Local Time 18:30 21 Jun 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : LIB - ASCII Graphics - A Start
Chris Roper
Posted: 03:42am 03 Jun 2015
Much attention has been given to having the Micromite drive various display types and the stunning Graphics that Matherp is developing show just how powerful it can get.
But the simple Console is being neglected, so I decided to have a go at remedying that omission.
Geoff's inbuilt Full Screen Editor is an example of what can be achieved on a VT100 Terminal. Many applications may only need a simple terminal based user interface and, whilst we can't do any high resolution Graphics on it,with a combination of ASCII Graphics Characters and the VT100 escape codes, a respectable Console Screen for Display and Input can be created.
So far I have only just scratched the Surface but in the process I have created a few new commands and put together a small demo to test them:
First the Use Notes:
' LIB - ASCII Graphics
' LOCATE [row, col, FG, BG]
' Positions Cursor at Row & Column and optionally sets the Foreground and Background Colours
' row defaults to 1
' col defaults to 1
' row must be specified for any other options to be specified
' See the CONSTANTS in the program for a list of Colours
' CLS
' Clears the Screen and positions Cursor at row 1, col 1
' BLANK [line]
'Clears the 'line' - Default is the top line
' RESET
' Resets The VT100 Terminal
' PSTRING( nbr, ascii )
' Prints a string 'nbr' bytes long consisting of the character representing the ASCII value 'ascii'
' Similar to STRING$ but accepts all ASCII values 0 through 255
' GSTRING$( nbr, ascii )
' Returns a string 'nbr' bytes long consisting of the character representing the ASCII value 'ascii'
' HLINE row, col, len[, fill, fst, lst]
' Draws a line starting at Row, Col, Right 'len' Columns
' fill is the character to use, default is CHR$(196) HS - Horizontal Single Line
' fst is an optional start character default is fill
' lst is an optional end character default is fill
' VLINE row, col, len[, fill, fst, lst]
' Draws a line starting at Row, Col, Down 'len' Rows
' fill is the character to use, default is CHR$(179) VS - Vertical Single Line
' BOX row, col, width, hight[, fill, style]
' Draws a Box starting at row, col of width and hight
' filled with the 'fill' character - Default fill is " " - SPACE
' style
' 0 - No Border (Default)
' 1 - Single Line
' 2 - Double Line
' FOREGROUND colour
' Self explanatory
' BACKGROUND colour
' as above
and the very early stages of a ASCII Graphics Library with a DEMO Program to give an idea of its capability's even in this early form.
Const ESC = Chr$(27)
Const BLACK=1,RED=2,GREEN=3,YELLOW=4,BLUE=5,MAGENTA=6,CYAN=7,WHITE=8
Const HS=196,VS=179,TLSS=218,TRSS=191,BLSS=192,BRSS=217,LSS=195,RSS=180
Const HD=205,VD=186,TLDD=201,TRDD=187,BLDD=200,BRDD=188,LDD=204,RDD=185
Const LSD=198,RSD=182,LDS=199,RDS=181
Const TSS=194,BSS=193,TDD=203,BDD=202
Const TSD=210,BSD=208,TDS=209,BDS=207
Const FG_RED=ESC+"[32m"
Sub LOCATE(row,col,FG,BG)
If FG > 0 Then FOREGROUND FG
If FG > 0 Then BACKGROUND BG
Print ESC+"[";Str$(row);";";Str$(col);"H";
End Sub
Sub CLS ' Clear Screen
Print ESC+"[2J";
LOCATE
End Sub
Sub BLANK (row) ' Clear a Line
LOCATE row
Print ESC+"[2K";
End Sub
Sub RESET
Print ESC+"c";
End Sub
Sub PSTRING(nbr, ascii)
nbr = nbr - 1
Print Chr$(ascii);
Loop Until nbr <= 0
End Sub
Function GSTRING$(nbr, ascii)
nbr = nbr - 1
GSTRING$ = GSTRING$ + Chr$(ascii)
Loop Until nbr <= 0
End Function
Sub HLINE(row,col,len,fill,fst,lst)
LOCATE row,col
If fill= 0 Then fill= HS
If fst = 0 Then fst = fill
If lst = 0 Then lst = fill
Print Chr$(fst);
If len > 2 Then PSTRING len-2, fill
If len > 1 Then Print Chr$(0);Chr$(lst);
End Sub
Sub VLINE(row,col,len,type,fst,lst)
If type= 0 Then type = VS
If fst = 0 Then fst = type
If lst = 0 Then lst = type
LOCATE row,col
Print Chr$(fst);
If len > 2 Then
For x = row + 1 To len - 1
LOCATE x, col
Print Chr$(type);
Next
LOCATE len,col
End Sub
