Forum Index : Microcontroller and PC projects : mini maximite
Can someone run me through how to load a program into the memory using XMODEM. The instructions in SC are a bit vague. My device is working OK as I get the greeting message but have tried using XMODEM RECEIVE ans SEND to no avail. I am using TERA TERM. PAUL. "It is better to be ignorant and ask a stupid question than to be plain Stupid and not ask at all" |
You could try to use MMIDE. You just click buttons to do it. MMIDE MMIDE is easy to use with the mini. Otherwise as I understand it you have a limited time from typing "XMODEM RECEIVE file.ext" until you get TeraTerm to send. Micromites and Maximites! - Beginning Maximite |
What version of MM Basic do you have? XMODEM is a new addition. XMODEM copies files too and from the file system, not program memory. Apart from needing to be quick to start, Tera Term works OK. It is much easier to use MMIDE or MMedit. Both applications handle the file transfer without too much pain. Try them both. Jim VK7JH MMedit |
