Forum Index : Microcontroller and PC projects : Problem with MMBASIC (DOS)
| BobDevries Senior Member Joined: 08/06/2011 Location: AustraliaPosts: 266 |
Hi all, I've been trying out MMBASIC for DOS, and finding a few problems. It frequently just quits if I type a line number by itself, to kill an existing line, or if I type NEW, to remove the programme in memory. Anyone else seen this? Regards, Bob Devries Dalby, QLD, Australia |
I haven't seen your problems but I usually code in MM Edit and run the program once in DOS MM Basic. I did try to get your errors but 20 or so NEW's worked OK and a similar number of line number entries also worked without fault. I did find another problem: The enter key on the number-pad does not work. The number keys are OK but not the enter key. Jim VK7JH MMedit |
