Forum Index : Microcontroller and PC projects : Forcing leading zeros
| Lee3 Regular Member Joined: 17/09/2014 Location: AustraliaPosts: 57 |
I've written some code that adds a number of minutes to the current time, and outputs a new time. This is on a umite. e.g 23:00 + 125 minutes = 01:05 instead in this case what I would get is 1:5 is there a way of forcing a leading zero? I could probably do something with if/then/length operators to decide if the number has 1 or 2 digits, and add a zero, but I suspect there is a much more elegant way ahead.... :) Cheers Lee |
For the micromite, STR$ will do what you want: h=1
m=5 s=0 myTime$=STR$(h,2,0,"0")+":"+STR$(m,2,0,"0")+":"+STR$(s,2,0," 0") print myTime$ Jim VK7JH MMedit |
Thanks Jim will try it out tonight. Lee |
@Lee3, Be careful to remove that extra space that the board has dropped into Jim's "mytime$=... line there Lee - near the end. The last expression doesn't contain a space, it should be +STR$(s,2,0,"0"). It's an ongoing problem that the bulletin board has whenever a long string is posted without any spaces. Greg |
And it was only the other day that I pointed out that you can ofter get arround the extra space problem by putting your own spaces where they don't cause problems: h=1
m=5 s=0 myTime$=STR$(h,2,0,"0")+":"+ STR$(m,2,0,"0")+":"+ STR$(s,2,0,"0") print myTime$ I should pay attention to myself more often. Jim VK7JH MMedit |
I remembered that Jim but didn't like to mention it. |
I saw that space, wasn't going to put it in.... :) Then I saw in the manual this is all spelled out.... |
