Forum Index : Microcontroller and PC projects : MM Edit Version 3.6.2
A few small changes When doing 'remove blank lines and comments', any white space is also removed on lines which had comments. When you go to Connect/New... There is an option add a list of com ports you want excluded from searches. The list needs a space between ports. eg "COM1 COM3". Remember to "save" before exiting. This is handy if you have a modem or other device you want left alone. Currently, you can still select the excluded port manually. Fixed a bug when you opened file manager with a serial port that doesn't have a 'mite attached. TFTcolour.exe is included in the distribution and there is a link to it in the File menu as well as a desktop shortcut. I have attempted to make TFTcolour's 'picker' work on displays set to other than 100%. F1 will give you the options. Download the full update from the usual location http://www.c-com.com.au/MMedit.htm The attached ZIP contains the replacement TKN file and an updated TFTcolour.exe. Put TFTcolour.exe into MMEdit's program folder if you want the File menu link to work. 2015-08-21_050431_MMedit.zip Jim VK7JH MMedit |
Thanks once again Jim |
