Forum Index : Microcontroller and PC projects : MM Edit update
Just a small update to MM Edit. You can now run your code in DOS MMbasic directly from MM Edit. The first time you try, it will ask for the location of MMBasic.exe MM Edit then creates a temp.bas file and runs it in MMBasic. There were no other changes needed to MM Edit for the new release of MM Basic. Jim VK7JH MMedit |
That is an excellent idea! Micromites and Maximites! - Beginning Maximite |