Sub BOX(row,col,width,hight,fill,style)
If fill = 0 Then fill = 32
Select Case style
Case 1
hl = HS
tl = TLSS
tr = TRSS
vl = VS
bl = BLSS
br = BRSS
Case 2
hl = HD
tl = TLDD
tr = TRDD
vl = VD
bl = BLDD
br = BRDD
Case Else
hl = fill
tl = fill
tr = fill
vl = fill
bl = fill
br = fill
row = row + 1
col = col + 1
width = width - 2
hight = hight - 1
End Select
HLINE row, col, width, hl, tl, tr
For x = row + 1 To hight - 1
HLINE x, col, width, fill, vl, vl
Next
HLINE hight, col, width, hl, bl, br
End Sub
Sub GSET row, col, ascii
LOCATE row, col
Print Chr$(ascii);
End Sub
Sub FOREGROUND (colour)
Print Chr$(27)+"[3"+Str$(colour - 1)+"m"
End Sub
Sub BACKGROUND (colour)
Print Chr$(27)+"[4"+Str$(colour - 1)+"m"
End Sub
' LIBRARY ENDS
' PROGRAM STARTS
CLS
Input "After each step press enter to continue",a$
BLANK
Input "Draw a box from 4,2, 25 col wide 15 rows high with a 1 line border",a$
BOX 4,2,25,15,,1
BLANK
Input "Next we use LOCATE to add a heading",a$
LOCATE 5,10 : Print "Test Box 1";
BLANK
Input "Segment the box with a Double Line Below the Heading",a$
HLINE 6,2,25,HD,LSD,RDS
BLANK
Input "Now Divide the new box Verticaly with a Single Line",a$
VLINE 6,6,15,VS,TDS,BSS
BLANK
Input "Maybe the Heading would be better in Red?",a$
LOCATE 5,10,RED : Print "Test Box 1";
FOREGROUND WHITE
BLANK
Input "Or Green",a$
LOCATE 5,10,GREEN : Print "Test Box 1";
FOREGROUND WHITE
BLANK
Input "and now just for fun lets fill this new box", a$
BOX 6,6,21,15,176
BLANK
Input "lets change the fill", a$
BOX 6,6,21,15,178
BLANK
Input "It was beter empty", a$
BOX 6,6,21,15
BLANK
Input "But the Sidebar could be Yellow", a$
BACKGROUND YELLOW
BOX 6,2,5,15
BACKGROUND BLACK
BLANK
Input "That's all Folks - Read the Program for details ..............",a$
'Move to the second last row
Locate 23
End
I have only tested it on TerraTerm so far and would appreciate any feedback from testing on other hardware.
Next step is to add some standard widgets and try to refine the code a bit more.
Cheers for now,
Chris
http://caroper.blogspot.com/
panky
Posted: 03:13pm 03 Jun 2015
Hi Chris,
Very impressive.
Works fine on a 28 pin 170 running 4.6b to Putty on a Linux box.
Fails on a 44 pin 170 running 4.7b8 with the error
"Error: Display not configured"
CLS
End Sub
Print ESC+"[2J";
LOCATE
End Sub
If I simulate the two print statements at the command prompt substituting real values, they work OK.
Geoff, this might be one for you?
Cheers,
Doug.
viscomjim
Posted: 03:18pm 03 Jun 2015
Probably because of the CLS statement as in 4.7b8 this is part of an lcd display command.... I'm guessing???
Posted: 04:45pm 03 Jun 2015
  viscomjim said   Probably because of the CLS statement as in 4.7b8 this is part of an lcd display command.... I'm guessing???
That is correct.
To help reduce the chance of conflicts, I would prefix all the functions with 'VT_' or similar.
RESET is a good function name to avoid!
A useful set of functions.
JimEdited by TassyJim 2015-06-05
panky
Posted: 08:37pm 03 Jun 2015
@TassieJim and viscomjim,
My apologies lads, should have seen that myself
@Chris
I put VT. in front of all commands and subs etc and it all works fine under 4.7b8
I agree with TassieJim, the VT. in front takes away any chance of competing with existing commands now or the future.
Cheers,
Doug
PS. @Geoff, hope you didn't waste any time on this , sorry.
Chris Roper
Posted: 09:10pm 03 Jun 2015
Thanks Guys,
Very useful feedback.
I was rather surprised that it allowed me to create the CLS and Reset commands.
I assumed MMBasic would throw an ERROR if they were reserved words.
Initially I was trying to use the GW-BASIC Graphics command set hence the choose of Key Words, but I have deviated so far from that now I may as well rename the commands too.
I also need to look at the fact that it is console specific, it would be better if it could run over any available com: port, and preferably more than one at a time, so I will include some form of Set-up command for Screen Resolution, port etc.
Chris
