Local Time 20:12 21 Jun 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Reserved Words
Frank N. Furter
Posted: 12:10am 14 Apr 2015
Hi to all!
The second SPI example in the Micromite Manual doesn't work with "data" as variable-name. It seems that "data" is a name that is used within the interpreter...
The example works perfectly after changing "data" to another name.
Does a list exists with reserved words like "data"??? - it would be very useful...
Thanks!
Frank
twofingers
Posted: 12:39am 14 Apr 2015
Hi Frank!
I recently had the same problem!
DATA is for READ/DATA, as you certainly knows.
Michael
Justplayin
Posted: 06:03am 14 Apr 2015
This is is not meant as a wise crack answer, but the Geoff's Maximite and Micromite manuals are and excellent source for that information. All the commands, functions and predefined variables are nicely listed.
--Curtis
Posted: 03:03pm 14 Apr 2015
This is my list for the uM Mk2
  Quote   ABORT ABS ABS( AIN AND AS ASC ASC( ATN ATN( AUTOSAVE BASE BAUDRATE BIN BIN$ BIN$( BYTE CASE CFUNADDR CFUNCTION CHR CHR$ CHR$( CIN CINT CINT( CLEAR CLOCKTRIM CLOSE CMD CONST CONTINUE COS COS( CPU DATA DATE DATE$ DEFAULT DEG DEG( DHT22 DIM DIN DISTANCE DO DOUT DS18B20 DS18B20( ECHO EDIT ELSE ELSEIF END ENDIF EOF EOF( ERASE ERROR EXIT EXP EXP( EXPLICIT FC FIN FIX FIX( FLOAT FOR FUNCTION GETTIME GOSUB GOTO HEX HEX$ HEX$( I2C IF INIT INKEY INKEY$ INPUT INPUT$ INPUT$( INSTR INSTR( INT INT( INTB INTEGER INTH INTL INVERT IR IRETURN IS KEYPAD LCASE LCASE$ LCASE$( LCD LEFT LEFT$ LEFT$( LEN LEN( LENGTH LET LINE LIST LOC LOC( LOCAL LOF LOF( LOG LOG( LOOP MEMORY MID MID$ MID$( MM.DEVICE MM.DEVICE$ MM.I2C MM.ONEWIRE MM.VER MM.WATCHDOG MOD NEW NEXT NOECHO NOINVERT NONE NOT OC OCT OCT$ OCT$( OFF ON ONEWIRE OOUT OPEN OPTION OR PAUSE PEEK PEEK( PI PIN PIN( POKE PORT PORT( POS PRINT PROGMEM PROMPT PULLDOWN PULLUP PULSE PULSIN PWM RAD RAD( RANDOMIZE READ RECEIVE REM RESTORE RETURN RIGHT RIGHT$ RIGHT$( RND RND( RTC RUN SELECT SEND SERVO SETPIN SETTICK SETTIME SGN SGN( SIN SIN( SLAVE SLEEP SPACE SPACE$ SPACE$( SPC SPC( SPI SPI( SQR SQR( STEP STOP STR STR$ STR$( STRING STRING$ STRING$( SUB TAB TAB( TAN TAN( THEN TIME TIME$ TIMER TO TROFF TRON UCASE UCASE$ UCASE$( UNTIL VAL VAL( VAR VARADDR VARTBL WATCHDOG WEND WHILE WORD WRITE XMODEM XOR
You will notice that words with $ and or ( are duplicated.
This list and ones for uMMk1 and Maximite V4.5 come with MMEdit.
There are certain to be a few errors and omissions.
Frank N. Furter
Posted: 08:47pm 14 Apr 2015
Hi Jim,
thanks a lot! Your list is very helpful!!! Now I can see with a short view if a word is reserved or not!
Thanks again! This list would be a great help as appendix in the manual...
Frank
