Local Time 18:19 21 Jun 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMBasic 4.6b Recursion
kwass
Posted: 06:45pm 28 Apr 2015
I'm a noob here so please excuse me if I'm missing something obvious.
I just started with playing around on a Micromite and came across what looks to be a bug in recursion. According to the manual, recursive functions should allow for a stack depth of 50, but I'm getting a stack overflow after 5 calls in this code:
Print fac(1)
Print fac(5)
Print fac(6)
Print fac(7)
Function fac(n)
If n <= 1 Then
fac = 1
Else
fac = n*fac(n-1)
EndIf
End Function
Am I doing something wrong?
Thanks,
Katie
Edited by kwass 2015-04-30
Posted: 08:03pm 28 Apr 2015
Welcome to the forum.
The program runs OK under DOS MMBasic but fails under micromite V4.6B
I don't think you are doing anything wrong.
kwass
Posted: 02:55am 29 Apr 2015
  TassyJim said   Welcome to the forum.
Thank you for the welcome and the confirmation of the problem report.
Is there a better place to officially report bugs to Geoff?
-Katie
paceman
Posted: 03:30am 29 Apr 2015
Hi Katie,
Welcome to the forum from me too. Geoff usually manages to keep a pretty good eye on all the TBS forum posts but just to make sure you can PM him from the forum. See "Private Messenger" link at the top of the posts - his member name is 'Geoffg' and he'll receive an e-mail via the forum if you message him.
Greg
G8JCF
Posted: 05:21am 29 Apr 2015
@kwass
I rewrote your test a little so that I could test it on different platforms
FOR P=1 TO 100 STEP 2
Q=0
PRINT P;" ",fac(P)," ";Q
NEXT P
FUNCTION fac(n)
Q=Q+1
IF n < 2 THEN
fac = 1
EXIT FUNCTION
ENDIF
FAC = n * fac(n-1)
END FUNCTION
and on a 4.6B micromite, it breaks at P%=7
> RUN
1 1 1
3 6 3
5 120 5
7
[13] If n% < 2 Then
Error: Stack overflow. Expression is too complex
Now, I also happen to have the STM32 beta of MMBasic aka ARMMite, and it breaks at P%=51 which is to be expected
> RUN
1 1 1
3 6 3
5 120 5
7 5040 7
9 362880 9
11 3.99168e+07 11
13 6.22702e+09 13
15 1.30767e+12 15
17 3.55687e+14 17
19 1.21645e+17 19
21 5.10909e+19 21
23 2.58520e+22 23
25 1.55112e+25 25
27 1.08889e+28 27
29 8.84176e+30 29
31 8.22284e+33 31
33 8.68332e+36 33
35 0.00000e+2147483647 35
37 0.00000e+2147483647 37
39 0.00000e+2147483647 39
41 0.00000e+2147483647 41
43 0.00000e+2147483647 43
45 0.00000e+2147483647 45
47 0.00000e+2147483647 47
49 0.00000e+2147483647 49
51
[7] Function fac(n)
Error: Too many SUB and FUN
And when run under MMBasic for DOS
1 1 1
3 6 3
5 120 5
7 5040 7
9 362880 9
11 3.99168e+07 11
13 6.22702e+09 13
15 1.30767e+12 15
17 3.55687e+14 17
19 1.21645e+17 19
21 5.10909e+19 21
23 2.5852e+22 23
25 1.55112e+25 25
27 1.08889e+28 27
29 8.84176e+30 29
31 8.22284e+33 31
33 8.68332e+36 33
35 inf 35
37 inf 37
39 inf 39
41 inf 41
43 inf 43
45 inf 45
47 inf 47
49 inf 49
51 inf 51
53 inf 53
55 inf 55
57 inf 57
59 inf 59
61 inf 61
63 inf 63
65 inf 65
67 inf 67
69 inf 69
71 inf 71
73 inf 73
75 inf 75
77 inf 77
79 inf 79
81 inf 81
83 inf 83
85 inf 85
87 inf 87
89 inf 89
91 inf 91
93 inf 93
95 inf 95
97 inf 97
99 inf 99
So it would seem that the MMBasic Interpreter's stack in the MX170 is probably quite small compared to the other platforms - to be expected given the small RAM on the '170.
So, to echo Jim, your code is quite correct.
PeterEdited by G8JCF 2015-04-30
The only Konstant is Change
twofingers
Posted: 05:34am 29 Apr 2015
I can confirm, the issue consist also with mmBasic 4.5 for MaxiMites.
I just do not understand why we have not found it sooner.
Posted: 06:23am 29 Apr 2015
The problem also arises on the MX470.
The stack size is set to 6K on both the MX170 and MX470. Changing it to 8K on the 470 I only get 2 extra levels. So it looks like there is too much stack being used.
I'll PM Geoff and ask him to look at this thread.
kwass
Posted: 06:54am 29 Apr 2015
Thank you all for the welcomes and further investigations of this.
-Katie
Posted: 07:58am 29 Apr 2015
For info:
Each level of recursion takes an extra 696 bytes off the stack
Posted: 11:38am 29 Apr 2015
  twofingers said  I just do not understand why we have not found it sooner.
Wow, yeah, exactly!
You beta test into the ground, and there are still bugs breeding deep in the code there somewhere!
VERY nice find, Katie.
Although, to be fair to EVERYONE, this example is a very complicated mathematical test, and unless specifically written such that you are calling said function from within that same function, you would never see this error.
That's what makes it a particularly interesting find. Edited by Grogster 2015-04-30
rave
Posted: 09:07pm 21 Apr 2018
Sorry folks, I'm resurrecting this old thread, since folks like me that use the CMM and MM will definitely run into this problem again, because we're still using MMBasic 4.5b or 4.4.
With a bit of experimentation I found out that there is an easy way to work around this problem using subs, which aren't causing stack overflows that quickly.
Just rewrite your function as a sub and add a parameter for the return value. The idea is to pass the result back out of the sub using parameter passing by reference. For example:
Sub fac(n, res)
If n < 2 Then
res = 1
Else
fac n-1, res ' recursive call
res = n*res
EndIf
End Sub
> fac 20, res: Print res
2.4329e+18
If you really want to use a function in the rest of your code, then add a function of the same name ( yes you can!) that calls the sub, like this:
Function fac(n)
Local res
fac n, res ' call sub
fac = res ' assign the return value
End Function
I also tried calling the sub with the fac parameter directly, like this:
Function fac(n)
fac n, fac
End Function
Which would have been really nice and compact, yet somewhat mysterious with the absence of logic . MMBasic does not complain. However, MMBasic does not apparently update the function return variable fac when passed as a reference parameter to the fac sub, although function return variables in most other cases can be set and then used just fine as I found out (e.g. assuming fac is a function, then in this function you can do things like fac = res: if fac > 1000 then fac = 1000).
I ran into this issue when converting Rob Pike's regular expression matching algorithm to MMBasic, which uses two mutually-recusive functions and I could't get even a simple regex match to work . But all is good now. Life is good .
- Rob
