Local Time 06:07 24 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MPU-6050 accelerometer
Posted: 07:20pm 15 Oct 2015
Back in April MOBI mentioned the MPU-6050 but I put in in the todo pile for future reference.
I wanted an inclinometer to monitor the vents in my hothouses so I ordered a couple of modules and had a play.
Talking to the module was straight forward and converting 'g' readings to angle is not too difficult. As with all trig, allowing for zero and 90 degrees is a must.
' TassyJim
' 16 October 2015
' MPU-6050 gyro/accelerometer
OPTION EXPLICIT
DIM MPU = &h68 ' MPU-6050 address
DIM temp, accelX, accelY, accelZ, gyroX, gyroY, gyroZ, tilt, accelM
DIM gyro(14)
PRINT CHR$(27)+"[2J" ' VT100 CLS
I2C OPEN 100,0
I2C WRITE MPU,0,2,&h6B,0 'wake up the MPU-6050
IF MM.I2C = 0 THEN
DO
I2C WRITE MPU,1,1,&h3B 'Reset memory pointer.
I2C READ MPU,0,14,gyro(1) 'Read 14 bytes
accelX=sint16(gyro(1)*256+gyro(2))
accelY=sint16(gyro(3)*256+gyro(4))
accelZ=sint16(gyro(5)*256+gyro(6))
temp=sint16(gyro(7)*256+gyro(8))/340+36.53
gyroX=sint16(gyro(9)*256+gyro(10))
gyroY=sint16(gyro(11)*256+gyro(12))
gyroZ=sint16(gyro(13)*256+gyro(14))
accelM=SQR(accelX*accelX+accelZ*accelZ)
IF accelM=0 THEN ' avoid divde by zero error
IF IF accelY<0 THEN
tilt=-90
ELSE
tilt=90
ENDIF
ELSEIF accelZ<0 THEN
IF accelY<0 THEN
tilt= -180 - DEG(ATN(accelY/accelM))
ELSE
tilt= 180 - DEG(ATN(accelY/accelM))
ENDIF
ELSE
tilt = DEG(ATN(accelY/accelM))
ENDIF
PRINT CHR$(27)+"[1;1H",TIME$
PRINT "ACCEL_XOUT ",accelX," "
PRINT "ACCEL_YOUT ",accelY," "
PRINT "ACCEL_ZOUT ",accelZ," "
PRINT "TEMP_OUT ",STR$(temp,3,1)," "
PRINT "GYRO_XOUT ",gyroX," "
PRINT "GYRO_YOUT ",gyroY," "
PRINT "GYRO_ZOUT ",gyroZ," "
PRINT
PRINT STR$(tilt,4,1)," Degrees"
PAUSE 1000
LOOP
ELSE
PRINT "I2C error ",MM.I2C
ENDIF
END
FUNCTION sint16(x) ' convert to signed 16 bit number
IF x>32767 THEN
sint16 = x - 65536
ELSE
sint16 = x
ENDIF
END FUNCTION
The module works in signed 16bit values so I had to convert them to floats with the function sint16().
Edit: Fixed the code for getting the quadrants right - goofed while tidying up.Edited by TassyJim 2015-10-17
viscomjim
Posted: 02:36am 16 Oct 2015
Hi TJ, this is great. I will have to give it a try. One for the library!!! Thanks.
I just notice that this thing also has temperature capabilities. I'll have to look into this.Edited by viscomjim 2015-10-17
MOBI
Posted: 11:35am 16 Oct 2015
I found it to be a useful little device, although I didn't play with it further than as a simple inclinometer (spirit level).
It is quite easy to use - the hardest part was reading and understanding the data sheet.
David M.
centrex
Posted: 03:40pm 16 Oct 2015
Hi TassyJim
Small error, you have two if statements on the same line here
IF IF accelY<0 THEN
tilt=-90
ELSE
removing the extra if I do not get any readings other than 36.5 for temperature and a line that says 90.
None of which appear to be correct.
Cliff
Cliff
VK2MCT
Posted: 04:45pm 16 Oct 2015
I hadn't heard of this device before and I'm thinking it might be useful for measuring the level in tanks. Maybe a float on a lever. Measure the angle of the lever for indication of fluid depth.
John B
centrex
Posted: 04:59pm 16 Oct 2015
All working doesnt like having an rtc plugged in at the same time.
But it doesnt show from 1 to 360 is this possible .
Other than that all is good.
Cliff
Cliff
Posted: 05:21pm 16 Oct 2015
IF IF accelY<0 THEN
tilt=-90
ELSE
Cliff
Thanks.
I should stop 'tidying up' code without testing it afterwards.
I started with only using two axis and decided to use the third one for greater accuracy. I should have left it alone.
The chance of having accelM=0 is very slim so the faulty code would not run very often, but still needs to be fixed.
I chose +/- 180 degrees but you could add 180 to get 0 to 360.
It also depends on where you want zero to be.
The orientation of the module might also require different axis to be used.
I am surprised that the unit doesn't play nice with the RTC connected. Perhaps the pullups end up being too low when in parallel.
@John,
It could be attached to a float arm. I will have some on hothouse vents which will tilt over 20 degrees or so from closed to fully open.
For my tank levels, I use ultrasonic distance devices (the waterproof ones with the sensor remote from the electronics.
BobD
Posted: 07:21pm 16 Oct 2015
Jim, Centrex
The problem with the RTC is the MPU-6050 uses the same I2C address as the DS323x RTCs. If they are on the same bus then it's a problem.
Bob
Posted: 07:47pm 16 Oct 2015
  BobD said   Jim, Centrex
Bob
That's not nice.
The MPU-6050 has a pin for changing the LSB of the address so there is a solution.
Tie the 'AD0' pin to VCC and use &h69 for the address.
Posted: 09:51pm 16 Oct 2015
  centrex said   But it doesnt show from 1 to 360 is this possible .
Cliff
Replace the last PRINT statement with these line:
PRINT STR$(tilt,4,1),"Degrees (+/-)"
tilt = ((tilt*10+3600) mod 3600)/10 ' MOD gives the result in integers
'if tilt = 0 then tilt = 360 ' uncomment if you want 360 instead of 0
PRINT STR$(tilt,4,1),"Degrees (0-360)"
The MOD operator gives results as integers so I had to multiply by 10 to get one decimal place. There are other ways of doing it but this is a 'oneliner'.
darthmite
Posted: 07:10am 19 Oct 2015
Hi
I have this module to home and will try to integrate it directly as command/function
into the st7mite
Thing like this is a must have ... he he ...
The command will be :
mpu6050(#init) : initialise module on I2C port
mpu6050(#read) : read data from mpu6050
then one function per data like :
print mpu6050(#gx) for show x angle and so forth...
and as i see in other post , i go for make everything in background (angle , flip etc ..)
Cheers.
Edited by darthmite 2015-10-20
