Forum Index : Microcontroller and PC projects : MM Edit update
I have released an update to MM Edit. The most obvious changes were to suit the changes in MM Basic V3 but I have retained compatibility with earlier versions and (I hope) MMBasic on Duinomite. You can still work with or without line numbers and convert between the two forms. For those who haven't tried MM Edit, it is a Windows application that lets you do your editing in the comfort of you own PC and relatively easily transfer file to and from the Maximite/Duinomite. MM Edit is available from: http://www.c-com.com.au/MMedit.htm Jim VK7JH MMedit |
| djuqa Guru Joined: 23/11/2011 Location: AustraliaPosts: 447 |
Added a Promo and link to latest version to Maximite.com.au & DuinoMite.com.au VK4MU MicroController Units |
| centrex Guru Joined: 13/11/2011 Location: AustraliaPosts: 320 |
Excellant work Jim How do find the CGMMSTICK. Cliff Cliff |
