Local Time 18:19 21 Jun 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Line is too long?
Posted: 11:16pm 01 Mar 2013
In CMM, MMBASIC reports that a certain line is too long, yet it executes just fine.
I cannot edit past column 81, but the code still runs.
LIST also shows the full line, but the editor will not.
Why?
NOT a criticism, just an observation.
MMBASIC 4.3 on CG CMM.Edited by Grogster 2013-03-03
Posted: 10:07am 02 Mar 2013
The maximum length of a line is 255 characters but the Editor is limited to 80, the maximum width of the screen.
If you edit outside the built-in editor, you can make your lines longer but this would make using the built-in editor troublesome so it is advisable to keep all lines within the 80 character limit.
shoebuckle
Posted: 11:04am 02 Mar 2013
You can still use the Editor to add to or change long lines. Move the cursor towards the end of the line and press enter to split the line. Characters after col 80 will move to the next line and you can edit them there. When you are finished, delete the Enter to rejoin the line. Simple.
Cheers,
Hugh
Posted: 07:48pm 02 Mar 2013
I split the line into two, so that it can be properly edited. :)
