Local Time 18:05 21 Jun 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Micromite stable/mature enough ?
atmega8
Posted: 04:36am 06 Oct 2014
Hi ,
would like to let a micromite to control the temperature of my
expansive Aqua Tank/fishtank.
Any suggestions if micromite/mmbasic is stable enough?
May the use of the watchdog give more reliability?
THX
plasma
Posted: 04:49am 06 Oct 2014
If the powersource stable and without spike from
Switching some relais or other connected things
I would say yes its solid and runs over years.
Posted: 09:58am 06 Oct 2014
@atmega8
Several members have posted stories here regarding having had their MicroMites running for several months without issues.
I personally have many MicroMites around the home doing various things 24/7.
I always include a software WatchDog in situations where it is important that the MicroMite keep running.
As Plasma says, ensure a good supply; and relevant isolation if required to control mains powered devices.
So I really don't see any issue for you using a MicroMite driving your aquatic set-up.
There are enough people here to help you out if you need assistance - most of us are friendly enough
WW
Posted: 12:22pm 06 Oct 2014
My coffee machine controller has been running without any problems for a couple of months.
The only thing I forgot to do was to set OPTION AUTORUN ON
I had the power off briefly and forgot to check that it had started.
I will put a slow pulsing LED on it so I can see at a glance that it is working.
I have a maximite environmental monitor that has not been touched for 333.5 days so I think that MMBasic is reasonably stable.
