Local Time 19:13 21 Jun 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Settick
OA47
Posted: 07:42pm 24 Jan 2014
I have an interupt set for every 10 minutes to check and analyse pins.
SetTick 600000, CheckAnalogs,1
Is there a way of calling this interupt routine at program startup without having to duplicate the code as a subroutine?
OA47
Posted: 08:04pm 24 Jan 2014
OK. Should have thought longer, I set a flag on startup and gave the routine a RETURN if the Startup flag was set, before the IRETURN.
Startup=1: GOSUB CheckAnalogs
CheckAnalogs:
If Startup=1 then Startup=0: RETURN
IRETURN
Posted: 08:11pm 24 Jan 2014
firstrun = 1
settick 100, CheckAnalogs, 1
do
loop
end
CheckAnalogs:
if firstrun = 1 then
settick 600000, CheckAnalogs, 1
firstrun = 0
endif
print "Checking at "+time$
ireturn
MicroBlocks
Posted: 09:12pm 24 Jan 2014
You might want to consider using defined Subroutines.
It will also stop code going into a subroutine unwanted.
You could then call that subroutine the first time and also use it for an interrupt routine.
You do not need to use an IRETURN when using defined subroutines.
It makes code easier to write and reuse.
[code]
CheckAnalogs
do
loop
SUB CheckAnalogs
END SUB
[/code]
Edited by TZAdvantage 2014-01-26
