Local Time 17:09 19 Jun 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : HEX$ problem
edu001
Posted: 10:25am 04 Nov 2014
Hi
This might be a simple fix!
I am converting this number--945736--to HEX using HEX$
The output I get is E6E48
The output I require is 0E6E48 as it forms the last 6 digits of an 8 digit hex number
Is there any way to stop HEX$ dropping the first 0
cwilt
Posted: 10:32am 04 Nov 2014
I ran into this as well and did not find a simple solution besides converting to a string and adding the required number of zero's.
x$=hex$(945736)
y$=string$(8-len(x$),"0")+x$
I would be interested if someone has a better solution.
edu001
Posted: 10:39am 04 Nov 2014
Thanks cwilt
I can do it that way but the initial number is entered by the user so the hex output changes
I have been fighting this all afternoon!
mindrobots
Posted: 10:51am 04 Nov 2014
cwilt's solution might be the best for MMBASIC 4.5
Version 4.6 adds a 'chars' parameter to the BIN$, HEX$ and OCT$ to indicate number of characters in the output string and will pad with zeroes as needed.
BIN$(number [,chars])
HEX$(number [,chars])
OCT$(number [,chars])
It appears Geoff knew you would have this problem and fixed it in advance!
edu001
Posted: 11:05am 04 Nov 2014
  mindrobots said   cwilt's solution might be the best for MMBASIC 4.5
Thanks it sounds like that could be the solution is 4.6 due for release
cwilt
Posted: 11:08am 04 Nov 2014
Good point mindrobots.
I often forget that there are 2 different platforms, Maxi and Micro.
Posted: 01:07pm 04 Nov 2014
Try this function.
It should work the same on all versions of MM Basic.
If you enter -1 for the number of characters the function returns the string padded to an even number of characters.
DO
INPUT x
PRINT myHEX$(x,6)
PRINT myHEX$(x,8)
PRINT myHEX$(x)
PRINT myHEX$(x,-1)
LOOP
END
FUNCTION myHEX$(number,chars)
' chars = 0 same as HEX$
' chars > 0 pads to that number of characters
' chars < 0 pads to an even number of characters
myHEX$=HEX$(number)
IF chars > LEN(myHEX$) THEN
myHEX$=STRING$(chars-LEN(myHEX$),"0")+myHEX$
ELSEIF chars < 0 AND LEN(myHEX$) MOD 2 > 0 THEN
myHEX$="0"+myHEX$
ENDIF
END FUNCTION
MicroBlocks
Posted: 06:46am 06 Nov 2014
If you need it only once in your code a simple oneliner is:
[code]
Result$=RIGHT$("00000000" + HEX$(945736), 6)
[/code]
As a function:
[code]
FUNCTION ToHex$(number, minlength)
ToHex$ = RIGHT$("00000000" + HEX$(number), minLength)
END FUNCTION
[/code]
cwilt
Posted: 07:21am 06 Nov 2014
Nice alternative code. Will do some tests to see which is quicker.
  TZAdvantage said   If you need it only once in your code a simple oneliner is:
[code]
[/code]
As a function:
[code]
END FUNCTION
[/code]
