Local Time 19:03 21 Jun 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Micro/Maximite Comparison Info
factus10
Posted: 02:16pm 04 Jan 2015
Someone asked in another post about comparisons between the Micro- and Maximites, so I've started building a table in a Google Spreadsheet, here:
Mite comparison
Let me know if you want to edit it and I'll add you.
Best,
David
Edited by factus10 2015-01-06
atmega8
Posted: 02:24pm 04 Jan 2015
you should add a line with devices like, DS18B20 and so on....
factus10
Posted: 03:42pm 04 Jan 2015
Yep, definitely. It's a work in progress.
mpep
Posted: 04:20pm 04 Jan 2015
Hi David,
That was me. Thanks for that.
Certainly makes it a bit easier to find out functionality, RAM size etc.
Much appreciated.
However, now you need a way to ensure that new comers can find it in amongst all the posts in the forum.
MPep
factus10
Posted: 04:31pm 04 Jan 2015
Once I get to a reasonably complete state, I'm going to ask Geoff to put a link somewhere prominent :)
paceman
Posted: 09:46pm 04 Jan 2015
David,
A prominent logical place is probably the sticky post Micromite MMBasic Library(s) which is kept at the top of the Topics list - have a look at that. As the sticky says, Peter Carnegie (G8JCF on this forum) maintains the Micromite libraries and Glenn (Gizmo) who runs the TBS forum keeps that post up to date when Peter sends him an update. If you PM Peter either with a link to the file or send the file to him he can put another link line in the sticky post to access the file.
Greg
Justplayin
Posted: 11:06am 05 Jan 2015
Noticed a small error in the comparison chart... The Original Maximite has one PWM and the Color Maximite has two. The chart has them reversed.
Under CPU speed for the all the Micromites, you might indicate "Software configurable (5MHz-48MHz)". Probably should also indicate the Maximites have SD program and data storage capability where the Micromites don't.
--CurtisEdited by Justplayin 2015-01-06
factus10
Posted: 12:00pm 06 Jan 2015
Thank you, Curtis. I caught that too.
I've updated the spreadsheet with as much info as I could find so far. I'll add internal and SD storage info soon.
Justplayin
Posted: 08:07am 07 Jan 2015
Here are some "Program Size" numbers for the Mono/Color Maximites. If you disable the VGA on the Maximites and just use the terminal interface, you have more free RAM your applications.
Monochrome - Video ON
86kB Free
Monochrome - Video OFF
112kB Free
Color - Video ON
31kB Free
Color - Video OFF
107kB Free
--Curtis
atmega8
Posted: 11:17am 07 Jan 2015
MX 250?
Geoff can answer the pluspoints of The 250?
More Flash/ RAM?
factus10
Posted: 10:44am 08 Jan 2015
Thank you, Curtis. I've added those numbers to the spreadsheet.
factus10
Posted: 11:19am 08 Jan 2015
Curtis, maybe I'm being dense: how do you disable VGA? I have a Circuit Gizmos ColorMax2. I tried the following as a program:
memory
option video off
memory
Both memory commands report 34k free.
I'm using the terminal interface over USB.
Posted: 11:41am 08 Jan 2015
OPTION VIDEO only stops sending data to the display.
You need
CONFIG VIDEO OFF | ON
Justplayin
Posted: 11:42am 08 Jan 2015
  factus10 said   Curtis, maybe I'm being dense: how do you disable VGA? I have a Circuit Gizmos ColorMax2. I tried the following as a program:
memory
option video off
memory
Try:
CONFIG VIDEO OFF
A reboot is required... Also, the "CONFIG VIDEO OFF" is broken in at least one of version of MMBasic version (4.4 I think), but version 4.5 does work.
--Curtis
factus10
Posted: 11:50am 08 Jan 2015
Got it. Thank you.
atmega8
Posted: 10:35pm 08 Jan 2015
  atmega8 said   MX 250?
More Flash/ RAM?
Sorry, i meant the MX270....
factus10
Posted: 05:19am 17 Jan 2015
Hi all,
I dug into an older Micromite doc and added info for the MkI. I also simplified some of the display overall. Here's the public view .
