Local Time 02:20 21 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Joystick for the CMM standardization
     Page 1 of 3
MicroBlocks
Posted: 12:27am 31 Jan 2013
I am in the process of designing a CMM clone and would like to have a joystick connector on it.
Maybe 2 is even better.
I would suggest going for the standard 9 pin D connector.
The most important however is how to wire them up.
I guess Nick is the one with the most experience, what do you suggest Nick?
The goal would be to have a standard joystick connection so that anyone who writes a program for the CMM can use the same routines/PINS. This will greatly improve the playability of the CMM.
I would suggest using at least 2 analog capable pins per joystick port so that analog joysticks can be used too.
The same as some pins are designated to have extra functionality like com ports, i2c and CAN, designating PINS to use for joysticks would be a great thing.
If that is done we could ask Geoff to add joystick functionality to MM to make use of it even easier for the BASIC programmer.
Edited by TZAdvantage 2013-02-01
CircuitGizmos
Posted: 04:58am 31 Jan 2013
Joystick wiring information already documented here:
http://www.thebackshed.com/forum/forum_posts.asp?TID=5511&PN =1
MicroBlocks
Posted: 05:22am 31 Jan 2013
How did i miss that?
Thanks!
edit:
I am not really happy with the chosen pins though.
PIN12 and PIN13 are for i2c and losing that capability while connecting a joystick is not nice.
Maybe a new and improved allocation of pins should be considered for a joystick (or 2).
CircuitGizmos
Posted: 05:28am 31 Jan 2013
I have that documented in the working copy of Beginning Maximite that I have at my desk. The most recently published one (version 1.3) does not have joystick information.
That is ONE defined "Atari" joystick. If there is to be a second joystick defined (perhaps in this thread) I will document that one, too.
MicroBlocks
Posted: 05:45am 31 Jan 2013
If i was Emperor then i would use the pins available on the arduino connectors.
I think when you want to keep compatibility with the monochrome version it i simportant to leave PIN1-20 alone.
If joystick feature can be added as a MMBasic function it would be nice to choose pins that are on the same PIC32 port. This will make implementing it much easier.
If you look at the color maximite schematics at jumpers J2 and J3 there is a n oppertunity to use both functionalities instead of choosing.
If you place the jumper for use as a I2C across pin 2 and 3. This will leave pin 1 of those free as analog ports.
I would suggest to use those for the analog X/Y.
It will only interfere with a pickit programmer, you would need to remove the joystick when you do that.
[code]
Software pin Joystick signal
Pin D7 Up
Pin D6 Down
Pin D11 Left
Pin D12 Right
Pin D10 Fire Button
Connector
J2 pin 1 Pot X
J3 pin 1 Pot Y
[/code]
A second joystick:
[code]
Pin D2 Up
Pin D1 Down
Pin D3 Left
Pin D0 Right
Pin D4 Fire Button
Pin A0 Pot X
Pin A1 Pot Y
[/code]
By using these pins, users of existing color Maximites and CGCOLORMAX can add joysticks as those pins are easy to access because they are not part of the external connector. Also adding the joystick connectors to the enclosure would be possible without soldering wires directly to the board.
CircuitGizmos
Posted: 05:59am 31 Jan 2013
You are saying that joysticks are not to be used with the B&W Maximite or CGMMSTICK?
MicroBlocks
Posted: 06:08am 31 Jan 2013
I think, but don't know for sure, that PIN1-20 are more used for controlling other stuff then it is for using a joystick.
Probably here is the best place to find that out.
The Color version gives an opportunity to have the best for both. Maintain PIN1-20 compatibility and use the Color versions extra pins to have extra features, like a joystick.
Maybe define an alternative pin mapping for monochrome versions but i would still refrain from using PIN 12 and PIN13.
CircuitGizmos
Posted: 06:20am 31 Jan 2013
As it stands right now, the single joystick is implemented in Nick's game programs as I have documented it.
The way I see it (some may agree or not) is that if you are using the Maximite for games, you are probably not using it for interfacing to I2C devices.
Also MMBasic code to deal with the joystick is simple enough that adding specific joystick functions to MMBasic would be effort that doesn't have a lot of return. (Again, in my opinion.)
If things change here, I'll update the Beginning Maximite documentation to _hopefully_ keep everyone using the joystick in the same way.
MicroBlocks
Posted: 06:48am 31 Jan 2013
Joysticks are very handy devices in control circuits. Think robotics, CNC, motion control, etc.
For that reason i think I2C is very common.
For the color maximite i think it would be nice if every 'clone' and the maximite itself would use the same pins.
It would make Nick - our resident game developer's- live easier. :)
And i think if the color maximite ever wants to break through, it needs that type of standardization. It will promote exchange of programs and knowledge.
Same as pins used for serial ports and I2C, once defined people will use them and there would be no reason to change.
CircuitGizmos
Posted: 06:59am 31 Jan 2013
It is already defined. You are suggesting that it be changed. That would leave anybody that has already made the hardware needing to change their hardware. It would mean that MaxMan and Donut (Nick) would have to be rewritten for your joystick connections or two versions released.
MicroBlocks
Posted: 07:37am 31 Jan 2013
But that would still work, just use the way it is made.
I see no reason why it should not work?
Maybe i am focused more on having a joystick function in MMBasic, that will make it for game development and motion control much easier.
There is no reason why it should not support the monochrome version for backward compatibility. A program can just ask which of the three joystick port is used, and then use those pins.
Going forward however it would be nice to 'lock' some things, and i am of the opinion that using pins that are specifically I2C should never have been used for a joystick in the first place.
