Forum Index : Microcontroller and PC projects : MMbasic 3.1 For...Next bug?
Raros![]() Regular Member Joined: 06/02/2012 Location: ItalyPosts: 55 |
Hi. In a loop FOR....NEXT I will return an error: 10 For t = 1 to 5 Error: FOR without matching NEXT error: 10 For t = 1 to 5 20 For t1 = 1 to 5 ......... 50 Next t1,t OK: 10 For t = 1 to 5 20 For t1 = 1 to 5 ......... 50 Next t,t1 OK: 10 For tt = 1 to 5 20 For t = 1 to 5 ......... 50 Next tt,t (or Next t,tt) OK: 10 For t = 1 to 5 20 For x1 = 1 to 5 ......... 50 Next x1,t (or Next t,x1) OK: 10 For t = 1 to 8 20 For p = 1 to 3 ......... 50 Next t,p (or Next p,t) error: 10 For p = 1 to 7 20 For pp = 1 to 2 50 Next pp,p OK: 10 For p = 1 to 7 20 For pp = 1 to 2 50 Next p,pp etc. Some explanation? Thanks, Raros |
| BobDevries Senior Member Joined: 08/06/2011 Location: AustraliaPosts: 266 |
I seem to remember this bug appearing some time ago. I thought it had been squashed, but it seems to have re-appeared. Regards, Bob Devries Dalby, QLD, Australia |
| djuqa Guru Joined: 23/11/2011 Location: AustraliaPosts: 447 |
Best solution is always use seperate matching next statements, as it is much easier to debug/trace program FLOW. [code] For Iterations =1 to 10 ' We need to do this 10 times For prodCount = 1 to Number_Products ' How many Products we have ' ' ' ' Next ProdCount Next Iterations [/code] The above is better software engineering practice also. Some of your above examples have invalid Syntax and should/would not be allowable by MMBasic. e.g. [quote]10 For tt = 1 to 5 20 For t = 1 to 5 ......... 50 Next tt,t [/quote] VK4MU MicroController Units |
Thanks Djuga. I already knew, i always use seperate matching next statements. I just wanted to know why when a variable repeats in a cycle (a single and then double time 't' and 'tt' for example), with the same letter by mistake and with different letters is ok (it is difficult to translate from Italian to English ).
Italian: Questo lo sapevo già, uso sempre il comando NEXT separato. Volevo solo sapere come mai, quando si ripete una variabile in un ciclo (una volta singola e poi doppia 't' e 'tt' ad esempio), con la stessa lettera da errore e con lettere diverse è ok (è difficile da tradurre da italiano ad inglese, sono on po' imbranato con le lingue). Raros. |
Raros, There is nothing wrong with your English. It's a lot better than my Italian! I hadn't seen the problem before because I would usually put the NEXT code on separate lines. This might be a better description of the bug: This code works: for nxy = 1 to 10
for nx = 11 to 21 print nxy,nx next nx,nxy end This code also works - the order of the variables in the NEXT statement have been reversed without any problems. for nxy = 1 to 10
for nx = 11 to 21 print nxy,nx next nxy,nx end This code fails because the outer loop variable (n) is a substring of the inner loop variable (nxy) and it is placed after the inner loop variable. for n = 1 to 10
for nx = 11 to 21 print n,nx next nx,n end This code works - the outer loop variable is first in the NEXT statement. for n = 1 to 10
for nx = 11 to 21 print n,nx next n,nx end I haven't found anything in the help to indicate if multiple NEXT variables have to be in a defined order. Jim VK7JH MMedit |
Thanks very TassyJim. Ok. I understood perfectly. Actually I had guessed what you say: "the outer loop variable (n) is a substring of the inner loop variable (nxy) and it is placed after the inner loop variable." But I had many doubts. And it is also true that the manual does not indicate a definite order in NEXT with several variables. Thank you for your availability. I do not give anything for granted, I like to fully understand things. Greetings to all, Raros. |
