Forum Index : Microcontroller and PC projects : ASCII - CURSOR OFF
| rentner111 Newbie Joined: 18/03/2014 Location: AustriaPosts: 19 |
09/28/2014 Hi Geoff! CURSOR OFF / ON For a more detailed explanation of using: I use a Displayset only for displaying text. In this case, the cursor is simply annoying. Therefore I would like the cursor off. In VT52 mode, there are ESC [e = SHOW CURSOR ESC [f = HIDE CURSOR Is it provided by you to incorporate these commands at the earliest opportunity? With thanks |
ESC [f is used in VT100 mode for 'cursor home'. The only references I can find for hide/show cursor are VT52 mode ESC e and ESC f (That is without the '[' character.) I will try and test them on a 'real' DEC terminal I have but it won't be today. Jim PS The reference was in some Atari documentation http://toshyp.atari.org/en/VT_52_terminal.html#VT-52_20termi nal VK7JH MMedit |
