Local Time 19:04 21 Jun 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PWM no longer ’ backround ’
hitsware
Posted: 02:15pm 22 Jun 2014
CMM
I just upgraded from 4.1 to 4.5 and now
PWM does not stay running
It does work, but only if I put it in a
loop ...... ?????
The change log says something about the
commands have changed, but I see nothing
reflected in the manual ???
Posted: 02:41pm 22 Jun 2014
It seems to work OK for me.
I tried a single line
PWM 2000, 10, 50
and
PWM 20000, 10, 50
on a CMM (UBW32) and the main program ran as normal
It looks like the order of CH1 and CH2 were swapped in the change to V4.5 but I can't see any other differences apart from some changes made to make a PWM change in duty cycle less 'jumpy'
What settings are you using?
hitsware
Posted: 04:29pm 22 Jun 2014
> PWM 2000, 10, 50
> and
> PWM 20000, 10, 50
BUT !
Did you have PWM output !?!?!?
Posted: 04:52pm 22 Jun 2014
  hitsware said   >
BUT !
Yes.
The first channel (CH2) was on the right audio out and the second (CH1) was on the left audio out.
I think that the channels have been swapped.
Posted: 05:27pm 22 Jun 2014
I don't have the code with me to check but it could be that the PWM output is stopped at the command prompt.
Are you running the PWM command in a program or at the command prompt?
Posted: 05:41pm 22 Jun 2014
The PWM stops when the program stops.
I test with Ctrl-C.
I am not sure what happens when the program stops with an error.
hitsware
Posted: 04:56am 23 Jun 2014
Circuit Gizmo ColorMax ..... 4.5
At boot up prompt
PWM 10000,50,50
works ....
If I
LIST
and then
RUN
it kills it ....
OR if I
EDIT
and then
RUN
It won't work again until I do
NEW
I'm sure it was OK with 4.1 because I was using it just before upgrade.
I seem to remember something similar with 4.4, but I'm not sure .....
hitsware
Posted: 09:07am 23 Jun 2014
FWIW
4.4 on DuinoMite Mega acts the same
Using line numbers gets rid of problem .
Posted: 04:43pm 23 Jun 2014
I am not sure what the problem is. The NEW and RUN commands reset the state of the interpreter. Is this what is concerning you?
hitsware
Posted: 05:58pm 23 Jun 2014
As I understood the PWM command
( and it seemed to work w/ver 4.1 )
PWM turns on a hardware oscillator
with output parameters that can only
be modified by further PWM commands ...
I.E.........
PWM 1000,50,50
should result in 1kHz squarewaves on
left and right pwm output pins until
another PWM command
As it is now any doings (for lack of a better term)
with the program turns off the free running timers ....
Posted: 06:18pm 23 Jun 2014
Well (without going through the source) I don't think that this aspect has changed. And anyway, the PWM command is supposed to be used in a program, so what does it matter if the NEW and RUN commands stop it?
I suspect that this is must be a misunderstanding due to our different customary languages.
hitsware
Posted: 01:37pm 24 Jun 2014
Thank You Geoff ,
Today everything seems fine :) Perhaps I wasn't holding my mouth right .
Besides upgrading the version , I switched back from using a PC terminal
to straight in and out of Maximite board . Gives everything a little differant
' feel '
MegaRegards ,
Michael Miller
