Local Time 17:11 19 Jun 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : LCD with 4.5
heppy36
Posted: 12:21pm 31 May 2014
Hi I was reading the manual on the V 4.5 for the maximite,I want to read voltage on a pin.
The manual has this example
LCD INIT 2, 3, 4, 5, 23, 24
LCD 1, 2, "Temperature"
LCD 2, 6, STR$(DS18B20(15))
to read voltage or data on pin 5 would I just go
LCD 2, 6, STR$(5)
Sorry if you have answered it before
Thank you
Martin
Heppy
Posted: 12:57pm 31 May 2014
First, you have to set the pin to analogue in
SETPIN 5, AIN
then use
LCD 2, 6, STR$(PIN(5))
You may want to format the output before displaying it.
heppy36
Posted: 01:02pm 31 May 2014
will it refresh automatic ,or do I need code to keep looping the pin?
Heppy
Posted: 02:13pm 31 May 2014
Yes, you would need to have a loop of some sort.
It's up to you to decide how often you want to update the display.
Posted: 04:37pm 31 May 2014
If you're using pin 5 as part of the LCD data-lines, can you also use it to measure the analog voltage at the same time?
Maybe you can, but I thought that once it is taken by the LCD routine, it is reserved for that command until you issue an LCD CLOSE command to release the pins.
Posted: 05:33pm 31 May 2014
You are right Grogster, I didn't notice that in the original code.
Having an analogue input feeding the same pin that talks to the LCD would be a problem.
heppy36
Posted: 08:56pm 31 May 2014
Thanks Pin 5 was just a example (I will use pin 6 and 7)I would like to monitor my O2 sensors on my engine
Heppy
heppy36
Posted: 12:14am 10 Jun 2014
Hi I bought my LCD,went to wire it up ,but I gather D4 to D7 got to pins 2 to 5,but the RS and EN ,I don't have a pin 23 and 24 on my org maximite?
Can anyone help me?
Thanks Martin
Heppy
MicroBlocks
Posted: 04:05am 10 Jun 2014
Use any pin you like/have available.
You then use LCD INIT with the pin numbers you connected to the LCD , that will tell the firmware how to control the LCD.
Edited by TZAdvantage 2014-06-11
Posted: 07:21am 10 Jun 2014
does the maximite have commands built in to drive an HD44780 LCD? i thought only the micromite had the LCD commands built in, and that with the maximite you had to put together your own routines - not that it is too difficult.
rob :-)
BobD
Posted: 07:43am 10 Jun 2014
V4.5 of MMBasic for the Maximite introduced the LCD command as well as many or all of the features from the Micromite.
heppy36
Posted: 11:50pm 10 Jun 2014
Thank you ,I made 11 and 12 the rs and e
And it worked great,I was just measuring 0 to 1 Volt on pin 7
40 SETPIN 7,AIN
50 LCD INIT 2, 3, 4, 5, 11, 12
60 LCD 1, 2, "O2 Voltage"
70 LCD 2, 6, STR$(PIN(7))
80 print "O2 Level is" pin(7)
90 pause 500
100 goto 70
Heppy
heppy36
Posted: 08:30am 11 Jun 2014
Hi can anyone tell me the command to clear the LCD ,before next read
Thanks again Martin
Heppy
jman
Posted: 09:20am 11 Jun 2014
LCD CLEAR will erase all data displayed on the LCD
