Local Time 18:05 21 Jun 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Set MicroMite COM2
edu001
Posted: 11:02am 16 Jul 2014
Hi
I am trying to set the com2 port on my micromite to:
50 baud, 8 bits, no parity, 2 stop bits
Could somebody guide me through the port setup I have done OPEN "COM2:50" AS #2 so far
I already have com 1 reading the GPS and transmitting to com 2
Posted: 12:28pm 16 Jul 2014
You have to use COM1 if you want to have 2 stop bits.
Can you swap the GPS to com2?
I think that COM1 is capable of non standard baud rates. I am not so sure about com2.
After that,
Can you test the output with a CRO. A common problem is the output is the inverse of what you are expecting.
edu001
Posted: 08:06am 17 Jul 2014
Thanks for the tip
Its now transmitting RTTY 50 Baud on com1 :)
