Forum Index : Microcontroller and PC projects : Sunrise-sunset times
I was asked to update an old MMBasic program from a few years ago. Old enough to have line numbers. This I have done and here it is. I also went back and started from the original GWBasic (?) program, documenting the step as I went. I will finish writing up the process as I think it will help others. I can also improve the Variable report in MMEdit to make life easier. There are lots of fantastic programs out there and they are crying to get rediscovered. This offering works on Maximites running V4.5 as well as micromites running V4.7 and I see no reason why V4.6 would be a problem. ' Sunrise-Sunset ' TassyJim 12 Sep 2015 ' Suitable for MMBasic V4.5 and above on Maximites and Micromites ' ' Latitude South and Longitude West are negative ' Time zones east of Greenwich (Australian) are negative ' ' Original program notes: ' This program by Roger W. Sinnott calculates the times of sunrise ' and sunset on any date, accurate to the minute within several ' centuries of the present. It correctly describes what happens in the ' arctic and antarctic regions, where the Sun may not rise or set on ' a given date. Enter north latitudes positive, west longitudes ' negative. For the time zone, enter the number of hours west of ' Greenwich (e.g., 5 for EST, 4 for EDT). The calculation is ' discussed in Sky & Telescope for August 1994, page 84. IF MM.VER >4.05 THEN ' OPTION EXPLICIT introduced in V4.6 OPTION EXPLICIT DIM Lat,Lon,Tz,D,M,Y ENDIF DO INPUT "Lat, Long (deg)";Lat,Lon INPUT "Time zone (hrs)";Tz INPUT "Year, Month, Day";Y,M,D IF Y<100 THEN Y = Y + 2000 ' allow for two digit years PRINT suntimes$(Lat,Lon,Tz,Y,M,D) PRINT "" LOOP END FUNCTION suntimes$(Lat,Lon,Tz,Y,M,D) ' returns a string with sunrise and sunset times LOCAL Ax(2), Dx(2), crlf$ LOCAL K1,Z0,G,D1,F,J,S,A,J3,T,TT,T0,n,L,V,U,W,P,B LOCAL A5,A0,D0,DA,DD,A2,D2,H0,H1,H2,L0,L2,C0,C,H7 LOCAL Z,M8,W8,V0,V2,E,T3,H3,M3,N7,D7,AZ,D5,Z1,V1 LOCAL Sset$,Srise$,Msg1$,Msg2$,Msg3$,Msg4$ crlf$=CHR$(13)+CHR$(10) K1=15*(PI/180)*1.0027379 Sset$="Sunset at " Srise$="Sunrise at " Msg1$="No sunrise this date" Msg2$="No sunset this date" Msg3$="Sun down all day" Msg4$="Sun up all day" Lon=Lon/360: Z0=Tz/24 G=1: IF Y<1583 THEN G=0 D1=INT(D): F=D-D1-.5 J=0-INT(7*(INT((M+9)/12)+Y)/4) IF G<>0 THEN S=SGN(M-9): A=ABS(M-9) J3=INT(Y+S*INT(A/7)) J3=0-INT((INT(J3/100)+1)*3/4) ENDIF J=J+INT(275*M/9)+D1+G*J3 J=J+1721027+2*G+367*Y IF F<0 THEN F=F+1: J=J-1 ENDIF T=(J-2451545)+F TT=T/36525+1: ' TT = centuries from 1900 ' LST at 0h zone time T0=T/36525 S=24110.5+8640184.813*T0 S=S+86636.6*Z0+86400*Lon S=S/86400: S=S-INT(S) T0=S*360*PI/180 T=T+Z0 ' Get Sun's Position FOR n = 1 TO 2 ' Fundamental arguments ' (Van Flandern & ' Pulkkinen, 1979) L=.779072+.00273790931*T G=.993126+.0027377785*T L=L-INT(L): G=G-INT(G) L=L*PI*2: G=G*PI*2 