.5,2.7,-7.1,7.0,0.0 ,-7.1,8.4,3.5,-4.1,9.1,0.0,-4.1,9.2,3.9,0.0
14 data 10.0,0.0,0.0,8.5,3.6,3.9,9.2,0.0,3.9,6.6,2.8,7.0,7.1,0.0,7.0 ,3.7,1.6,9.1,4.1,0.0,9.1,0.0,0.0,10.0
15 data 2.8,2.7,-9.2,5.0,5.0,-7.1,6.5,6.4,-4.1,7.1,7.0,0.0,6.6,6.5,3 .9,5.0,5.0,7.0,2.9,2.9,9.1,1.6,3.5,-9.2
16 data 2.9,6.4,-7.1,3.7,8.4,-4.1,4.1,9.1,0.0,3.7,8.4,3.9,2.9,6.5,7. 0,1.6,3.7,9.1,0.0,3.9,-9.2,0.0,7.0,-7.1
17 data 0.0,9.1,-4.1,0.0,10.0,0.0,0.0,9.2,3.9,0.0,7.1,7.0,0.0,4.1,9. 1,-1.5,3.6,-9.2,-2.7,6.5,-7.1,-3.5,8.4,-4.1
18 data -3.9,9.2,0.0,-3.6,8.5,3.9,-2.8,6.6,7.0,-1.6,3.7,9.1,-2.7,2.8 ,-9.2,-5.0,5.0,-7.1,-6.4,6.5,-4.1
19 data -7.0,7.1,0.0,-6.5,6.6,3.9,-5.0,5.0,7.0,-2.9,2.9,9.1,-3.5,1.6 ,-9.2,-6.4,2.9,-7.1,-8.4,3.7,-4.1
20 data -9.1,4.1,0.0,-8.4,3.7,3.9,-6.5,2.9,7.0,-3.7,1.6,9.1,-3.9,0.0 ,-9.2,-7.0,0.0,-7.1,-9.1,0.0,-4.1
21 data -10.0,0.0,0.0,-9.2,0.0,3.9,-7.1,0.0,7.0,-4.1,0.0,9.1,-3.6,-1 .5,-9.2,-6.5,-2.7,-7.1,-8.4,-3.5,-4.1
22 data -9.2,-3.9,0.0,-8.5,-3.6,3.9,-6.6,-2.8,7.0,-3.7,-1.6,9.1,-2.8 ,-2.7,-9.2,-5.0,-5.0,-7.1,-6.5,-6.4,-4.1
23 data -7.1,-7.0,0.0,-6.6,-6.5,3.9,-5.0,-5.0,7.0,-2.9,-2.9,9.1,-1.6 ,-3.5,-9.2,-2.9,-6.4,-7.1,-3.7,-8.4,-4.1
24 data -4.1,-9.1,0.0,-3.7,-8.4,3.9,-2.9,-6.5,7.0,-1.6,-3.7,9.1,0.0, -3.9,-9.2,0.0,-7.0,-7.1,0.0,-9.1,-4.1
25 data 0.0,-10.0,0.0,0.0,-9.2,3.9,0.0,-7.1,7.0,0.0,-4.1,9.1,1.5,-3. 6,-9.2,2.7,-6.5,-7.1,3.5,-8.4,-4.1
26 data 3.9,-9.2,0.0,3.6,-8.5,3.9,2.8,-6.6,7.0,1.6,-3.7,9.1,2.7,-2.8 ,-9.2,5.0,-5.0,-7.1,6.4,-6.5,-4.1
27 data 7.0,-7.1,0.0,6.5,-6.6,3.9,5.0,-5.0,7.0,2.9,-2.9,9.1,3.5,-1.6 ,-9.2,6.4,-2.9,-7.1,8.4,-3.7,-4.1
28 data 9.1,-4.1,0.0,8.4,-3.7,3.9,6.5,-2.9,7.0,3.7,-1.6,9.1
29'Faces from the 3D Object
30 data 0,1,2,3,4,1,3,1,0,5,6,4,5,4,3,7,8,6,7,6,5,9,10,8,9,8,7,11,12 ,10,11,10,9,13,14,12,13,12,11,15,14,13
31 data 16,0,2,17,3,0,17,0,16,18,5,3,18,3,17,19,7,5,19,5,18,20,9,7,2 0,7,19,21,11,9,21,9,20,22,13,11,22,11,21
32 data 15,13,22,23,16,2,24,17,16,24,16,23,25,18,17,25,17,24,26,19,1 8,26,18,25,27,20,19,27,19,26,28,21,20
33 data 28,20,27,29,22,21,29,21,28,15,22,29,30,23,2,31,24,23,31,23,3 0,32,25,24,32,24,31,33,26,25,33,25,32
34 data 34,27,26,34,26,33,35,28,27,35,27,34,36,29,28,36,28,35,15,29, 36,37,30,2,38,31,30,38,30,37,39,32,31
35 data 39,31,38,40,33,32,40,32,39,41,34,33,41,33,40,42,35,34,42,34, 41,43,36,35,43,35,42,15,36,43,44,37,2
36 data 45,38,37,45,37,44,46,39,38,46,38,45,47,40,39,47,39,46,48,41, 40,48,40,47,49,42,41,49,41,48,50,43,42
37 data 50,42,49,15,43,50,51,44,2,52,45,44,52,44,51,53,46,45,53,45,5 2,54,47,46,54,46,53,55,48,47,55,47,54
38 data 56,49,48,56,48,55,57,50,49,57,49,56,15,50,57,58,51,2,59,52,5 1,59,51,58,60,53,52,60,52,59,61,54,53
39 data 61,53,60,62,55,54,62,54,61,63,56,55,63,55,62,64,57,56,64,56, 63,15,57,64,65,58,2,66,59,58,66,58,65
40 data 67,60,59,67,59,66,68,61,60,68,60,67,69,62,61,69,61,68,70,63, 62,70,62,69,71,64,63,71,63,70,15,64,71
41 data 72,65,2,73,66,65,73,65,72,74,67,66,74,66,73,75,68,67,75,67,7 4,76,69,68,76,68,75,77,70,69,77,69,76
42 data 78,71,70,78,70,77,15,71,78,79,72,2,80,73,72,80,72,79,81,74,7 3,81,73,80,82,75,74,82,74,81,83,76,75
