Local Time 18:04 21 Jun 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MM/DM Caravan Power Monitor
panky
Posted: 02:34am 12 Oct 2012
Hi all,
I have been working for some time on a hardware/software package to provide a Caravan Power Monitoring system. I have included my work to date below and am happy if Hugh would like to add it into the library. It is a work in progress and I'm happy to take any questions/suggestions.
Doug.
2012-10-12_123415_CVanBM.zip
shoebuckle
Posted: 01:11pm 12 Oct 2012
Doug,
It will be in the next MMLib update.
Cheers & thanks,
Hugh
Posted: 01:26pm 14 Oct 2012
An interesting project.
I am in the early stages of something similar.
Instead of shunts, I am using hall effect devices - ASC758
I went for these modules on ebay:
"50A/100A/150A/200A Bi/Uni AC/DC Current Sensor Module (arduino compatible)"
Being isolated makes them easier to connect to the Maximite. I also use LM324 op amps so I can run a single supply rather than split.
Inputs at this stage are:
DC amps X 2
AC amps
Indoor, outdoor and fridge temperature (LM335Z)
Electric brake monitor - DC amps on each axle and if they are not the same - panic.
(I went down Macquarie Pass south of Sydney with one axle not working and it was not nice!)
I might also have a GPS so I can align the satellite dish.
I want to use the AC current to control load shedding - turn the hot water of when the BOSS starts the hair dryer.
panky
Posted: 09:01pm 18 Oct 2012
For anyone interested, I have ordered a 9" VGA LCD display so when I get home in a couple of weeks, I will start work on a pixel level graph of voltages and currents.
I had a look at the single supply op-amps but came to the conclusion (just me, not necessarily fact) that because I wanted to work down to to the millivolt level for low currents, I needed the ability to zero the offset and calibrate so I could read voltages within a few millivolts above zero.
I also had a problem of how to read both input current and load current independently and where to reference both readings hence I took (for me) the easy way out and used the battery neg as the reference zero thus with a shunt on the input current negative path and a shunt on the output negative path, I could read a negative millivolt value for input current and a positive millivolt reading for the output current.
As well as amplifying the millivolt levels to voltage levels, I scaled the input to be within the 3.3V levels of the MM ( in fact, 50A thru the shunt gave 50Mv and after amplifying, 2.5V at the MM input pin.
Battery charge or discharge then became the difference between the two.
I haven't looked at hall effect devices for this project - how are they for reading down to 1 Amp DC currents?
Interesting thought about the AC monitoring - might have a go at integrating that as well.
As I'm getting toward memory limits, I am going to see how Jim's short strings go - my only concern is timing in the interrupt routines.
Regards, Doug.
graynomad
Posted: 01:22pm 20 Oct 2012
  panky said  how are they for reading down to 1 Amp DC currents?
The ASC712 has a 5A version, presumably it works OK down around the 1A level.Edited by graynomad 2012-10-21
Rob Gray, AKA the Graynomad, www.robgray.com
panky
Posted: 02:32pm 20 Oct 2012
Thanks Rob, I might try to have a play with Hall Effect when I get a chance.
What I needed when I started was to read currents from 0 to 50 amps with a resolution to .1A and an accuracy of around +- half an amp. So for me, the simple solution was the current shunt and dc amp config - not saying it's the best but easiest for me (I also liked the challenge of playing with the op amps for dc amplification ;-) )
Cheers, Doug.
Posted: 02:37pm 20 Oct 2012
Doug,
I have the 50A bidirectional ACS758 which outputs 40mV per amp.
zero amps is at 50% supply voltage.
Regarding saving program memory,
Rather than go to the overhead of my "short string" routines, you could fit 5 minutes of readings into one string.
That would make the LogFileArray$ a lot smaller without too much work.
You can save a few more string variables by reusing (without making the code unreadable)
The 3 string variables debug_mode$, getdate$, and gettime$ appear to get used once and the result saved as a numeric variable.
You could use one string variable for the answer and reuse it.
This code:
MinTurnover$="59"
Do While MinTurnover$ <> "00"
MinTurnover$=Mid$(Time$,7,2)
could be changed to:
MinTurnover=0
Do While MinTurnover <> 0
MinTurnover=val(Mid$(Time$,7,2))
to save another string.
The next release of MMEdit will have a command to strip out comments which means you can develop code with comments and deploy to the Maximite with the leaner code.
The next release also has a working VT100 screen which I have been testing with your code (amongst others).
panky
Posted: 08:14pm 20 Oct 2012
Jim, That's really helpfull - much appreciated. You are certainly right in that I have not optimised my variable usage and I should be able to prune a lot of rubbish and/or redundancy. My initial work was just getting the sucker to work!!!
I was particularly interested in the elegance of your short strings idea so couldn't help myself in wanting to have a play with that ;-)
I like the idea of the REM strip function - I was thinking of some way of creating a program to strip REM's from a program myself so I look forward to the new version of MMEdit, a really, REALLY neat program. Within my limited coding capabilities or as a tester, anything I can do to assist with MMEdit development - just ask.
Cheers, Doug.
James_From_Canb
Posted: 08:26pm 20 Oct 2012
There should be a StripComments program written in MMBasic in the library. I wrote one while I was developing the LCD.LIB and ran out of memory. I can't confirm the name because I'm out of town for a couple of days.
James
shoebuckle
Posted: 04:48pm 21 Oct 2012
  James_From_Canb said   There should be a StripComments program written in MMBasic in the library. I wrote one while I was developing the LCD.LIB and ran out of memory. I can't confirm the name because I'm out of town for a couple of days.
James
James, I can't see your StripComments programs in mmlib and I don't remember having ever come across it. Why not send it to mmlib@geoffg.net and I will add it.
Cheers,
Hugh
panky
Posted: 03:32pm 09 Jan 2013
Hi All,
Have finally gone live with the VGA version of my Caravan Battery Monitor program. Seems to go OK so I have taken the liberty of a 1.00 version.
Any/all comments appreciated. Hugh, feel free to put up in the library and delete previous.
For all interested, please note the comments/caveats in the readme file.
Doug.
2013-01-10_013139_CVBM10.zip
