Forum Index : Microcontroller and PC projects : (DM MM) Key mapping for Function keys
Hi All, I wrote a little piece of code to test for various keys and their values as in 10 CLS: PRINT "press any key to get its value" 20 PRINT: PRINT: PRINT"KEY Value" 30 a$=INKEY$: IF a$="" THEN GOTO 30 40 PRINT a$;" ", ASC(a$) 50 GOTO 30 But F9 doesnt return anything and F11 returns 55 instead of what I believe should be 155..(according to the sequence of F keys) Regards Mick PS. This is using USB console. I havent tested PS2 yet . Mick Mick's uMite Stuff can be found >>> HERE (Kindly hosted by Dontronics) <<< |
What terminal program are you using? With Teraterm, I get the expected results F9 gives 153 F11 gives 155 Jim Maximite, MMBasic V2.7B VK7JH MMedit |
Hmm, Ok, I am using a DuinoMite 2.7 (based on Geoffs 2.7), I use TeraTerm so must have been a minor bug fixed in 2.7b. Thanks Mick Mick's uMite Stuff can be found >>> HERE (Kindly hosted by Dontronics) <<< |
No, nothing changed in that area. Geoff Graham - http://geoffg.net |
Hmm, Thanks Geoff, I will run that one by Ken, Unless TerraTerm has remapped those keys... I will check the settings and try Putty.. Hmm. Using Putty.. F9 -No response, also F11 no response so the F11 thing might be a TT setting. Still something for Ken I suspect. Regards, Mick Mick's uMite Stuff can be found >>> HERE (Kindly hosted by Dontronics) <<< |
donmck![]() Guru Joined: 09/06/2011 Location: AustraliaPosts: 1314 |
I use TeraTerm so must have been a minor bug fixed in 2.7b. No, nothing changed in that area. Hmm, Thanks Geoff, I will run that one by Ken, Unless TerraTerm has remapped those keys... I will check the settings and try Putty.. Hmm. Using Putty.. F9 -No response, also F11 no response so the F11 thing might be a TT setting. Still something for Ken I suspect. Regards, Mick Just checked MM V2.7a and 2.7b, OK in VGA mode Also checked DM V2.7a and it is OK in VGA mode Tried MM&DM from TT and I found F9 is OK, F11 = 55 More investigation needed with TT I think. Cheers Don... https://www.dontronics.com |
I just wrote a PC program to display the keyboard key codes. No routing through TT, no MMBasic stuff, just display the key code in a box. F11 and F12 display nothing. I think that the operating system grabs them first. Micromites and Maximites! - Beginning Maximite |
Bryan1![]() Guru Joined: 22/02/2006 Location: AustraliaPosts: 2099 |
G'day Guy's, I spent most of yesterday and last night getting all the commands finished on that help file and today I'll setup both the SM1 and the DM and test it out on the VGA. Just need to do a bit more tweaking then I'll release the code for people to have a play with it. Now I did try for while to try and map the F1 key so it would start up the file with no luck. Basically the main 'help file' is in a folder on the SD card called help. I do feel it would be a huge bonus for when a user wants to see the help file simply pressing F1 like on all computers will bring it up. Regards Bryan |
Just checked MM V2.7a and 2.7b, OK in VGA mode Also checked DM V2.7a and it is OK in VGA mode Tried MM&DM from TT and I found F9 is OK, F11 = 55 More investigation needed with TT I think. Cheers Don... Got closer to the bottom of it. In TT there is term setup >> term ID >> then a whole range of emulation modes. I tried every one of them, and although the returned code changed, it never gave the expected result. I also tried coding receive changes, but no joy. Then I saw that you can open a new window in "TEK" mode, and bingo, correct results. I didn't find out how to enlarge the small screen, and save the settings, but that is for another person, or another time. Cheers Don... https://www.dontronics.com |
