Forum Index : Microcontroller and PC projects : uMite vs mini MaxMite
samuelT
Posted: 07:29am 21 Oct 2014
Hello:
I am new and am deciding which Mite to start with.
q1) Does the mini-MaxiMite have more software capabilities than the uMite 170?
q2) If i were to use the mini-MaxiMite, can I use the VGA and other special purpose
ports as regular digital I/O?
q3) I see the newer post are with regard to the uMite so should i not be looking
at the mini-MaxiMite to begin my adventure.
q4) Does any one do development with a MAC and if so what terminal emulator is used?
Thank you much for you patience.
samT
plasma
Posted: 07:58am 21 Oct 2014
i use vmware in osx or an old laptop with xp.
MicroBlocks
Posted: 08:24am 21 Oct 2014
I am secretly hoping for a MicroMite based on the MX795. :)
With 6 comports, 4 SPI's, 5 I2C's etc... massive amounts of memory, USB...... :)
I think it would kill anything on the market.
palcal
Posted: 11:22am 21 Oct 2014
I guess it depends on what you want to use it for. The original Maximite was designed as a small computer similar to those of the early 1980s. The mini Maximite was a smaller version that could be built with or without the SD card, keyboard and video so could be used as an embedded controller.
The Micromite is really designed to be an embedded controller, you program it use it in a project and there it stays.
Have you been to Geoff's web site.Here
Paul.
Edit. Sorry the link doesn't work properly but it will get you there.Edited by palcal 2014-10-22
Posted: 11:39am 21 Oct 2014
The micromite is low power low parts count designed for imbedding in your project.
The Maximite has the VGA/composite, crystal controlled for better timing, designed as a stand-alone with your sensors/interface added as needed.
The maximites are easily upgraded, the micromite needs more effort to upgrade but there has been a lot of work done by members of the forum to make it easier (and cheaper).
The maximite has storage, the micromite doesn't.
Zonker
Posted: 04:17pm 21 Oct 2014
Oh... And welcome to the Forum Sam..!
There is a nice group of really smart people here... Enjoy..!
Posted: 06:44pm 21 Oct 2014
why does someone not resurrect the mini-maximite? an 'extra wide' package similar in appearance to the 44-pin DIP PCB being produced for the 44-pin micromite, with SD card socket at one end and pin-headers for VGA and PS/2 keyboard at the other. in between two rows of pins down the long sides bring out all the I/O pins.
as i recall, the big killer for the mini maximite was the high cost of the kit. but as a cheap blank PCB it might be more attractive today.
just my 2 cents worth,
rob :-)
Posted: 09:02pm 21 Oct 2014
  robert.rozee said   why does someone not resurrect the mini-maximite? an 'extra wide' package similar in appearance to the 44-pin DIP PCB being produced for the 44-pin micromite, with SD card socket at one end and pin-headers for VGA and PS/2 keyboard at the other. in between two rows of pins down the long sides bring out all the I/O pins.
rob :-)
. . . . be patient - something coming
WW
kiiid
Posted: 09:22pm 21 Oct 2014
rob :-)
That exists for 1.5 years now. See ICeemite and DEB2-1001W68. Of course some people are acting the emu way putting their heads in the sand, but that does not change the fact it is out there
http://rittle.org
