Local Time 06:09 24 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : problem to connect CircuitGizmo
f1fco
Posted: 08:11pm 25 Mar 2012
hello to all,
I cannot connect the site of CircuitGizmo :
http://www.circuitgizmos.com/products/cgmmstick1/cgmmstick1. shtml
(I want to order a CGMMSTICK1)
does others with the same problem ?
thank you for your help
Pierre from France
73s de F1FCO
BobD
Posted: 08:25pm 25 Mar 2012
Pierre
it is because you have a space between the 1. and the shtml.
Try this http://www.circuitgizmos.com/products/cgmmstick1/cgmmstick1. shtml You may also find this site useful http://www.downforeveryoneorjustme.com/
f1fco
Posted: 03:59pm 26 Mar 2012
thank you for your answer
nut the problem is the same with only
I receive the message (in french of course) :
I use Firefox 11.0
La connexion a été réinitialisée
La connexion avec le serveur a été réinitialisée pendant le chargement de la page.
Le site est peut-être temporairement indisponible ou surchargé. Réessayez plus
tard ;
Si vous n'arrivez à naviguer sur aucun site, vérifiez la connexion
au réseau de votre ordinateur ;
Si votre ordinateur ou votre réseau est protégé par un pare-feu ou un proxy,
assurez-vous que Firefox est autorisé à accéder au Web.
73s de F1FCO
BobD
Posted: 07:55pm 26 Mar 2012
  f1fco said   thank you for your answer
I use Firefox 11.0
tard ;
The connection was reset
The connection to the server was reset while the page loads.
The site may be temporarily unavailable or too busy. Try again later. If you are unable to load any pages,
check the connection on your computer networking.
If your computer or network is protected by a firewall or proxy, make sure that
Firefox is permitted to access the Web.
IE9 works OK for me.Edited by BobD 2012-03-28
James_From_Canb
Posted: 02:44am 27 Mar 2012
I'm using Firefox 11.0 too.
Clicking on the link that Bob supplied worked for me.
I can also access http://www.circuitgizmos.com
darthmite
Posted: 03:01am 27 Mar 2012
I confirm that http://www.circuitgizmos.com is working fine.
Firefox 11.0 too here.
Cheers.
Posted: 06:56am 27 Mar 2012
TBS kept failing to respond / resetting for me yesterday but seems OK today.
JohnEdited by JohnS 2012-03-28
