Forum Index : Microcontroller and PC projects : MM+ End Sub
| Page 1 of 2 |
I have some code that works perfectly well with the 170 chip, but when I loaded it into the MM+ I have a problem. This is part of the code:- SetTick 200, POSITION, 1 ' ' ' ' ' sub POSITION If Touch(x) >215 And Touch(x) < 255 Then Latitude$ = Left$(arg$(3) ,2)+" "+Mid$(arg$(3) ,3)+" "+arg$(4) Longitude$ = Left$(arg$(5) ,3)+" "+Mid$(arg$(5) ,4)+" "+arg$(6) CLS(Yellow) Text 150,100,"CURRENT POSITION",CM,2,2,RGB(Cyan) Text 145, 140, "Lat " + Latitude$,CM,2,2,RGB(Cyan) Text 145, 180, "Lon " + Longitude$,CM,2,2,RGB(Cyan) Flags= 0 Pause 10000 GoSub Display ELSE END SUB endif GoTo START When working, if the screen is touched it branches to this SUB and displays the current position for 10 secs. before returning to the SUB DISPLAY which displays the normal screen. The problem is the settick goes to the Sub POSITION, the screen is not touched so TOUCH(X) and TOUCH(y) are both -1 (checked this) but the ELSE END SUB is not processed and the program goes to START. This code has been working perfectly with the 170 chip for many months. Paul. "It is better to be ignorant and ask a stupid question than to be plain Stupid and not ask at all" |
| BobD Guru Joined: 07/12/2011 Location: AustraliaPosts: 935 |
Paul 2 things and I can't test either. Instead of END SUB it should probably be EXIT SUB and it may need to be on the line following the ELSE. The rules may be tighter with different firmware. Bob |
Paul, BobD is correct in that the ELSE has to be on its own line with the 'else statement' also on its own line. See Page 52 of Manual (v4.7) which shows syntax for single line and multi-line IF statements. WW |
I'm running 4.7 on the 170s but it may be different in this version. Will try later. Thanks for the replies, will get back. Paul. Edit. Just altered the code and it works fine. Thanks again. Paul. "It is better to be ignorant and ask a stupid question than to be plain Stupid and not ask at all" |
Paul, With subroutines you need to make sure that it has a start and an end. Otherwise the interpreter will loose track of where it is. A subroutine starts with the word SUB followed by the name. [code] SUB mySubroutine [/code] after this line you can write the code that has to be executed when the subroutine is called. after the code you need to 'close' the subroutine with [code] END SUB [/code] This will cause the interpreter to go back to were it was when the subroutine was called. You can not jump out of a subroutine with a GOTO. The interpreter will then not see an END SUB and will think that it is still inside the subroutine. This should trigger an error but interpreters are normally not so strict. Eventually the program wil run out of memory because each time it executes a subroutine it has to remember were to go back to. If you need to get out of a subroutine use EXIT SUB. Also it is best to not use any pause in subroutines that are used with timers or interrupts. You can also consider using then new GUI commands to capture a touch. [code] Micromite Plus only. In addition, on the Micromite Plus an interrupt can be triggered on touch down and up. The following command will set up the interrupt: GUI INTERRUPT down [, up] Where 'down' is the subroutine to call when a touch down has been detected. And optionally 'up' is the subroutine to call when the touch has been lifted from the screen ('up' and 'down' can point to the same subroutine if required). Specifying the number zero (single digit) as the argument will cancel both of these interrupts. ie: GUI INTERRUPT 0 [/code] Microblocks. Build with logic. |
Thanks, I changed the code when I switched from push buttons to touch. With the push buttons I used the interrupt to set a flag and then return to the main code so it didn't spend long in the interrupt. I forgot about using PAUSE in an interrupt not being good practice. I will try the GUI INTERRUPT command or maybe go back to using the SUB to just set a flag. Paul. "It is better to be ignorant and ask a stupid question than to be plain Stupid and not ask at all" |
With TOUCH, is is a good idea to store the X Y values quickly then do you tests. The touch(X) will be constantly changing and that can make life interesting when you are trying to do tests. SUB tapped
LOCAL tx,ty tx=TOUCH(X) ty=TOUCH(Y) IF ty < 120 AND ty >0 THEN etc... Be prepared for some -1 values as the finger leaves the screen. Jim VK7JH MMedit |