V=.39785*SIN(L) V=V-.01000*SIN(L-G) V=V+.00333*SIN(L+G) V=V-.00021*TT*SIN(L) U=1-.03349*COS(G) U=U-.00014*COS(2*L) U=U+.00008*COS(L) W=-.00010-.04129*SIN(2*L) W=W+.03211*SIN(G) W=W+.00104*SIN(2*L-G) W=W-.00035*SIN(2*L+G) W=W-.00008*TT*SIN(G) ' Compute Sun's RA and Dec S=W/SQR(U-V*V) A5=L+ATN(S/SQR(1-S*S)) S=V/SQR(U):D5=ATN(S/SQR(1-S*S)) 'R5=1.00021*SQR(U) ' we don't use R5 anywhere Ax(n)=A5: Dx(n)=D5 T=T+1 NEXT n T=T-1 IF Ax(2)<Ax(1) THEN Ax(2)=Ax(2)+PI*2 Z1=(PI/180)*90.833: ' Zenith dist. S=SIN(Lat*(PI/180)): C=COS(Lat*(PI/180)) Z=COS(Z1): M8=0: W8=0: PRINT A0=Ax(1): D0=Dx(1) DA=Ax(2)-Ax(1): DD=Dx(2)-Dx(1) FOR C0=0 TO 23 P=(C0+1)/24 A2=Ax(1)+P*DA: D2=Dx(1)+P*DD ' Test an hour for an event L0=T0+C0*K1: L2=L0+K1 H0=L0-A0: H2=L2-A2 H1=(H2+H0)/2: ' Hour angle, D1=(D2+D0)/2: ' declination, ' at half hour IF C0<=0 THEN V0=S*SIN(D0)+C*COS(D0)*COS(H0)-Z ENDIF V2=S*SIN(D2)+C*COS(D2)*COS(H2)-Z IF SGN(V0)<>SGN(V2) THEN V1=S*SIN(D1)+C*COS(D1)*COS(H1)-Z A=2*V2-4*V1+2*V0: B=4*V1-3*V0-V2 D=B*B-4*A*V0 IF D >= 0 THEN D=SQR(D) IF V0<0 AND V2>0 THEN suntimes$=suntimes$ + Srise$ IF V0<0 AND V2>0 THEN M8=1 IF V0>0 AND V2<0 THEN suntimes$=suntimes$ + Sset$ IF V0>0 AND V2<0 THEN W8=1 E=(0-B+D)/(2*A) IF E>1 OR E<0 THEN E=(0-B-D)/(2*A) T3=C0+E+1/120: ' Round off H3=INT(T3): M3=INT((T3-H3)*60) suntimes$=suntimes$ + ftime$(H3,M3) H7=H0+E*(H2-H0) N7=-COS(D1)*SIN(H7) D7=C*SIN(D1)-S*COS(D1)*COS(H7) AZ=ATN(N7/D7)/(PI/180) IF D7<0 THEN AZ=AZ+180 IF AZ<0 THEN AZ=AZ+360 IF AZ>360 THEN AZ=AZ-360 suntimes$=suntimes$ + ", azimuth "+STR$(AZ)+crlf$ ENDIF ENDIF A0=A2: D0=D2: V0=V2 NEXT IF M8=0 AND W8=0 THEN ' Special msg? IF V2<0 THEN suntimes$=suntimes$ + Msg3$+crlf$ IF V2>0 THEN suntimes$=suntimes$ + Msg4$+crlf$ ELSE IF M8=0 THEN suntimes$=suntimes$ + Msg1$+crlf$ IF W8=0 THEN suntimes$=suntimes$ + Msg2$+crlf$ ENDIF END FUNCTION FUNCTION ftime$(h,m) ' a time format method that works on most versions of MMBasic ftime$=RIGHT$(STR$(h+100),2)+":"+RIGHT$(STR$(m+100),2) END FUNCTION Jim VK7JH MMedit |
Good stuff ! Are those last-of-sun's-disc on horizon times ? The NOAA spreadsheet gives sunrise/sunset times but there is a disclaimer, the values are not to be used for legalistic purposes. (Atmospheric refraction varies slightly with pressure etc) How about posting some comparison values ? I guess MMBasic uses Microchips double precision trig functions ? I am wondering if say the equivalent code on Arduino etc would work nearly as well. It would be good to see MMx being used for alternative / solar projects a lot more. |
The program uses "Z1=(PI/180)*90.833: ' Zenith dist. " So I think that 90.833 means last-of-sun's-disc horizon times. As far as accuracy, MMBasic uses 32bit floating point and so did GWBasic/Quick Basic. The times seem to agree with most on-line and BOM figures. I deliberately didn't use seconds in the output. Most of the variations between civil, military etc are for twilight time. Jim VK7JH MMedit |
