Forum Index : Microcontroller and PC projects : Linux Mint 12
elchucko![]() Regular Member Joined: 09/11/2011 Location: United StatesPosts: 86 |
Any Linux user that has their MM connected? Drivers available? Thank you |
| Olimex Senior Member Joined: 02/10/2011 Location: BulgariaPosts: 226 |
Hi, in our users manual is covered how to work in Linux with MM/DM |
I'm not on Mint but all the drivers needed were already there and probably are for Mint, too. Post what fails, if anything John |
Hi, When I plug in my usb cable the PC/Linux Mint does not recognize MM is there. I'll check user manual. Thank you |
The only reference I see in the user manual is a Windows driver that's needed. Since I'm new at Linux I don't know how to compare Linux and Windows for driver requirements. |
I see no reference to Linux in the MM user manual that's on Geoff's web site. :( |
You need the DuinoMite manual. Jim VK7JH MMedit |
elchucko, first check dmesg before and after you plug the board in. You should see it recognised. Then I guess you need to know more about the MM. (The DM works as expected.) I only have a DM. It appears as 1 of 2 devices: 1 when in bootloader mode another when not in that mode in case that helps. Generally Windows needs drivers but Linux commonly has them available already. Don't assume Linux behaves the same as Windows!! |
Now I'll really show my lack of knowledge. What is "dmesg"? I don't see any response from Linux when I plug the usb cable to the PC. Furthermore, what utility is available (such as Tera Term) to utilize the MM? Thank you |
try googling dmesg
http://en.wikipedia.org/wiki/Dmesg as it show lot of driver info you can type at command prompt "dmesg | grep tty* " before and after you plug your board in DM user manual is written how to use minicom |
