Local Time 17:08 19 Jun 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MM Edit update V3.5.12
Posted: 03:34pm 31 Dec 2014
Today's update should fix a problem caused by my earlier change which didn't release the serial port. The connection now automatically clears 20 seconds after closing the Chat and File windows (unless disconnected manually). This allows unplugging USB devices without drama.
The port number is remembered and reconnection should happen automatically when required.
There is a new button for disconnecting. Because it only appears when a connection is established, it also acts as a connection indicator.
I have also reverted to an earlier version of the runtime exe so 'drag and drop' to the desktop shortcut works again.
MMEdit still can't talk to the VT100 ASCII terminal.
http://www.c-com.com.au/MMedit.htm
If you don't want the full program and are running a recent version of MMEdit, the files in this ZIP are all that need to be changed:
http://www.c-com.com.au/stuff/MMedit.zip