| MMAndy Regular Member Joined: 16/07/2015 Location: United StatesPosts: 91 |
Using your "old" sunrise sunset algorithm, in DOS, I inputted the following for Columbus, Ohio USA: Lat: 39.9833 <--- in decimal Long: -83.9833 timezone: 4 (EDT) Year 2015 Day 12 Month 9 Old result: +- 1 min <--- good sunrise at 07:11, azimuth 84.1997 <--- OK sunset at 19:45, azimuth 275.545 <--- OK New algorithm result for MM+: sunrise at 03:02, azimuth 118.191 <---? sunset at 12:35, azimuth 241.728 <---? Did you change the input format? |
Using your data: DOS MMBasic Version 4.5 Copyright 2011-2014 Geoff Graham Lat, Long (deg)? 39.9833,-83.9833 Time zone (hrs)? 4 Year, Month, Day? 15,9,12 Sunrise at 07:14, azimuth 83.8052 Sunset at 19:50, azimuth 275.939 I think you had the date order wrong. I used Year, Month, Day to get away from the usual problem of some countries have their date the wrong way around. ie MM/DD/YY instead of the Australian DD/MM/YY If you program gets it's input from a user, you will need to put sanity checks in to be confident that the data inputted is OK. Even then, it is difficult to know if 1/4 is January 4th or 1st April. The function doesn't do ANY range checking. It is always possible that there is an error in my conversion. I did the checking using my location which is South and West rather than your North and East. Jim VK7JH MMedit |
The reason I ask, is that [I think] the trig libraries called in C default to industrial-strength high precision algorithms, even if the calling input and output is by using single precision variables. As an exercise I changed a program using dp variables to sp, with very little effect on the results ! The downside is the libraries are larger and a little slower, less precision routines can be specified if wanted but it is a deliberate step. Arduino "double" actually is single, so I am wondering what libraries arduino uses...may be it has space restraints more. There seem to be quite a few solar projects with arduino but not much detail on how useful the results are. edit BTW why aren't the "number of posts" numbers increasing ? Perhaps the corgis are getting sneaking bytes |
I 'think' that MMBasic uses single precision internals for the trig functions. I was raised with a slide-rule and lookup tables. Double precision wasn't an issue. I do remember having to calculate the effects that small input errors would have on the end result. It is rather frightening sometimes. I also should look at the processing order to see if there is any unnecessary loss of precision. That's more an issue with integer maths. As far as this program goes, most of the inaccuracy will be from the ' Fundamental arguments - (Van Flandern & Pulkkinen, 1979) Some of them are 9 significant digits long even though the floating point number they are stored in will round them off. Other constants are only 3 or 4 significant digits. Within a minute is good enough for me and most solar tracking purposes. I live on high ground so I get a head start.... The main thing is to know what precision your purposes require. Jim VK7JH MMedit |
