Local Time 19:02 21 Jun 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Monitoring the USB state
Posted: 01:37pm 11 Jul 2013
Geoff,
would it be possible add another Read Only Variable:
MM.USB to indicate when the Maximite is plugged into a USB host. (This would not guarantee any intelligence on the PC end.)
maybe even an interrupt:
ON USB goto xxxx
MM Basic already sends the welcome message when the USB comes up.
or is there a PEEK that does the job for me?
Posted: 05:31pm 11 Jul 2013
You could use either of these two:
IF (PEEK(&HBF88, &H5060) AND 1) = 1 THEN PRINT "+5V is on the USB connector"
or
IF (PEEK(&HBF88, &H5060) AND &B100000) = 0 THEN PRINT "There is a valid USB session"
Note that the second one means that there is a computer host connected to the USB (it does not tell you that there is a a terminal emulator running on it - that is much harder).
GeoffEdited by Geoffg 2013-07-13
Posted: 05:59pm 11 Jul 2013
Thanks Geoff,
those 2 options will keep me happy.
vk2sja
Posted: 05:20am 13 Jul 2013
  Geoffg said   (it does not tell you that there is a a terminal emulator running on it - that is much harder).
Not sure if this is required/helpful but it seems that if you fire "ESC [0c" (that's zero c, and remove the spaces) off at the unknown device at the other end of your USB come serial link. Then if there is a DEC VT100 terminal emulator of some sort at the other end it should respond with "ESC [?1;#c" where the # is a number between 0 and 7.
That's the DEC VT100 DA – Device Attributes ESC sequence.
See: http://www.vt100.net/docs/vt100-ug/chapter3.html
You could use this to see if you have a live VT100.
Haven't tried it yet.
Mileage may vary depending on how good the emulator is. Linux XTerm does seem to support it
http://invisible-island.net/xterm/ctlseqs/ctlseqs.html