43 data 83,75,82,84,77,76,84,76,83,85,78,77,85,77,84,15,78,85,86,79, 2,87,80,79,87,79,86,88,81,80,88,80,87
44 data 89,82,81,89,81,88,90,83,82,90,82,89,91,84,83,91,83,90,92,85, 84,92,84,91,15,85,92,93,86,2,94,87,86
45 data 94,86,93,95,88,87,95,87,94,96,89,88,96,88,95,97,90,89,97,89, 96,98,91,90,98,90,97,99,92,91,99,91,98
46 data 15,92,99,100,93,2,101,94,93,101,93,100,102,95,94,102,94,101, 103,96,95,103,95,102,104,97,96,104,96,103
47 data 105,98,97,105,97,104,106,99,98,106,98,105,15,99,106,107,100, 2,108,101,100,108,100,107,109,102,101
48 data 109,101,108,110,103,102,110,102,109,111,104,103,111,103,110, 112,105,104,112,104,111,113,106,105
49 data 113,105,112,15,106,113,1,107,2,4,108,107,4,107,1,6,109,108,6 ,108,4,8,110,109,8,109,6,10,111,110
50 data 10,110,8,12,112,111,12,111,10,14,113,112,14,112,12,15,113,14
20000 OPTION base 0
20010 CLEAR
20020 CLS
20030 DIM sinx(360)
20040 DIM cosx(360)
20060 RESTORE
20070 READ nbface
20080 READ nbpoint
20210 NEXT a
20250 NEXT a
20300 NEXT b
20310 NEXT a
20330 ax = 45
20340 ay = 20
20350 az = 0
20370 zoom = 5
20380 'Cube Center
20390 dx = 152
20400 dy = 108
20420 DO WHILE 1
20430 sx = sinx(ax)
20440 sy = sinx(ay)
20450 sz = sinx(az)
20460 cx = cosx(ax)
20470 cy = cosx(ay)
20480 cz = cosx(az)
20500 tx = px(i)
20510 ty = py(i)
20520 tz = pz(i)
20530 '
20570 ty = y
20580 tz = z
20620 tx = x
20630 ty = y
20700 NEXT i
20870 ENDIF
20880 NEXT i
20900 CLS
20940 NEXT i
20960 ax = ax + 3
20970 ay = ay + 3
20980 az = az + 3
21000 ax = ax - 360
21010 ENDIF
21030 ay = ay - 360
21040 ENDIF
21060 az = az - 360
21070 ENDIF
21080 LOOP
elproducts
Posted: 03:00pm 26 Nov 2011
  darthmite said   Heya
The 3D is great but I'm more interested in your STL to BASIC converter.
Is this available and/or documented anywhere?
I've just started investigating 3D printing (Makerbot, Reprap, etc) and found some easy to use 3D CAD software that will produce an STL file.
I'd like to see if making a Maximite control a 2D or 3D printer could be done and your software seems like a key.
I'd like to know more about the STL format.
Do you have a good reference you could recommend?
www.elproducts.com
Vikingboy
Posted: 06:58pm 26 Nov 2011
Me too !
I am nearly completed my CNC machine and one of the uses for my maximite I was thinking of was as part of the control system for it (monitoring limit/home and other sub systems), I considered if it would be possible to have a standalone system running on the maximite with input of .stl/.DXF /Gcode files etc via the SDcard. Perhaps your code could make this a more reasonable possibility.
rgds,
Andrew
darthmite
Posted: 08:32pm 26 Nov 2011
I don't have get reference etc.. from the STL format i just have export a cube and a ball
from Rhino and have look how it show
I have do the same with the PLY format and here are the results.
Joined to this post the VB6 source and executable + all DLL required to run the soft.
I dev in VB6 on a virtualbox with XP , it's why i add all dll to be able to use the
soft into my Win7 x64
Enjoy.
2011-11-27_063206_STL_Mite.zip