It was probably done, accepted and never questioned.
However if we move forward, and i mean specifically with the Color version, i would think it is best to set a good standard now.
I have my own projects that i want to do, and seeing that two joysticks are never used on a Color maximite i would like to make one myself, all the better if others would like to use it too.
At the moment i have this design in mind:
I don't have all the 3d parts yet so the render is incomplete, especially the VGA connector on the top left and the microsd front center. The idc should be a right angle.
CircuitGizmos
Posted: 08:16am 31 Jan 2013
"Maybe i am focused more on having a joystick function in MMBasic, that will make it for game development and motion control much easier."
Wow. A person that can't figure out how to write a simple joystick function and need to have it be a MMBasic command probably can't write a full game anyway.
This is what I think is going to hurt the Maximite: Making a bunch that are close, but incompatible with each other in some way. Making the end user have to choose to follow what has been documented here at TBS, or something else. More confusion for the end user. You are dismissing what has been done so far just because you think you have a better use of Maximite pins.
This has happened before and has done a lot of damage to the Maximite.
MicroBlocks
Posted: 10:09am 31 Jan 2013
Well lets just say you have a different opinion.
As an example PIN 12 and 13 can be used as input, output or I2C.
Would having a I2C function in MMBasic not make programming easier? After all, you can just manipulate the pins directly to have the same functionality.
PIN 15,16,17,18 can be used as input, output and as COM1:.
Would having a com1: port in MMBasic not make programming easier? After all, you can just manipulate the pins directly to have the same functionality.
PIN 19 and 20 can be used as com2:.
Would having a com2: port in MMBasic not make programming easier? After all, you can just manipulate the pins directly to have the same functionality.
D4 and D5 can be used as input, output and as CAN.
Would having a CAN function in MMBasic not make programming easier.
I think we see recent proof of that.
And is that detrimental to 'what has been done before'?
I hope you can see what i am trying to tell.
You not loose any functionality, you only gain it.
Again i am not dismissing anything, just adding.
Having often used algorithmes within MMBasic will not only speed things up but it would also minimize usage of RAM. Programmers would not need to worry how a joystick is connected. A function in MMBasic will make that generic.
I think that is a good thing to add joystick functionality especially as its uses go beyond only games as mentioned before.
I think it will bring even more joy to using a maximite and more projects will be made.
CircuitGizmos
Posted: 10:16am 31 Jan 2013
I can clearly see what you are saying. I could all along.
I'll state my position one last time: I hope that this doesn't devolve into what happened last time.
MicroBlocks
Posted: 10:24am 31 Jan 2013
Educate me, what happened last time?
I am only a recent member.
vegipete
Posted: 11:06am 31 Jan 2013
I off-topic posted in Nick's (cool) blit example thread a thought about joystick connections that belongs in a thread like this one. I mused whether a joystick port could be specified with respect to say the PC pinout, using a 15 pin D-SUB instead of a 9 pin. Allows for 2 joysticks (4 analog channels) and 4 buttons, good for 2 player games. Allpinouts.org has a nice write up. 5 volt pins would be 3.3 volts instead. Standard analog PC joysticks should be cheap and easy. The big problem is that PC joysticks were wired as variable resistors, not pots.
I thought I read here somewhere that a wii remote would connect via the I2C.
Nick
Posted: 12:26pm 31 Jan 2013
I like the idea of a joystick as a standard interface available for all.
I personally like the good old Atari standard for the following reasons:
1) It's a standard.
2) It's supports digital (switch type) connections as well as 2 analogue (X/Y).
3) It's easy to find these joysticks on Ebay.
If we go to a 15pin PC joystick standard, then we can't use these Atari/Amiga joysticks without modding the plug or adding an adaptor.
Also, PC joysticks are predominantly analogue and cost more than the Atari ones.
The Nunchuk is OK but not as good for gameplay as a stick/joypad. Even on the Nintendo Wii, the Nunchuck is not used as the primary controller. Besides, you have to mod the NunChuch connector to connect it to the Maximite.
Any joystick solution should be accessible by all without the need to get "down-n-dirty" modding sticks and connectors, something that not every can do.
We need support for an off-the-shelf stick that can be plugged in and start getting those high scores!
I've supported Darthmites interface from the start. It works well and uses a standard unmodified Atari style joystick or Paddle Controller.
Why complicate it any more than that?
Nick
P.S. With the joystick, I can easily do all 10 rounds of Donut Dilemma. Edited by Nick 2013-02-01
cosmic frog
Posted: 12:52pm 31 Jan 2013
I'm with Nick on this one. The Atari/Amiga joystick is a tried and tested rock solid standed that has been with us for over 30 years, which, compliments the Maximite perfectly.
paceman
Posted: 07:10pm 31 Jan 2013
OK,OK I obviously need to get an Atari style joystick instead of the Nunchuk - Geoff too I think or did he quietly swap over earlier Mind you Nick, I reckon you just could have a special version of Donut
Greg
P.S. I think I can see merit in everyone's arguments above so I think I'll stay out of this!
MOBI
Posted: 07:18pm 31 Jan 2013
On the subject of joy sticks..
I have tried to get the "space invaders" game to work and although it comes up on the screen and the little beasties shoot at me, I can't get any keyboard response. Was it written only for joystick??
I also notice with all the games that there isn't much "read.me" documentation saying how things work.
And be damned if I can get past level 1 on Donut Dilema. How do you get from the upper left platform to the right? There's a dancing donut in the way and I can't jump it. Am I missing something?
David M.
     Page 1 of 3
