Local Time 06:08 24 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : UBW32 WITH I2C COMMS
ratsac
Posted: 04:42am 27 Feb 2012
I AM HAVING NIL RESULTS WHEN USING UBW32 INSTEAD OF MY MAXIMITE
I AM USING OUTPUT TAGS 12 AND 13, ON UBW32 BOARD THEY ARE D9 AND D10 RESPECTIVELY
THE SAME PROGRAM AS IN THE MAXIMITE LISTED BELOW
5 DIM PORT
10 I2CEN 100,100
20 I2CSEND 32,0,1,&hff
30 ? "MM.I2C after send: "; MM.I2C
40 I2CRCV 32,0,1,port
50 ? "MM.I2C after recv: "; MM.I2C;", Data from port: ";HEX$(port)
60 I2CDIS
70 END
THE RESULTS ARE
MM.I2C after send: 2
MM.I2C after recv: 2 , Data from port: 0
WHICH IS THE SAME AS NIL CONNECTION
HAVE TESTED O/P 12 TO SDA AND O/P 13 TO SCL
THANKS
SAC
BobD
Posted: 06:50am 27 Feb 2012
silly questions but ....
power on the I/O board?
on the right UBW32 pins?
right cables on the right pins?
do you still have the pullup resistors in circuit?
declare a pin as counting input and couple the sda and scl pins to it one by one to test if you are getting pulses on the line. You should be able to approximately predict the count. slow the I2C speed down to do the counting. dont forget the resistorsEdited by BobD 2012-02-28
darthmite
Posted: 04:13pm 27 Feb 2012
Hi ,
Cool to see that I'm not the only one who cant achieve to made a I2C communication
with the UBW32.
I'm 100% sure that all pin used are working because i have use them to
connect my joystick who work perfect
After trying with 3 different nunchuk and with no result i just keep that
on side up it work
I tested the SDA/SCL pins on the oscilloscope and no signals are coming out.
The 2 pins have a resistor to 3.3v as pull-up , i tried from 2.7 to 10K.
It will be good if it work , so all next games can use nunchuk instead of a
buttons based joystick.
Cheers.
Posted: 05:56pm 27 Feb 2012
Could it be to do with the different chip used by the UBW32? It uses the ...512L not ...512H, so 100-pin not 64-pin. Maybe some pins change function or need initialising differently?
darthmite
Posted: 05:01am 28 Feb 2012
Nah , i check the PIC32MX795F512L data-sheet for the pins , they are correct.
Posted: 10:08am 28 Feb 2012
Yes, but what I meant was along these lines:
Oh, I'm working on the basis that SDA & SCL are SDA1 & SCL1.
On the 100-pin 512L these are pins 67 & 66. Those are shared with other device features such as INT4 & INT3, RA15 & RA14. On the 512H the sharing is different and I wondered if that might be related to the problem.
ratsac
Posted: 04:59am 19 Mar 2012
I have resolved thjs problem with the use of different pins as indicated by johns
I used ra15 for sda and ra15 for sdl this enabled a result
Have emailed geof with this result
ratsac
