Local Time 20:11 21 Jun 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Hi all, need help for a greenhouse projec
crosstydown
Posted: 04:27am 29 Nov 2013
I need to built automation for aquaponics greenhouse with the maximite.
i know little about programming exept that i still have my old color computer 2 trs80
and i do some automation whit it in my youger times.
first trouble, i buy a sensor http://www.robotshop.com/ca/en/dfrobot-light-sensor-bh1750.h tml and i dont know how to make it work, can someone explain how to do and give me program in mmbasic . i will use the sensor to control lighting for flowering.
many thanks
this is my website, www.shojigarden.com
www.shojigarden.com
BobD
Posted: 08:31am 29 Nov 2013
Do you know any MMBasic programming?
Some info for you:
Use the I2C functions of MMBasic to control the module and read the data.
The I2C address is decimal 35 or hexadecimal 23 with the ADD pin unconnected.
You don't need to use pull-up resistors as they are included on the module.
crosstydown
Posted: 08:45am 29 Nov 2013
many thanks for your help.
can you write some line code that will read the light from the sensor, it will help me understand the basic of i2c.
crosstydown
Posted: 08:45am 02 Dec 2013
please i need help to understand to use i2c if someone can help
BobD
Posted: 09:12am 02 Dec 2013
  crosstydown said   please i need help to understand to use i2c if someone can help
You could try clicking this link.
crosstydown
Posted: 09:25am 02 Dec 2013
bobd , do you have experience with i2c?
Frank N. Furter
Posted: 08:35pm 02 Dec 2013
Hello Crostydown,
I can give you my code for the Lightsensor ISL29023 which you can buy from Soldercore:
"http://soldercore.com/products/sensecore/corelight/"
It works very well with my Duinomite and MMBasic.
'* TESTPROGRAM FOR LIGHTSENSOR ISL29023 *
'* Filename: ISL01.BAS *
'* Date: 2013-10-25 *
Clear
Cls
Pause 500
'*** Array Declaration ***
Dim Licht_DAT(1) 'Array for LSB and MSB of candle power
'SDA is on Maximite-Pin 5, CLK on Maximite-Pin 6
ISL29023_addr = &h44 ' ISL29023 slave baseaddress
I2CEN 400, 100 ' Enable I2C
'*** Registers ***
COMMANDI_R = &H00
COMMANDII_R = &H01
DATA_LSB_R = &H02
DATA_MSB_R = &H03
'*** Config Sensor ***
I2CSEND ISL29023_addr, 0, 2, COMMANDI_R, &HA3 'Command Register I 00(hex):
'ALS continous, NUMBER OF INTEGRATION CYCLES = 16
GoSub CheckIIC
I2CSEND ISL29023_addr, 0, 2, COMMANDII_R, &H02 'Command Register II 01(hex):
'n-BIT ADC = 16, FSR(LUX) @ ALS SENSING = 16000 (Range 3)
GoSub CheckIIC
'*** MAIN-PROG ***
Start:
GoSub LESE_SENSOR
'Print"LUX: ";Bin$(LUX(0));" ";Bin$(lux)
'Print Bin$(lux(0))
Print"Light: ";Bin$(Licht);" ";Licht; " LUX: ";LUX
Pause 100
GoTo Start
'*** Read Sensor ***
LESE_SENSOR:
'First send Registeradress DATA_LSB_R, than read 1 Byte
'(LSB)
I2CSEND ISL29023_addr, 0, 1, DATA_LSB_R
GoSub CheckIIC
I2CRCV ISL29023_addr, 0, 1, Licht_DAT(0)
GoSub CheckIIC
'receive MSB:
I2CSEND ISL29023_addr, 0, 1, DATA_MSB_R
GoSub CheckIIC
I2CRCV ISL29023_addr, 0, 1, Licht_DAT(1)
GoSub CheckIIC
Licht = (Licht_DAT(1)*256 + Licht_DAT(0))
LUX = Licht * (16000/2^16) 'Alpha=Range(k)/2^n (see Datasheet S.6)
Return
'*** CheckIIC ***
CheckIIC:
If MM.I2C <> 0 Then Print"I2C-ERROR!"
Return
I hope the comments are useful...
Frank
Edited by Frank N. Furter 2013-12-04
BobD
Posted: 12:24am 03 Dec 2013
  crosstydown said   bobd , do you have experience with i2c?
Denis, yes, Bob
palcal
Posted: 11:44am 03 Dec 2013
I had the same problem with a humidity sensor and one of the members 'seco61' very kindly wrote some code for me. Send him a PM maybe he can help.
Paul.
crosstydown
Posted: 04:35pm 04 Dec 2013
thanks, i will try and come back with the result
crosstydown
Posted: 07:23pm 05 Dec 2013
i try the code from Frank Furter and dont have value both something start to communicate because the mm.i2c change from 0 to 1 when i put the add wire fom positive to negative power
Posted: 08:26pm 30 Dec 2013
Did you get your sensor working?
I received one in the post today and was able to have a successful play.
' reading the BH1750 light sensor
' in single shot mode.
' TassyJim 31 12 2013
Cls
Dim LightData(2)
BH1750address = &H23 ' BH1750 address
I2CEN 400, 200 ' Enable I2C
pause 200
I2CSEND BH1750address, 0, 1, &H01 ' Power on
print MM.I2C
pause 250
I2CSEND BH1750address, 0, 1, &H07 ' Reset
pause 250
main:
do
pause 50
I2CSEND BH1750address, 0, 1, &H20 ' 1x scaling, single reading
pause 200
I2CRCV BH1750address, 0, 2, LightData(0)
lux= (LightData(0)*256 + LightData(1))/1.2
Print "Light: ";format$(lux,"%7.1f");" lux"
pause 750
k$=inkey$
loop until k$="q"
I2CDIS
end
It is a lot better than using a resistor and LDR!
crosstydown
Posted: 05:04am 04 Feb 2014
MANY THANKS FOR YOUR HELP!
my project start to run and i will receive the tft maximite this week.
akashh
Posted: 03:26pm 04 Feb 2014
Hi, please do not take this as a marketing post. I am also an aquaponics enthusiast and worked on several systems here in India. I built my own timers, etc. but this was before I built the Wattmon. One of my goals with the Wattmon has always been to control a complete aquaponics setup and I have various modules that could be put together with minimal programming for this purpose, such as pulse counter for water flow, analog inputs, digital inputs, and relays. I just have not found the time yet to build my setup. If you are interested in using a Wattmon I would be happy to assist in the customisation. The main reason to use such a device instead of the maximite would be the Internet connectivity, allowing you to get alerts and check the running status from anywhere, which IMHO is essential for aquaponics. I did not have it for my previous setups and it proved to be catastrophic a couple of times.
The other project which I find great is by a guy in the US: http://www.kijanigrows.com/
He has apparently done it with a fully open sourced arduino.
Edited by akashh 2014-02-06
crosstydown
Posted: 05:00pm 04 Feb 2014
Hi Akashh,
thanks for the info.
From my experience, INTERNET is not the safest way to know alarm in greenhouse. The best from now is a pager like paravox to call your cellular phone and is easy to link to the mighty maximite.
crosstydown
Posted: 05:01pm 04 Feb 2014
Hi Akashh,
