Local Time 19:03 21 Jun 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : how to "reset" a Maximite ?
f1fco
Posted: 07:23am 24 Nov 2012
hello from France
do you know how to reset a Maximite board (basic v4) by software ?
a special POKE ?
thank you for answer
Pierre, south of France
hamradio : F1FCO
73s de F1FCO
Posted: 12:48pm 24 Nov 2012
  f1fco said   hello from France
a special POKE ?
Hi Pierre,
As I just posted in another thread for someone who asked a similar question. ....
You could always try connecting an unsed ouptut pin (pulled high via a 10k or 4k7 OHM resistor) to the RESET.. when you want to reset the MM direct the pin to go LOW and bingo it kicks itself up the ..... errr ... well it resets itself.
The MM should reconfigure the pin as an INPUT and the pull up would keep it high until the MM has control again.
PS.. Maybe there is some merit in this being added as a command..
Mik
Talbit
Posted: 11:29pm 24 Nov 2012
Not sure if a kick up the Kyber by a MM pin would work because I'm presuming the MM has frozen. A watchdog timer could be made with a hardware timer like a LM555 that is continually reset by a MM pin programmed to periodically reset the timer. If the timer times out because the MM has frozen then it could somehow toggle the MM power to get it to reboot.
Talbit
Talbit
Posted: 12:57am 25 Nov 2012
  Talbit said   Not sure if a kick up the Kyber by a MM pin would work because I'm presuming the MM has frozen. A watchdog timer could be made with a hardware timer like a LM555 that is continually reset by a MM pin programmed to periodically reset the timer. If the timer times out because the MM has frozen then it could somehow toggle the MM power to get it to reboot.
Talbit
But Pierre wanted a way to do it in software... One makes the assumption that the MM hasnt crashed. Yes a watchdog timer is a good recovery system in the event it crashed but I think he wanted to controll the resetting..
Regards Mick
VK2MCT
Posted: 04:21am 25 Nov 2012
A watchdog arrangement maybe a bit tricky because of an infinite loop of resetting before program runs. ie - program run needs to happen to stop watchdog timing out.
John B Edited by VK2MCT 2012-11-26
MicroBlocks
Posted: 05:16am 25 Nov 2012
A PIC32 has a builtin watchdog.
I am not sure if it is used by MMBasic.
http://ww1.microchip.com/downloads/en/DeviceDoc/61114E.pdf
Posted: 09:10pm 25 Nov 2012
No, MMBasic does not use the watchdog timer. There is little advantage in using it in a general purpose computer and a lot of issues.
TinkersALot
Posted: 12:40pm 26 Nov 2012
there are dozens of watchdog circuits out on the web. Here are a couple:
http://techdoc.kvindesland.no/radio/ymse3/20081009164537926. pdf
http://cache.freescale.com/files/microcontrollers/doc/app_no te/AN1263.pdf (see page 9)
http://discovercircuits.com/DJ-Circuits/watchdog.htm
http://www.industrologic.com/nv_watchdogtimer.pdf
http://powerelectronics.com/704PET07.pdf
Edited by TinkersALot 2012-11-27
Posted: 01:56pm 26 Nov 2012
The PIC32 has a watchdog timer built in (as do most micros) - it does not need an external circuit.
TinkersALot
Posted: 04:53pm 26 Nov 2012
...confused....these replies seem at odds with each other?Edited by TinkersALot 2012-11-28
Posted: 05:57pm 26 Nov 2012
Hi Michael,
The PIC32 has a watchdog timer but MMBasic does not enable it or use it. I only mentioned this because you gave some circuits for an external watchdog circuit.
I did not enable the watchdog in MMBasic because the interpreter is stable enough that it does not need it and the watchdog timer would (if it went off) completely reset the PIC32 chip erasing the program and data in RAM (not a good thing).
But, I could imagine a circumstance where a BASIC program written by a user got itself stuck in a loop and, to prevent that being a problem, you could use the SETTICK command as a watchdog timer for MMBasic programs.
For example insert the following into critical parts of your code: SETTICK 1000, ErrorRecoveryLabel
If you called that function regularly (ie, faster than once a second) the timer would never go off but, if something did go wrong and the timer timed out, the code at ErrorRecoveryLabel would be executed.
GeoffEdited by Geoffg 2012-11-28
TinkersALot
Posted: 06:42pm 26 Nov 2012
Cool. Thanks for teaching me that. That function could perform the do the output pin toggle to tied to the reset pin as was described earlier in this thread...so kind of a through a timeout based software reset.Edited by TinkersALot 2012-11-28
Posted: 09:33pm 26 Nov 2012
I do have a need for a watchdog timer.
I have a Maximite based data acquisition system.
There are times when I can be a few thousand kM away for months at a time.
I did a have a strange problem with my first Maxi that meant it needed a power down at random times. This happened every few weeks so it was hard to track down.
I had an old IP based IO board so it was setup to power the Maxi through a relay.
If the laptop software didn't receive data for 20 seconds, it knew there was a problem and the power to the Maximite was cycled.
I could also log into my system remotely and turn the power of whenever desired.
(Being a Windows computer tech, turning the power of then on again is a common task)
This worked well for a month or so until a mouse with a weak bladder buggered up the IO board.
The replacement Maximite has run for 3 months or so now so the reset hasn't been used lately.
Rather than having the laptop controlling the reset, I have considered a picaxe which is triggered every second or so to keep things running.
Using a picaxe, you can include software that waits for the first pulses before being active. That way you can have time to restart the Maximite application without continual resets.
Posted: 10:17am 27 Nov 2012
Ahh... Yes, True so if my suggestion of a pin is tied to RESET then the program should be stored as AUTORUN.BAS so at least the code will continue away.. The prog will need to be able to handle the recovery from this state.
TinkersALot
Posted: 11:16am 27 Nov 2012
  TassyJim said   I do have a need for a watchdog timer.
...That way you can have time to restart the Maximite application without continual resets.
for that reason alone, I think I like this external hardware circuit the best out of those that I posted because it offers a very long delay for timeout:
Posted: 01:24pm 27 Nov 2012
One big disadvantage of any watchdog system is that you loose any chance of finding out what went wrong. This makes fixing the problem a lot harder.
If your program crashes, there is likely to be clues left on the screen.
Doing a reset before reading the clues is not a good idea.
TinkersALot
Posted: 02:04pm 27 Nov 2012
wonders:
if instead of relying on screen content to ascertain the cause of an error/halt; would not a simple checkpoint log (persisted to file) be a solution allow improved forensic analysis of possible fault conditions?
Ideally, this log could contain enough information to reproduce the error; Presuming it is a logic fault, and not a single event upset (SEU) which are transient bit-flips or a single event latchups (SEL) due to the passage of is a single, highly-energetic charged particle through a semiconductor.
TinkersALot
Posted: 02:17pm 28 Nov 2012
in reviewing the code for MMBasic,
it appears that the device may be reset by MMBasic interpreter if there is arithmetric overflow....
so if I really wanted a way to have a software-reset for the maximite, can I use "bad code" that causes an arithmetric overflow condition to reset the device? Edited by TinkersALot 2012-11-30
BobD
Posted: 02:21pm 28 Nov 2012
  TinkersALot said   in reviewing the code for MMBasic,
Not sure if it will work here ( my machine temporarily out of action) but divide by zero is usually good to cause havoc.
CircuitGizmos
Posted: 02:26pm 28 Nov 2012
POKE 0,0,0 once used to reset the device in version 2.6.
