Forum Index : Microcontroller and PC projects : What’s wrong with my GOSUB?
Bizzie
Posted: 04:37pm 30 Sep 2015
Hi all,
Here is a simple test of ON GOSUB
' Test of GO SUB
kb$ = Inkey$
If kb$ <> "" Then Print ">";kb$;"<== Pressed!"
On Val(kb$) GoSub Menu1,Menu2,Menu3,Menu4,Menu5,Menu6
Sub Menu1
Print "Menu 1"
End Sub
Sub Menu2
Print "Menu 2"
End Sub
Sub Menu3
Print "Menu 3"
End Sub
Sub Menu4
Print "Menu 4"
End Sub
Sub Menu5
Print "Menu 5"
End Sub
Sub Menu6
Print "Menu 6"
End Sub
Here is two attempted runs
> run
>1<== Pressed!
[6] On Val(kb$) GoSub Menu1,Menu2,Menu3,Menu4,Menu5,Menu6
Error: Cannot find label
> run
>2<== Pressed!
> ? mm.ver
4.05
I am using a CGCOLORMAX 2 running the above version.
What is it that I do not understand?
Rob
Rob White
Posted: 05:03pm 30 Sep 2015
' Test of GO SUB
DO
kb$ = INKEY$
IF kb$ <> "" THEN PRINT ">";kb$;"<== Pressed!"
ON VAL(kb$) GOSUB Menu1,Menu2,Menu3,Menu4,Menu5,Menu6
LOOP
Menu1:
PRINT "Menu 1"
RETURN
Menu2:
PRINT "Menu 2"
RETURN
Menu3:
PRINT "Menu 3"
RETURN
Menu4:
PRINT "Menu 4"
RETURN
Menu5:
PRINT "Menu 5"
RETURN
Menu6:
PRINT "Menu 6"
RETURN
I would use SELECT CASE rather than ON GOSUB then you can use SUB....END SUB
Edit: Select case is not available for MMBasic V4.5
JimEdited by TassyJim 2015-10-02
Bizzie
Posted: 05:21pm 30 Sep 2015
Thanks Jim,
Yes I would use Select Case too if I could. Don't like labels much!
Rob
Rob White
BobD
Posted: 07:34pm 30 Sep 2015
You could try resolving Val(kb$) before the ON command.
[code]
kb$ = Inkey$
kb = val(kb$)
On kb GoSub Menu1,Menu2,Menu3,Menu4,Menu5,Menu6
[/code]
MicroBlocks
Posted: 07:52pm 30 Sep 2015
Another possibility. I like to change strings into numbers as quickly as possible because strings are pretty slow in processing. (Not so important here).
[code]
DO
key = ASC(INKEY$) - 48 ' "1" = ascii code 49
IF key = 1 THEN
Menu1
ELSE IF key = 2 THEN
Menu2
ELSE IF key = 3 THEN
Menu3
ELSE IF key = 4 THEN
Menu4
ELSE IF key = 5 THEN
Menu5
ELSE IF key = 6 THEN
Menu6
ELSE
'Illegal key pressed
'Do something with it or ignore
ENDIF
LOOP
[/code]
Posted: 08:50pm 30 Sep 2015
@Bizzie
Answering your original question - you have no RETURN (hence TassyJim's post sorting this out).
I am sure you've managed to sort it all out by now but for completeness here is a listing using SELECT CASE that you referred to:
' Test of GO SUB
kb$ = Inkey$
kp = ASC(kb$) - 48 ' "1" = ascii code 49
select case kp
case 1
Menu1
case 2
Menu2
case 3
Menu3
case 4
Menu4
case 5
Menu5
case 6
Menu6
case else
end select
Sub Menu1
Print "Menu 1"
End Sub
Sub Menu2
Print "Menu 2"
End Sub
Sub Menu3
Print "Menu 3"
End Sub
Sub Menu4
Print "Menu 4"
End Sub
Sub Menu5
Print "Menu 5"
End Sub
Sub Menu6
Print "Menu 6"
End Sub
WW
EDIT: Not sure if v4.05 has the SELECT CASE function Edited by WhiteWizzard 2015-10-02
Posted: 09:11pm 30 Sep 2015
No.
If ...Then
ELSEIF ...
ENDIF
is the alternative.
Bizzie
Posted: 09:57pm 30 Sep 2015
Thanks to all who have responded.
All sorted now.
Rob
Rob White
