Forum Index : Microcontroller and PC projects : Micromite editor, refresh keycode in edit
sagt3k
Posted: 09:41pm 30 Jul 2015
Hi Geoff
Is there a keycode or escape sequence code to simulate a refresh video when micromite is in editor mode?
Posted: 09:46pm 30 Jul 2015
Home key twice should bring it back to the beginning of the file.
sagt3k
Posted: 01:33am 31 Jul 2015
Unfortunately it, does not work.
Try this steps:
-connect with putty or ttyemulator with your micronite
-after go in edit mode and write your code 1 row ex: 10 goto 10
-press F1 and return in editmode
-disconnect your emulator and reconnect
-you will see all black, now press twice home buttom.
-you don't see the code
-while with more rows code yes
please try it, or happen only to me?
Posted: 01:44am 31 Jul 2015
Confirming that I am seeing this 'issue' with MM+ B23 in TT on Win10.
Two lines also comes back 'blank' UNTIL you press a key and then code 're-appeared'.
But one line I can not get to 're-appear' yet!!
Anyone else seeing this in other MM's?
WW
sagt3k
Posted: 01:58am 31 Jul 2015
My sw that use micromite in remote socket with ethernet support need to reconnect with micromite. The software need to send a command for a total refresh.
Thanks for your support.
Posted: 06:39am 31 Jul 2015
@WW, what were the steps that you did to reproduce the issue?
Posted: 07:38am 31 Jul 2015
  Geoffg said   @WW, what were the steps that you did to reproduce the issue?
1> Fired up TT (Win10) with MM+ connected via the Serial Console (i.e. USB-TTL module)
2> Went into editor and typed ONE line of code
3> F1 to save it
4> Back into Editor (code can be seen)
5> Physically disconnected the USB-TTL module
6> Physically reconnected USB-TTL module (TT unresponsive (as expected) since connection got broken)
7> Restablished TT connection so comms with MM+ once again
8> Go into editor and NO CODE i.e. the ONE line of code has vanished
Note: I did not try a 'useful' line of code. If I had have done I could have tried running it to see if it was hiding in the background. Will try this later but can't do it right now . . .
Please does anyone else see this??? If so, on what firmware/device?
WW
Posted: 07:45am 31 Jul 2015
Thanks, I will add it to the list.
sagt3k
Posted: 09:37am 31 Jul 2015
Ok ...Thanks Geoff
If you need more details I can attach screenshoot and more details
