Local Time 17:09 19 Jun 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MM spinning knob
Posted: 10:27pm 11 Aug 2015
This is a rough mockup of a control knob - volume control etc.
Runs on MM Basic V4.7b23 for MX170 or MX470.
Tested on 7" and 2.4" displays.
' TassyJim
' spinning knob test
OPTION EXPLICIT
DIM knob_x = 120, knob_y = 120, knob_radius = 80, finger_radius = 20
DIM INTEGER knob_fill = RGB(178, 211, 213), knob_edge = RGB(024, 087, 197)
DIM n, r, angle, tx,ty
CLS
FOR n = 0 TO 360 STEP 15
r=knob_draw(knob_x,knob_y,RAD(n))
PAUSE 100
NEXT n
DO
tx=(TOUCH(X)- knob_x)
ty=(TOUCH(Y)- knob_y)
IF ABS(tx) < (knob_radius+30) AND ABS(ty) < (knob_radius+30) THEN
SELECT CASE tx
CASE 0
IF ty<0 THEN
angle = PI
ELSE
angle = 0
ENDIF
CASE < 0
angle = ATN(ty/tx)+PI/2
CASE ELSE
angle = ATN(ty/tx)+PI*1.5
END SELECT
PRINT tx," ",ty," ", DEG(angle) 'DEBUG
r=knob_draw(knob_x,knob_y,angle)
ELSE
PAUSE 100
ENDIF
PAUSE 100
LOOP
END
FUNCTION knob_draw(x,y,a)
LOCAL fingerX, fingerY
CIRCLE x, y, knob_radius,6 , , knob_edge, knob_fill ' clear knob
fingerX=x-SIN(a)*(knob_radius-finger_radius)
fingerY=y+COS(a)*(knob_radius-finger_radius)
CIRCLE fingerX, fingerY, finger_radius, 6, , knob_edge, knob_fill ' draw marker
END FUNCTION
The knob follows your finger/stylus around.
Not as nice as PeterM's gauges but a start...
Next on the list is a "slider" control.
On the MM+, it would be nice to have a new GUI object - CANVAS or ZONE etc.
It needs to respond to touch and is used for user designed gadgets.
Having to poll the touch(X) doesn't fit well with all the other GUI objects.