When using the GUI INTERRUPT command, can I have more than one interrupt. I tried it and only one interrupt works. Reading the manual I don't think I can. Paul. "It is better to be ignorant and ask a stupid question than to be plain Stupid and not ask at all" |
You can have two interrupts. One for touch down and another for touch up. Within the interrupt use a SELECT CASE statement or some other way to determine what is being touched. See page 23 of the advanced manual. Geoff Geoff Graham - http://geoffg.net |
Thanks Geoff, was reading all that last night. I just have to get my little brain to understand it all, but I'm confident I will have it up and running soon. Paul "It is better to be ignorant and ask a stupid question than to be plain Stupid and not ask at all" |
Trying to test my new code but MM+ wont connect to my GPS receiver. I am using the command 'OPEN "COM2:4800" As #1' but I see in the advanced Manual that the OPEN command is used to OPEN a file for reading or writing. Is there any conflict here. Paul. "It is better to be ignorant and ask a stupid question than to be plain Stupid and not ask at all" |
It should work for either COM ports or files and your command looks OK to me. Jim VK7JH MMedit |
I have done a bit of playing around with serial on the new MM+, and can confirm that the serial ports do work, so this command should be working for you. What is the rest of the code you are using to talk to the GPS on COM2? It is quite possible that there is an error there, as COM2 to the GPS device should actually be open. At the command prompt, and assuming that some data should have been sent by the GPS module, type the following: ? LOC(#1) If the number is zero, no data has been received. If the number is not zero, then there is data from the GPS sitting in COM2's receive buffer waiting for you. Smoke makes things work. When the smoke gets out, it stops! |
The rest of the code is OK I have it working on other devices. Just wanted to confirm the OPEN command before I looked elsewhere. Paul. "It is better to be ignorant and ask a stupid question than to be plain Stupid and not ask at all" |
OK Iv'e been working on this for most of the day. I just can't get the COMM port to work on the Explore-64 board. I checked the TX connection from the GPS back to pin 59 on the 470 (I'm using COMM1) and it is OK. I have printed out what I am receiving and the characters are rubbish. If I connect the GPS to the board running a 170 chip with exactly the same code it works fine. I'm stumped and need a break maybe alcohol is the answer. Paul. "It is better to be ignorant and ask a stupid question than to be plain Stupid and not ask at all" |
Rubbish characters are usually a wrong baud rate or inverted signal. Try adding 'INV' to the end of your comspecs. You will need a few of the optional parameters in there as well. Jim VK7JH MMedit |
I doubt that could be the problem as it all works on the 170 chip. Is there a way to test the COMM PORT by tying TX and RX together. Paul. "It is better to be ignorant and ask a stupid question than to be plain Stupid and not ask at all" |
OK after many hours I have this working in a sort of fashion, but still have a problem with 'TOUCH' When a button is touched I want to go to another screen so I had to use GUI DELETE to get rid of the buttons but when I return to the main screen and redraw the GUI BUTTONS they don't work. Try this short example GUI INTERRUPT CHOOSE START: Screen Do Loop Sub Screen GUI BUTTON #1, "SELECT",50,100,185,40,RGB(Black),RGB(Green) End Sub CHOOSE: GUI Delete #1 CLS Pause 2000 GoTo Start After the interrupt the screen is redrawn but the button won't work. Paul. Edit: I tried GUI HIDE and GUI RESTORE with the same result. "It is better to be ignorant and ask a stupid question than to be plain Stupid and not ask at all" |
Can not test it here but rewrite your code like this: [code] ActiveScreen = 0 NextScreen = 1 GUI INTERRUPT CHOOSE Do if NextScreen <> ActiveScreen then Screen NextScreen endif Loop Sub Screen(value) if value = 1 then GUI BUTTON #1, "SELECT",50,100,185,40,RGB(Black),RGB(Green) endif if value = 2 then GUI DELETE #1 CLS pause 2000 NextScreen = 1 endif ActiveScreen = value End Sub Sub CHOOSE 'You can add code here to examine the touch location and decide which screen 'you want to show. NextScreen = 2 End Sub [/code] Microblocks. Build with logic. |
Thanks TZ but your code won't work for me. When you a next near an MM+ can you test and advise. Paul. "It is better to be ignorant and ask a stupid question than to be plain Stupid and not ask at all" |
| Page 1 of 2 |
