Local Time 19:04 21 Jun 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Logical NOT not working as expected
JohnL
Posted: 01:47pm 25 Dec 2015
Micromite Plus Firmware 4.07.
NOT 0 returns 1 as expected, single bit.
Logical NOT returns 0 for all other values?
I would expect NOT to work in BASIC with at least a 16 bit integer (0 - &HFFFF)
If NOT only works with a single bit than it is almost useless in BASIC?
Posted: 03:09pm 25 Dec 2015
AND, OR and XOR are integer bitwise operators so you can usually use XOR to get a bitwise NOT.
NOT is useful in IF statements.
JohnL
Posted: 04:57pm 25 Dec 2015
Thanks Jim,
That works.
Just to clarify for anyone else that does not know the details.
If you want to invert (NOT) a 16 bit integer using XOR.
you have to XOR the number with &HFFFF.