I found a bug... It's one that always seems to catch me out. Variables passed to functions are passed by reference so if your function changes it, the 'master copy' is also changed. If you were to run my function twice in a row without resetting the variables, you would get different results. The suntimes$() function now doesn't alter any of the variables passed to it. This version also has a function to print out the inputs in a different format so the user can see that his/her input is correct (or not). ' Sunrise-Sunset ' TassyJim 13 Sep 2015 ' Suitable for MMBasic V4.5 and above on Maximites and Micromites ' ' Latitude South and Longitude West are negative ' Time zones east of Greenwich (Australian) are negative ' ' Original program notes: ' This program by Roger W. Sinnott calculates the times of sunrise ' and sunset on any date, accurate to the minute within several ' centuries of the present. It correctly describes what happens in the ' arctic and antarctic regions, where the Sun may not rise or set on ' a given date. Enter north latitudes positive, west longitudes ' negative. For the time zone, enter the number of hours west of ' Greenwich (e.g., 5 for EST, 4 for EDT). The calculation is ' discussed in Sky & Telescope for August 1994, page 84. IF MM.VER >4.05 THEN ' OPTION EXPLICIT introduced in V4.6 OPTION EXPLICIT DIM Lat,Lon,Tz,D,M,Y ENDIF DO INPUT "Lat, Long (deg)";Lat,Lon INPUT "Time zone (hrs)";Tz INPUT "Year, Month, Day";Y,M,D IF Y<100 THEN Y = Y + 2000 ' allow for two digit years PRINT "" PRINT checkinput$(Lat,Lon,Tz,Y,M,D) PRINT "" PRINT suntimes$(Lat,Lon,Tz,Y,M,D) PRINT "" LOOP END FUNCTION suntimes$(Lat,Lon,Tz,Y,M,D) ' returns a string with sunrise and sunset times LOCAL Ax(2), Dx(2), crlf$, Lonx, Dy LOCAL K1,Z0,G,D1,F,J,S,A,J3,T,TT,T0,n,L,V,U,W,P,B LOCAL A5,A0,D0,DA,DD,A2,D2,H0,H1,H2,L0,L2,C0,C,H7 LOCAL Z,M8,W8,V0,V2,E,T3,H3,M3,N7,D7,AZ,D5,Z1,V1 LOCAL Sset$,Srise$,Msg1$,Msg2$,Msg3$,Msg4$ Dy=D crlf$=CHR$(13)+CHR$(10) K1=15*(PI/180)*1.0027379 Sset$="Sunset at " Srise$="Sunrise at " Msg1$="No sunrise this date" Msg2$="No sunset this date" Msg3$="Sun down all day" Msg4$="Sun up all day" Lonx=Lon/360: Z0=Tz/24 G=1: IF Y<1583 THEN G=0 D1=INT(Dy): F=Dy-D1-.5 J=0-INT(7*(INT((M+9)/12)+Y)/4) IF G<>0 THEN S=SGN(M-9): A=ABS(M-9) J3=INT(Y+S*INT(A/7)) J3=0-INT((INT(J3/100)+1)*3/4) ENDIF J=J+INT(275*M/9)+D1+G*J3 J=J+1721027+2*G+367*Y IF F<0 THEN F=F+1: J=J-1 ENDIF T=(J-2451545)+F TT=T/36525+1: ' TT = centuries from 1900 ' LST at 0h zone time T0=T/36525 S=24110.5+8640184.813*T0 S=S+86636.6*Z0+86400*Lonx S=S/86400: S=S-INT(S) T0=S*360*PI/180 T=T+Z0 ' Get Sun's Position FOR n = 1 TO 2 ' Fundamental arguments ' (Van Flandern & ' Pulkkinen, 1979) L=.779072+.00273790931*T G=.993126+.0027377785*T L=L-INT(L): G=G-INT(G) L=L*PI*2: