Forum Index : Microcontroller and PC projects : MM Edit Version 3.6.0
TassyJim![]() Guru Joined: 07/08/2011 Location: AustraliaPosts: 6626 |
MMedit V3.6.0 is available for download from http://www.c-com.com.au/MMedit.htm There are too many changes to provide a simple ZIP attachment this time. Changes in this version: Help file changed to CHM format with an index. I will add hyperlinks later. Support for the Micromite Plus. You can now have an unlimited number of syntax files to allow for any new devices. Support for a "library" where you can save user sub and functions. Colour support added to VT100 terminal Added ability to change default colours in editor and VT terminal. Added warnings for buffer overflow in terminal Added command line buffer in terminal ASCII mode - the last 30 commands remembered between sessions. As there are a lot of changes, there is likely to be a few problems. The Micromite Plus is still in Beta phase so there will likely be an update to MMEdit as the changes to the Plus evolve. The "check for update" menu item doesn't work. I will have that fixed for the next update. Jim VK7JH MMedit |
| WhiteWizzard Guru Joined: 05/04/2013 Location: United KingdomPosts: 2994 |
Thank-You so much for continuing to support and improve this extremely useful application
I for one use it on a daily basis so your commitment to it is very much appreciated on this small island on the opposite side of the planet!! Thanks again, WW PS: Is it still snowing there? |
| Chris Roper Senior Member Joined: 19/05/2015 Location: South AfricaPosts: 280 |
Thanks Jim, Much appreciated here in Darkest (but not as cold by the sounds of it) Africa. Cheers Chris http://caroper.blogspot.com/ |
No snow today, back to a frost this morning. Jennene hadn't played in the snow since she was a little kid Jim VK7JH MMedit |
| MikeO Senior Member Joined: 11/09/2011 Location: AustraliaPosts: 275 |
Thanks Jim, I also use MMedit daily I especially appreciated your additions that provided the Terraterm macro support, works like a charm! Looks colder but less dreary down your way than Melbourne this past week! Mike Codenquilts |
| Zonker Guru Joined: 18/08/2012 Location: United StatesPosts: 772 |
More beer money... I love your program big J..! |
Grogster![]() Admin Group Joined: 31/12/2012 Location: New ZealandPosts: 10072 |
Hi folks.
Latest version. - If you open an existing port, but not the MM port(by mistake!), you can't close the transfer window, and you then can't close MMEDIT either - you have to force a close via task manager. Not sure if Jim knows about this or not, but thought I would just post it in case. Smoke makes things work. When the smoke gets out, it stops! |
What sort of device was it? When I try to upload to my modem, MMEdit eventually gives up - as I designed it. Jim VK7JH MMedit |
@Grogster This is what you should get when trying to upload to an unknown or unresponsive device: Starting process...
Chat closed File manager closed Connection Handle: 188679712 1 Break... Break... Break... Break... Break... Break... Break... Break... Break... Break... Break... Break... Break... Break... Break... sending NEW Clearing... Clearing... Clearing... Clearing... Clearing... Clearing... Clearing... Clearing... Clearing... Clearing... Clearing... Clearing... Clearing... Clearing... Clearing... Checking device... Checking device... Checking device... Checking device... Checking device... Checking device... Checking device... Checking device... Checking device... Checking device... Checking device... Checking device... Checking device... Checking device... Checking device... MaxiMite Version V0.0 detected Error talking to maximite I have added some more code to check for closing the window. That will allow you to break out sooner. It should have gone through the above sequence eventually. Jim VK7JH MMedit |
Hey there.
I get nothing. What device? - NONE. I had accidentally selected COM1, which IS present, but had nothing on it at the time. I was supposed to select COM3. As COM1 was there to be opened, it opened it, and the window comes up for the transfer wizard, but then I can't close the window or MMEdit. Try opening a port you know is there, but does not have a MM on it, and you should see what I mean. Smoke makes things work. When the smoke gets out, it stops! |
Also, file transfer does not want to work for me. I can select the file I want on the PC, tell the transfer wizard to send it to the MM+, and that works, but the file is then not there. The process completes fine, and the transfer wizard reports "All done!" without any error messages of any kind, but when you check the files list, the file is not on the SD card. I seem to be able to read a file from the MM+ to a file on the PC, but I can't send one from the PC to the MM+ Not sure what is going on there..... I will try to make a short video of the problems and put up a link. Smoke makes things work. When the smoke gets out, it stops! |
MM+ doesn't support XMODEM to a file. All you can do at this stage is transfer into MM+ memory, much the same as the MM Geoff might add the ability to transfer to and from files but we shall have to wait and see. Once I know what's in the release version of MMBasic for the MM+, I will adapt the file manager to suit. I don't have any problems with serial ports that have nothing connected. This update has the improved exit routines. Can you test with your COM1 again. Hopefully, you can close the transfer window now but I am not sure why it hung on your system so don't be surprised if it still hangs. 2015-08-11_055929_MMedit.zip This update can only be used with V3.6.0 Replace the mmedit.tkn file in the program folder with this one. There are no other significant changes. Jim VK7JH MMedit |
Cheers.
I did not realize that transfers to MM+ memory, but now I know, that's fine. I could transfer a file on the MM+ SD card to the PC, you see, which is what was confusing me - I expected that you could also send to a file. No big deal. The COM port thing might just be my machine - I will update and post the results. Smoke makes things work. When the smoke gets out, it stops! |
Are you sure that it was a file off the SDcard that you transferred to the PC? As far as I know, with beta23, you can only transfer the program in memory in either direction. Jim VK7JH MMedit |
darthmite![]() Senior Member Joined: 20/11/2011 Location: FrancePosts: 240 |
Hi Jim
I just get the v3.6 for see the news and ... bad news ... he he . The Guru meditation say : 9 Subscript out of range: 31, cmdbuffer$() I don't have see someone complain for that on the forum , then it's probably new
It's installed on win7 x64 (v3.2 or 3.3 was ok .... times ago) And when i click ok , i have to kill the process manually . Cheers. PS: I beta test a port of MMBasic on stm32f7 and if we do the project to end I'm sure some more will come leech you page
Theory is when we know everything but nothing work ... Practice is when everything work but no one know why ;) |
I haven't been able to reproduce the error but there are a few changes I can make to (hopefully) stop it happening. I will post an update later today. Jim VK7JH MMedit |
