Forum Index : Microcontroller and PC projects : MM Edit bug fix
Posted: 02:15pm 28 Mar 2014
There was a bug in MM Edit which prevented 'Run in DOS' from loading your program if your file pathname has spaces in it.
A common problem which I should have allowed for a long time ago.
There was another bug which sometimes appeared when loading one line programs - not a common action.
You can replace MMedit.tkn with the one in the attached ZIP
2014-03-29_001304_MMedit.zip
or download the latest full version for my website.
http://www.c-com.com.au/MMedit.htm
I haven't made any other changes so there may still be a few commands missing from the syntax help.
Posted: 03:31pm 28 Mar 2014
Some more good news.
The author of Liberty Basic (the basic I used for MM Edit) will shortly release an update which should solve the problems with Windows 8.1 touch screens.
The maximum speed for serial ports will also be increased.
Both the above were annoying problems so I will be pleased when the update arrives.