G=G*PI*2 V=.39785*SIN(L) V=V-.01000*SIN(L-G) V=V+.00333*SIN(L+G) V=V-.00021*TT*SIN(L) U=1-.03349*COS(G) U=U-.00014*COS(2*L) U=U+.00008*COS(L) W=-.00010-.04129*SIN(2*L) W=W+.03211*SIN(G) W=W+.00104*SIN(2*L-G) W=W-.00035*SIN(2*L+G) W=W-.00008*TT*SIN(G) ' Compute Sun's RA and Dec S=W/SQR(U-V*V) A5=L+ATN(S/SQR(1-S*S)) S=V/SQR(U):D5=ATN(S/SQR(1-S*S)) 'R5=1.00021*SQR(U) ' we don't use R5 anywhere Ax(n)=A5: Dx(n)=D5 T=T+1 NEXT n T=T-1 IF Ax(2)<Ax(1) THEN Ax(2)=Ax(2)+PI*2 Z1=(PI/180)*90.833: ' Zenith dist. S=SIN(Lat*(PI/180)): C=COS(Lat*(PI/180)) Z=COS(Z1): M8=0: W8=0: PRINT A0=Ax(1): D0=Dx(1) DA=Ax(2)-Ax(1): DD=Dx(2)-Dx(1) FOR C0=0 TO 23 P=(C0+1)/24 A2=Ax(1)+P*DA: D2=Dx(1)+P*DD ' Test an hour for an event L0=T0+C0*K1: L2=L0+K1 H0=L0-A0: H2=L2-A2 H1=(H2+H0)/2: ' Hour angle, D1=(D2+D0)/2: ' declination, ' at half hour IF C0<=0 THEN V0=S*SIN(D0)+C*COS(D0)*COS(H0)-Z ENDIF V2=S*SIN(D2)+C*COS(D2)*COS(H2)-Z IF SGN(V0)<>SGN(V2) THEN V1=S*SIN(D1)+C*COS(D1)*COS(H1)-Z A=2*V2-4*V1+2*V0: B=4*V1-3*V0-V2 Dy=B*B-4*A*V0 IF Dy >= 0 THEN Dy=SQR(Dy) IF V0<0 AND V2>0 THEN suntimes$=suntimes$ + Srise$ IF V0<0 AND V2>0 THEN M8=1 IF V0>0 AND V2<0 THEN suntimes$=suntimes$ + Sset$ IF V0>0 AND V2<0 THEN W8=1 E=(0-B+Dy)/(2*A) IF E>1 OR E<0 THEN E=(0-B-Dy)/(2*A) T3=C0+E+1/120: ' Round off H3=INT(T3): M3=INT((T3-H3)*60) suntimes$=suntimes$ + ftime$(H3,M3) H7=H0+E*(H2-H0) N7=-COS(D1)*SIN(H7) D7=C*SIN(D1)-S*COS(D1)*COS(H7) AZ=ATN(N7/D7)/(PI/180) IF D7<0 THEN AZ=AZ+180 IF AZ<0 THEN AZ=AZ+360 IF AZ>360 THEN AZ=AZ-360 suntimes$=suntimes$ + ", azimuth "+STR$(AZ)+crlf$ ENDIF ENDIF A0=A2: D0=D2: V0=V2 NEXT IF M8=0 AND W8=0 THEN ' Special msg? IF V2<0 THEN suntimes$=suntimes$ + Msg3$+crlf$ IF V2>0 THEN suntimes$=suntimes$ + Msg4$+crlf$ ELSE IF M8=0 THEN suntimes$=suntimes$ + Msg1$+crlf$ IF W8=0 THEN suntimes$=suntimes$ + Msg2$+crlf$ ENDIF END FUNCTION FUNCTION ftime$(h,m) ' a time format method that works on most versions of MMBasic ftime$=RIGHT$(STR$(h+100),2)+":"+RIGHT$(STR$(m+100),2) END FUNCTION FUNCTION checkinput$(Lat,Lon,Tz,Y,M,D) LOCAL mydate$, mylat$, mylon$, NS$, de, mm, La, Lo IF M>0 AND M<=12) THEN mydate$=STR$(D)+"-"+MID$("xxJanFebMarAprMayJunJulAugSepOctNovDec",M*3,3)+"-"+STR$(Y) ELSE mydate$="Unknown date format" ENDIF IF D < 1 OR D >31 THEN mydate$="Unknown date format" ENDIF IF Lat<0 THEN NS$="South" ELSE NS$="North" ENDIF La = ABS(Lat) de=INT(La): mm = INT((La - de)*60 + 0.5) mylat$=STR$(de)+"deg "+STR$(mm)+"min "+NS$ IF Lon<0 THEN NS$="East" ELSE NS$="West" ENDIF Lo = ABS(Lon) de=INT(Lo): mm = INT((Lo - de)*60 + 0.5) mylon$=STR$(de)+"deg "+STR$(mm)+"min "+NS$ IF Tz < 0 THEN NS$="Ahead of" ELSE NS$="Behind" ENDIF checkinput$=mylat$+", "+mylon$+CHR$(13)+CHR$(10) checkinput$=checkinput$+"("+STR$(ABS(Tz))+"hrs "+NS$+" Greenwich) On "+mydate$ END FUNCTION Jim VK7JH MMedit |
Leaving out the commas will cause the wrong results. |
If it helps, then to reduce 'input error' then modify: . . . .
