Forum Index : Microcontroller and PC projects : Reading a Maximite Pin doesn’t work
mcmichael
Posted: 09:31pm 30 Nov 2013
Hi Experts,
I'm trying to read values from a pin and all I'm getting are rubbish values.
In the program I wrote:
SETPIN 1,1
PRINT PIN(1)
I connected a variable resistor (potentiometer) to GND, 5V and I/O Pin 1.
The values jump from 0.1 to 0.7 and are not referenced to the input value.
What am I doing wrong?
Thanks,
Michael
palcal
Posted: 10:13pm 30 Nov 2013
Michael,
Try
SetPin 1,1
V=Pin(1)
Print V
Paul.
palcal
Posted: 11:51pm 30 Nov 2013
Michael,
Your code should work the only reason I suggested the change is because it is what I have used to read the value from a temperature sensor, and it works fine.
But I just had a thought, make sure you have actually connected to pin 1 it can get confusing. If pin 1 is floating you probably will get funny readings.
Paul.
Posted: 09:34am 01 Dec 2013
Pin 1 has a maximum allowed input of 3.3V. Connect your pot to 3.3, not 5V.
With the readings your are getting, I agree with Paul, you have an open circuit or floating input.
paceman
Posted: 02:59pm 01 Dec 2013
Another possibility is your Gnd reference. Are you using the Maximite Gnd and 3.3v - if not, try them.
Greg
mcmichael
Posted: 06:17am 02 Dec 2013
Hello Experts,
thank you vermy much for your replies - I've found the mistake.
It was none of the leads you mentioned - I looked at
the connection diagram the wrong way around.
Now everything is fine and my joystick is working.
have a good time!
Bye,
Michael
