Local Time 20:13 21 Jun 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Better built-in editor
kiiid
Posted: 02:30am 13 Aug 2015
I miss some basic functionality there - Ctrl-something to delete a whole line, search and replace functions, Undo/Redo...
http://rittle.org
Chris Roper
Posted: 04:44am 13 Aug 2015
That is what MM Edit is for, the MicroMite editor is damn good for VT100 in a minimal memory footprint. I tried to write one in C, for the 250F based on my experience of using the Microite 170, I have no idea how Geoff managed to get it so compact yet so usable.
http://caroper.blogspot.com/
jman
Posted: 10:07am 13 Aug 2015
I miss using the up arrow to recall the last used command
Jman
Chris Roper
Posted: 10:24am 13 Aug 2015
  jman said   I miss using the up arrow to recall the last used command
Jman
That I do agree with.
Especially on an interpretive language which makes it easy to test hardware by toggling pins from the command line.
I spoke to Peter about that in another thread and apparently the next release of CFunctions will be able to run independently and still be active whilst at the prompt, so it will be possible to create a basic line editor function.
Posted: 12:43pm 13 Aug 2015
Jman
You can do that in the latest version of MM Edit.
You probably could create a macro for Teraterm - I will have to have a play.