INPUT "Year, Month, Day";Y,M,D IF Y<100 THEN Y = Y + 2000 ' allow for two digit years to: . . . .
getDate: Y=-1:M=-1:D=-1 'reset variables to indicate missing Y,M,D entries INPUT "Year, Month, Day";Y,M,D 'set variables; any missing will still =-1 IF y<0 OR M<0 OR D<0 THEN GOTO getDate 'check Y and M and D have been entered; if not then re-enter IF Y<100 THEN Y = Y + 2000 'allow for two digit years |
This is cut-and-paste descriptions of cos from the X32 math libraries doc: cos Description: Calculates the trigonometric cosine function of a double precision floating-point value. Include: <math.h> Prototype: double cos (double x); Argument: x value for which to return the cosine Return Value: Returns the cosine of x in radians in the ranges of -1 to 1 inclusive. Remarks: A domain error will occur if x is a NaN or infinity. cosf Description: Calculates the trigonometric cosine function of a single precision floating-point value. Include: <math.h> Prototype: float cosf (float x); Argument: x value for which to return the cosine Return Value: Returns the cosine of x in radians in the ranges of -1 to 1 inclusive. Remarks: A domain error will occur if x is a NaN or infinity. So I think a C program using "cos" will use the dp function by default (promoting sp input), unless cosf is deliberately used instead. It is a strength, not a problem ! (ed - keeping track of what version of compiler does what with multiple libraries and chips and versions, is becoming an art form in itself ) Agreed, it is often not important but for solar concentrator work, a small aiming error is critical. |
I see an application for the mighty MicroMite(+). The above sunrise and sunset algorithm needs the year, month and day which can be obtained automatically from the MM+ external I2C RTC. (Date$) For the time zone, which will change during the dates of daylight saving time (+- 1 hour) you can use the DST algorithm from Geoff Graham's computer controlled clock. He uses the date and day of week to compute the daylight saving time. You need to create a flag variable to indicate whether your in or out of daylight saving time. Now what you have is an algorithm which can be used to control indoor or outdoor lighting using TassyJim's sunrise and sunset time(s) algorithm. |
| kiiid Guru Joined: 11/05/2013 Location: United KingdomPosts: 671 |
I don't think lighting normally depends strictly on hours, but rather on ambient luminosity instead. Hence for your particular application a simple photodiode based circuit with hysteresis, would do the same job more accurately from human's point of view :) http://rittle.org -------------- |
I would use both a photodiode and the sunrise sunset algorithm.
As for an output, a SSR like a 3v input Crydom brick will drive any AC mains circuit. BTW ... The sunrise sunset algorithm is awesome - TassyJim. |
