Local Time 06:10 24 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : DMA2D Advantages for Graphics in MCU Apps
camguy
Posted: 04:06am 24 Dec 2013
DMA2D (2D direct memory access) peripheral in an MCU can treat graphics used in a GUI with very little code and core processing time.
When we saw the DMA2D with integrated SDRAM and LCD controllers on the STM32F429, it was clear that this integration marked a revolution in graphics use in MCU apps.
Francis Lamotte describes the DMA2D implementation and shows how it is used in this article:
http://www.embedded.com/design/mcus-processors-and-socs/4426 244/2/Building-eye-catching-GUIs-for-your-embedded-MCU-desig ns
Source code for his demo application is provided at stm32circle.com
darthmite
Posted: 06:24am 24 Dec 2013
Will be interesting to know from where they get the STM32F429 chip , no other can
get them actually.
About the CircleOs , well , we have allot other OS on stm32 (and open sourced)
Better will be to have the source from the library , the source code for use the library is useless without the 'what' is making the stuff working.
I do myself test on st429i disco board (little modified).
My modded board
My FULL library will be posted on ST Forum until i have clean the code ;)
It work perfectly with 16Mb expansion , VGA Video , Wii Classic , 2 x tm1638 and
SD Card.
it have :
Graphics on VGA at 240x320 , 320x240, 640x650 , 640x400, 640x480 , 720x400 at 16bit.
Wii Classic game controller library.(2 pins I2C)
tm1638 for LED segments + allot of button control (3 pins SPI)
SD Card Library.
And it use the DMA2D and LTDC ;)
The schematic for the little expansion board is still on rev1.0 page.
(if you don't build it , then just made a little R-2R DAC for the video).
Here you go away from the microscopic disco board LCD ;)
Cheers.
PS : i was reading the ST Forum in same time i written this post here and .. oh !
i found this : hmmm ...
Edited by darthmite 2013-12-25
camguy
Posted: 01:05am 06 Jan 2014
CircleOS is more in the class of an application scheduler, as opposed to a full featured embedded OS. It is intended to provide a level of abstraction that makes it easier to write an application for STM32.
That said...
All of the sources for CircleOS, the DMA2D implmentation and about 100 sample applications are available at stm32circle.com
If you have any questions don't hesitate to ask or to post your questions on the forums at stm32circle.com.
Cheers,
Edited by camguy 2014-01-07
