Local Time 18:20 21 Jun 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMbasic DHT21 bug?
MipsyKing
Posted: 06:20am 26 Feb 2015
Hello,
i'm experiencing a strange behaviour with MMbasic v4.6 and a DHT21 temperature-humidity senor. (this one: ebay
1) I connect sensor exactly like in the manual (with the pull-up resistor)
2) I program a simply loop reading sensor every 2 seconds. (no other functions called)
3) I get a long sequence of 1000,1000... 1000,1000 and only sometimes 2 or 3 REAL values, then a lot of 1000 again, and so on.
4) When values are OK, they show right temperature and humidity, so sensor is working.
5) Powering sensor at 3,3 or 5V doesnt change the problem.
6) the same sensor, connected to a PIC16f628 programmed by me in machine language is working without problems.
After all, I think problem may/seems to be (?) the MMbasic too critical about timings (?), or reading too near transation fronts instead in the middle (?), or disturbed by other interupts (?)
MipsyKing
Posted: 06:23am 26 Feb 2015
...anyother is experiencing same unreliable behaviour from MMbasic and DHT2X sensor?Edited by MipsyKing 2015-02-27
Posted: 11:34am 26 Feb 2015
There is a bug in V4.6.
At temperatures below about 25 degrees C and above 42 degrees, the error occurs.
http://www.thebackshed.com/forum/forum_posts.asp?TID=7369&PN =5
The latest version of MM Basic V4.6B has fixed the bug.
robot
Posted: 11:54am 26 Feb 2015
MipsyKing, There is a known bug that was corrected in MMBasic 4.6B
You can download this version at http://geoffg.net/micromite.html
Unfortunately you have to flash the micro again.
MipsyKing
Posted: 07:47am 27 Feb 2015
Many thanks to both!
I didnt suspect about this because i've flashed my firmware just a week ago!
But I was also in a "forced pause", caused by my PICKIT 3 incompatibily, so I didnt realize I was actually flashing a "surpassed" version. Thank again.Edited by MipsyKing 2015-02-28