If you are looking a light levels, perhaps twilight is more appropriate. There are 3 main definitions of twilight. Civil, Nautical and astronomical. For Civil twilight at mu location we have: Lat, Long (deg)? -41.125833,145.907778 Time zone (hrs)? -10 Year, Month, Day? 15,9,14 41deg 8min South, 145deg 54min West (10hrs Ahead of Greenwich) On 14-Sep-2015 Sunrise at 06:21, azimuth 85.852 Sunset at 18:04, azimuth 273.903 Twilight: Sunrise at 05:53, azimuth 90.3354 Sunset at 18:32, azimuth 269.386 All it takes is a small change to the function. The extra variable passed to it is 0=sunset/rise, 1= civil, 2=nautical, 3=astronomical. ' Sunrise-Sunset ' TassyJim 13 Sep 2015 ' Suitable for MMBasic V4.5 and above on Maximites and Micromites ' ' Latitude South and Longitude West are negative ' Time zones east of Greenwich (Australian) are negative ' ' Original program notes: ' This program by Roger W. Sinnott calculates the times of sunrise ' and sunset on any date, accurate to the minute within several ' centuries of the present. It correctly describes what happens in the ' arctic and antarctic regions, where the Sun may not rise or set on ' a given date. Enter north latitudes positive, west longitudes ' negative. For the time zone, enter the number of hours west of ' Greenwich (e.g., 5 for EST, 4 for EDT). The calculation is ' discussed in Sky & Telescope for August 1994, page 84. IF MM.VER >4.05 THEN ' OPTION EXPLICIT introduced in V4.6 OPTION EXPLICIT DIM Lat,Lon,Tz,D,M,Y ENDIF DO INPUT "Lat, Long (deg)";Lat,Lon INPUT "Time zone (hrs)";Tz INPUT "Year, Month, Day";Y,M,D IF Y<100 THEN Y = Y + 2000 ' allow for two digit years PRINT "" PRINT checkinput$(Lat,Lon,Tz,Y,M,D) PRINT "" PRINT suntimes$(Lat,Lon,Tz,Y,M,D,0) PRINT "Twilight:" PRINT suntimes$(Lat,Lon,Tz,Y,M,D,1)' 1 = Civil, 2=Nautical, 3 = Astronomical PRINT "" LOOP END FUNCTION suntimes$(Lat,Lon,Tz,Y,M,D,Tw) ' returns a string with sunrise and sunset times LOCAL Ax(2), Dx(2), crlf$, Lonx, Dy LOCAL K1,Z0,G,D1,F,J,S,A,J3,T,TT,T0,n,L,V,U,W,P,B LOCAL A5,A0,D0,DA,DD,A2,D2,H0,H1,H2,L0,L2,C0,C,H7 LOCAL Z,M8,W8,V0,V2,E,T3,H3,M3,N7,D7,AZ,D5,Z1,V1, Za LOCAL Sset$,Srise$,Msg1$,Msg2$,Msg3$,Msg4$ Dy=D crlf$=CHR$(13)+CHR$(10) K1=15*(PI/180)*1.0027379 Sset$="Sunset at " Srise$="Sunrise at " Msg1$="No sunrise this date" Msg2$="No sunset this date" Msg3$="Sun down all day" Msg4$="Sun up all day" IF Tw = 0 THEN ' sunrise/sunset Za = 0.833 ELSE Za = Tw*6 ' 1 = Civil, 2=Nautical, 3 = Astronomical ENDIF Lonx=Lon/360: Z0=Tz/24 G=1: IF Y<1583 THEN G=0 D1=INT(Dy): F=Dy-D1-.5 J=0-INT(7*(INT((M+9)/12)+Y)/4) IF G<>0 THEN S=SGN(M-9): A=ABS(M-9) J3=INT(Y+S*INT(A/7)) J3=0-INT((INT(J3/100)+1)*3/4) ENDIF J=J+INT(275*M/9)+D1+G*J3 J=J+1721027+2*G+367*Y IF F<0 THEN F=F+1: J=J-1 ENDIF T=(J-2451545)+F TT=T/36525+1: ' TT = centuries from 1900 ' LST at 0h zone time T0=T/36525 S=24110.5+8640184.813*T0 S=S+86636.6*Z0+86400*Lonx S=S/86400: S=S-INT(S) T0=S*360*PI/180 T=T+Z0 ' Get Sun's Position FOR n = 1 TO 2 ' Fundamental arguments ' (Van Flandern & ' Pulkkinen, 1979) L=.779072+.00273790931*T G=.993126+.0027377785*T L=L-INT(L): G=G-INT(G) L=L*PI*2: G=G*PI*2 V=.39785*SIN(L) V=V-.01000*SIN(L-G) V=V+.00333*SIN(L+G) V=V-.00021*TT*SIN(L) U=1-.03349*COS(G) U=U-.00014*COS(2*L) U=U+.00008*COS(L) W=-.00010-.04129*SIN(2*L) W=W+.03211*SIN(G) W=W+.00104*SIN(2*L-G) W=W-.00035*SIN(2*L+G) W=W-.00008*TT*SIN(G) ' Compute Sun's RA and Dec S=W/SQR(U-V*V) A5=L+ATN(S/SQR(1-S*S)) S=V/SQR(U):D5=ATN(S/SQR(1-S*S)) 'R5=1.00021*SQR(U) ' we don't use R5 anywhere Ax(n)=A5: Dx(n)=D5 T=T+1 NEXT n T=T-1 IF Ax(2)<Ax(1) THEN Ax(2)=Ax(2)+PI*2 Z1=(PI/180)*(90+Za): ' Zenith dist. S=SIN(Lat*(PI/180)): C=COS(Lat*(PI/180)) Z=COS(Z1): M8=0: W8=0: PRINT A0=Ax(1): D0=Dx(1) DA=Ax(2)-Ax(1): DD=Dx(2)-Dx(1) FOR C0=0 TO 23 P=(C0+1)/24 A2=Ax(1)+P*DA: D2=Dx(1)+P*DD ' Test an hour for an event L0=T0+C0*K1: L2=L0+K1 H0=L0-A0: H2=L2-A2 H1=(H2+H0)/2: ' Hour angle, D1=(D2+D0)/2: ' declination, ' at half hour IF C0<=0 THEN V0=S*SIN(D0)+C*COS(D0)*COS(H0)-Z ENDIF V2=S*SIN(D2)+C*COS(D2)*COS(H2)-Z IF SGN(V0)<>SGN(V2) THEN V1=S*SIN(D1)+C*COS(D1)*COS(H1)-Z A=2*V2-4*V1+2*V0: B=4*V1-3*V0-V2 Dy=B*B-4*A*V0 IF Dy >= 0 THEN Dy=SQR(Dy) IF V0<0 AND V2>0 THEN suntimes$=suntimes$ + Srise$ IF V0<0 AND V2>0 THEN M8=1 IF V0>0 AND V2<0 THEN suntimes$=suntimes$ + Sset$ IF V0>0 AND V2<0 THEN W8=1 E=(0-B+Dy)/(2*A) IF E>1 OR E<0 THEN E=(0-B-Dy)/(2*A) T3=C0+E+1/120: ' Round off H3=INT(T3): M3=INT((T3-H3)*60) suntimes$=suntimes$ + ftime$(H3,M3) H7=H0+E*(H2-H0) N7=-COS(D1)*SIN(H7) D7=C*SIN(D1)-S*COS(D1)*COS(H7) AZ=ATN(N7/D7)/(PI/180) IF D7<0 THEN AZ=AZ+180 IF AZ<0 THEN AZ=AZ+360 IF AZ>360 THEN AZ=AZ-360 suntimes$=suntimes$ + ", azimuth "+STR$(AZ)+crlf$ ENDIF ENDIF A0=A2: D0=D2: V0=V2 NEXT IF M8=0 AND W8=0 THEN ' Special msg? IF V2<0 THEN suntimes$=suntimes$ + Msg3$+crlf$ IF V2>0 THEN suntimes$=suntimes$ + Msg4$+crlf$ ELSE IF M8=0 THEN suntimes$=suntimes$ + Msg1$+crlf$ IF W8=0 THEN suntimes$=suntimes$ + Msg2$+crlf$ ENDIF END FUNCTION FUNCTION ftime$(h,m) ' a time format method that works on most versions of MMBasic ftime$=RIGHT$(STR$(h+100),2)+":"+RIGHT$(STR$(m+100),2) END FUNCTION FUNCTION checkinput$(Lat,Lon,Tz,Y,M,D) LOCAL mydate$, mylat$, mylon$, NS$, de, mm, La, Lo IF M>0 AND M<=12) THEN mydate$=STR$(D)+"-"+MID$("xxJanFebMarAprMayJunJulAugSepOctNovDec",M*3,3)+"-"+STR$(Y) ELSE mydate$="Unknown date format" ENDIF IF D < 1 OR D >31 THEN mydate$="Unknown date format" ENDIF IF Lat<0 THEN NS$="South" ELSE NS$="North" ENDIF La = ABS(Lat) de=INT(La): mm = INT((La - de)*60 + 0.5) mylat$=STR$(de)+"deg "+STR$(mm)+"min "+NS$ IF Lon<0 THEN NS$="East" ELSE NS$="West" ENDIF Lo = ABS(Lon) de=INT(Lo): mm = INT((Lo - de)*60 + 0.5) mylon$=STR$(de)+"deg "+STR$(mm)+"min "+NS$ IF Tz < 0 THEN NS$="Ahead of" ELSE NS$="Behind" ENDIF checkinput$=mylat$+", "+mylon$+CHR$(13)+CHR$(10) checkinput$=checkinput$+"("+STR$(ABS(Tz))+"hrs "+NS$+" Greenwich) On "+mydate$ END FUNCTION Jim VK7JH MMedit |
