Local Time 18:19 21 Jun 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Using VAL with PWM
edu001
Posted: 11:59pm 16 Dec 2014
Hi
I posted a question about Lookup tables earlier this is not a Bump but a code question
I am sort of getting somewhere with generating tones using the table, I have converted this
{ 1,15, 9}, { 1,15,10}, { 1,15,11}, { 1,15,12}, { 1,15,13}, { 1,15,14}, { 1,15,15}, { 2, 8, 8} to this
DIM A(8) AS STRING
DATA "1,15, 9"," 1,15,10","1,15,11","1,15,12","1,15,13","1,15,14","1,15,15"," 2, 8, 8"
FOR B = 0 TO 7
READ (A)B
NEXT B
What I need to do is use the 3 numbers in each element ie: "1,15,9" to generate sequential tones, then add a fixed delay before moving onto the next element, this is what I have tried
DO
FOR B= 0 TO 7
PWM 1, 2500, VAL(A(B))*5
PAUSE 64
NEXT B
My initial problem is that only reads the first character in the sequence not all three
And maybe a bigger problem is that I cannot DIM the complete array which is 256 elements
Jed
Posted: 12:27am 17 Dec 2014
Your first problem is the READ statement - it should be READ A(B)
Then you need to parse the strings to extract the three numbers. Have a look at the INSTR function. Use it to find the commas and then use LEFT$, MID$ and RIGHT$ to get the individual numbers for the VAL function.
I could give you the code but it is better if you try yourself and ask for more help if needed Edited by matherp 2014-12-18
edu001
Posted: 12:35am 17 Dec 2014
  matherp said   Your first problem is the READ statement - it should be READ A(B)
Thanks matherp
My sentiments exactly I don't want it done for me that achieves 0
Posted: 12:49am 17 Dec 2014
Actually looking at your data again if you used leading spaces in the strings (as in the C code) to make all the strings the same length you wouldn't need INSTR and could just use LEFT$, MID$ and RIGHT$ because you would know where the commas are.
MicroBlocks
Posted: 02:35am 17 Dec 2014
Also look at LENGTH when dimensioning an array.
Now each string will reserved 256 bytes using too much memory
A length of 8 would be sufficient.
edu001
Posted: 02:38am 17 Dec 2014
Ok maybe a bit untidy but it works
do
for B = 1 to 120
vcode1$ = LEFT$(mid$(A(B), 1), 2)
vcode2$ = left$(mid$(A(B), 4), 2)
vcode3$ = right$(mid$(A(B), 1), 2)
pwm 1, 50000, val(vcode1$)*6
pause 64
pwm 1, 50000, val(vcode2$)*6
pause 64
pwm 1, 50000, val(vcode3$)*6
pause 64
next B
loop
Now to sort the arrays out
Ill will have to do that TZAdvantage
edu001
Posted: 02:48am 17 Dec 2014
Tried Dimensioning the array with
DIM A(256) LENGTH 8
Error: Not Enough Memory
Posted: 02:54am 17 Dec 2014
Try: DIM STRING A(256) LENGTH 8
works for me uses 3K memory as expectedEdited by matherp 2014-12-18
edu001
Posted: 03:16am 17 Dec 2014
  matherp said   Try: DIM STRING A(256) LENGTH 8
That worked :)
edu001
Posted: 03:18am 17 Dec 2014
That worked :)
Actually I was trying DIM A(256) AS STRING LENGTH 8
That didd'nt work
Posted: 03:48am 17 Dec 2014
If you took the quotes out of the DATAs you could simply use READ and drop all the strings.
(In effect it's like using INPUT but the value comes from DATA.)
MicroBlocks
Posted: 05:15am 17 Dec 2014
That would work good too. Storing it would use more space as each value is then at least 4 bytes in memory.
Combining the 3 values into one would save some.
[code]
READ A
READ B
READ C
Values(count) = A + B * 16 + C * 256
[/code]
But going through that exercise is only worth it when memory gets scarce or speed of execution is not fast enough.
Maybe use DIM STRING A(256,3) LENGTH 1. That will use only about 1200 bytes of memory and might be easier to work with as it has the same structure.
Each value can then be stored with CHAR() and retrieved with ASC().
In the newest version arrays can be initialized directly. That would save even more as no more data statements are necessary.
Another solution would be to treat the DATA statements as the storage and use READ statements in the loop, and then use RESTORE to reset reading from the top.
This would be the most memory efficient as it will not be stored in RAM (is stored along the program in flash) with some sacrifice in speed and usability.
Edited by TZAdvantage 2014-12-18
edu001
Posted: 12:03pm 17 Dec 2014
  JohnS said   If you took the quotes out of the DATAs you could simply use READ and drop all the strings.
Thanks JohnS
The way DominoEX16 (earlier post) works means that the array must stay intact as each character consists of 3 nibbles ie: the character < ASCII 60 is "0,8, 10"
edu001
Posted: 09:30am 18 Dec 2014
  TZAdvantage said   That would work good too. Storing it would use more space as each value is then at least 4 bytes in memory.
[code]
READ A
READ B
READ C
[/code]
edu001
Posted: 09:37am 18 Dec 2014
[code]
READ A
READ B
READ C
[/code]
Should DIM STRING A(512,3) LENGTH 1 work as the arrays need to be indexed together
I am getting an error on this line
FOR B = 0 TO 511
READ A(B) the error occurs here "error number of dimensions"
NEXT B
Posted: 10:18am 18 Dec 2014
If you create a multidimensional array, you need to specify all dimensions each time.
OPTION BASE 0
FOR B = 0 TO 511
READ A(B,0)
READ A(B,1)
READ A(B,2)
NEXT B
AS you are using a string array, the data statements need to be single length strings, which could be difficult, or you need to convert the data from decimal to strings with chr$()
something like:
OPTION BASE 0
FOR B = 0 TO 511
READ X, Y, Z
A(B,0) = CHR$(X)
A(B,1) = CHR$(Y)
A(B,2) = CHR$(Z)
NEXT B
Edited by TassyJim 2014-12-19
edu001
Posted: 09:51pm 18 Dec 2014
Ok I am a little stuck at this point
So far I have sorted out sending the tones using PWM, and I have extracted the ASCII values from my string that I need to transmit
I think the table DIM is going to work
The next step is to match my ASCII value to the varicode table and send the three tones with a 64ms delay, here is a reference http://www.qsl.net/zl1bpu/MFSK/DominoEX%20Varicode%20Table.p df
Is it possible for instance to count the segments according to the ASCII value ie: E = 69 so count 68 then 256
so that the 2 tables are read then another 64ms delay and so on
Jed
edu001
Posted: 06:48am 19 Dec 2014
I have made some progress:)
I can successfully read the tables in the correct sequence
The problem I am having now is that when I read the nibbles 3,8,0
like this
syma = val(LEFT$(mid$(A(txtchr), 1), 2))
symb = val(left$(mid$(A(txtchr), 4), 2))
symc = val(right$(mid$(A(txtchr), 1), 2))
It retains the trailing 0 likewise for 0,10,8 It retains the leading 0
Is there a way I can read the table and remove any single 0's
edu001
Posted: 07:04am 19 Dec 2014
  edu001 said   I have made some progress:)
like this
Just reading up on DominoEX16 if the 0 is the first of the 3 nibbles it has to stay
