Forum Index : Microcontroller and PC projects : print statement with only cr
| drkl Senior Member Joined: 18/10/2015 Location: HungaryPosts: 102 |
Hello, is there any possibility always overwrite a number in place? I hate the scrolling lines... drkl |
Sure put highly depended on what you are using. Which version of MMBasic and which of the Maximite/Color Maximite/Micromite is it. Microblocks. Build with logic. |
Sorry, I forgot: Micromite version 4.7 drkl |
It will also help to know what sort of display (or terminal program) you are using. If a PC, you can use VT100 commands to position the text wherever you want it. eg PRINT CHR$(27)+"[1;1H",TIME$ will print the time at row 1, column 1 If a TFT display, you use different commands. Jim VK7JH MMedit |
If you pad to a consistent length you can use print chr$(13);x$; or print chr$(13)+x$; where x$ is the padded string. The idea is CR but not LF John |
Many thanks, both solutions are good, I tested with Teraterm. drkl |
